#1 |
I've been focusing on getting better natural light shots, usually indoors with window light and want to get some reflectors to help the cause. Ideally, I'd like to order from Amazon as I have a gift certificate there. I'm confused by all the options. This seems like a good deal. Any tips?
| sponsored links |
#2 |
"I'd kill for a hot pink 40D"
You can go as cheap as using simple posterboard
Seriously though, white and silver posterboard from hobby lobby works great as a reflector, and you can cut them up into different sizes as you need.
www.innerlightcreations.com - Gear? The stuff I have, does everything I need, and I don't worry about the latest and the greatest anymore - I worry about getting the best images I can. |
#3 | |
Location: Feeding my camera somewhere in Western Washington
I have only one regret with mine and that's because I'm a backpacker who doesn't want to pack light stands and such. Because it's round it's hard to prop it against something instead of using the holder or having another person along to hold it. They also make triangular shaped ones and squared ones (with rounded corners). In a studio setting I'm looking towards something larger as well so that I don't have to keep refocusing the light. This one is small enough that it won't do much for groups. In the end though I think having a small one and a large one (or more than one of either) is useful so it's hard to go wrong with your choice there because it is so versatile, packs down small and gets you a lot of functionality right from the start.
Canon ~ 7D, 1D MkIIn, 5D, 20D, 10D, 100-400L IS, 70-200 2.8L IS, 24-105 f4L IS, 17-40 f4L, 135mm f2L, 85mm 1.8, 50mm 1.4, 50mm 2.5 macro, Ext. tubes, TC's 1.4 & 2.0, Feisol 3441-S CF Tpod, Gitzo Traveler Mpod, Acratech ballhead, 550EX, 200EG bag, Epson Pro 3800 printer. |
| sponsored links |
#4 |
Cream of the "Prop"
Just get some foamcore.
Leave one side white and cover the other side with aluminum foil.
"If you aren't getting extraordinary images from today's dSLRs, regardless of brand, it's not the camera!" - Bill Fortney, Nikon Corp. |
#5 | |
#6 | ||
I'm afraid the gift certificate is burning a hole in my pocket. |
#7 |
Consider the size of a reflector, a 1meter reflector does pretty well for a 3/4 or headshot but sometimes struggle to get even lighting on full length shots. This said it's probably the most versatile size.
I have a 5 and 1 and it's literally been up mountains and in rivers and still going strong! Also observe your environment for 'free' reflectors such as cars, glass, white/light colour walls, and diffuse materials such as canopies. |
#8 |
User is banned from forums
From poster board to foam core to fancy reflectors costing $100's of dollars, most reflectors available will bring you the same end result overall. The main difference is personal usability and person choice.
Personally I'm not a big fan of true round reflectors, others may feel different. I feel larger oval, rectangular, or triangle shapes are more usable for angles or for proping it up against something in the cases where there is no stand or assistant to hold it. In the studio foam core is hard to beat. "V" a couple of large pieces together and you have a great inexpensive self standing reflector system thats very usable, just not very portable. 5 in 1 reflectors are versatile but a bit more work to change colors. White works best for adding soft light to portraits. Silver is good for times when you want a bit harder light cast on your subject/object or just need to reflect the light a further distance. Although I've seen photos where gold has worked, overall I feel it adds an awkward orangish cast to what it is reflected on. I rarely use it. Translucent is great for shooting through to soften your light or as an overhead diffusion screen to soften natural sunlight during harsh times of the day. Black makes a great gobo or if you want to absorb light so it doens't reflect at all. I agree with a previous post that the 36 inch/1 meter size is probably the most versatile overall. The difference I've noticed between the inexpensive (cheap) 5 in 1 type reflectors vs. the more expensive ones is the durability of the reflector itself and the fact that the rims on the cheaper ones tend to warp more easily giving you a pretzel'ish twist to the reflector itself. I prefer a straight flat reflector for even light reflection. Having said all of this..I own a little of each. I use foam core, a Amvona 5-1 reflector, poster board and smaller collapsable triangle reflectors for when I'm out and about. It's generally cheap enough to own several methods. I find myself using this cheap $15 triangle reflector that I found on ebay here: http://cgi.ebay.com/Triangular-Grip-...QQcmdZViewItem There's better made and larger versions available from name brand manufacturer's but for the money it's been very usable for me. A better made 36 inch version of this is interesting to me. |
#9 | |
It's not productive to carry it and not use it when I'm alone so I really ought to figure it out soon myself.
| Thread Tools | |
| Display Modes | |
| eBay light reflectors | simonSE15 | Small Flash and Studio Lighting | 1 | 19th of September 2007 (Wed) 09:04 |
| Light. Natural vs natural vs flash | LordV | Macro | 8 | 17th of June 2007 (Sun) 13:43 |
| natural light, reflectors and diffusers. | smittymike19 | General Photography Talk | 18 | 8th of February 2006 (Wed) 09:53 |
| (?)Glamour Candle-light and some reflectors | .me | General Photography Talk | 5 | 7th of September 2005 (Wed) 05:05 |
| Help? Low-light, natural light, high-speed, fill flash | juneappal | Canon EOS Digital Cameras | 14 | 23rd of June 2005 (Thu) 05:23 |
