Thread started 24 Nov 2004 (Wednesday) 05:39
Image stabilization
phili1
Joined Oct 2003
Nov 24, 2004 05:39 |  #1
I just purchased the Canon 100-400 L IS lens. The book says that Mode 1 for panning and Mode 2 for shots of moving objects. What is the difference isn't panning for moving subjects.
Any hints on using stabilization is welcome.
MKII N-Canon 20D - Tamron 90MM F2.8 Macro -
Tamron 17-35 F 2.8-4 - Canon 70-200 F4 L
Canon 100-400 F4.5-5.6 IS L - Kenko Pro 300 Ext 2 X - 420 EX
mr.photoguy
Nov 24, 2004 05:43 |  #2
I know Panning is when you shoot a moving object and move the camera along with the object, following it. I think it gives the blurred moving background look.
That may be the effect it gives you.
You can always have someone drive your car in a empty parking lot and then practice, take a few shots and see what you come up with.
Mode 2, most likely will help freeze the object.
Someone correct me, as I am not sure of what mode 2 is supposed to do.
Bruce
~~Your learn a lot more when your camera is out of hybernation....~~
my pbase page (external link)
C20D
10mm 2.5
phili1
Joined Oct 2003
Nov 24, 2004 05:49 |  #3
I know what Panning is what I need to know is the differenc in Modes on my lens for 1 & 2 for Image stabilization. Thanks.
But that is my confusion, 1 is fdor Panning and 2 is for moving objects, isn't that the same. It can only be answered by someone who has IS.
R.T.
Nov 24, 2004 05:51 |  #4
I'm a rookie at this so I'm guessing a little. But I think panning would be when you are moving the camera to keep up with your subject, but if you were shooting something like a hummingbird and just wanted to stop the wings then you would use mode 2 and be able to control your DOF.
R.T.
Jesper
Joined Oct 2003
Nov 24, 2004 06:08 |  #5
Mode 1 is the normal IS mode. In this mode, the image is stabilised in the horizontal as well as the vertical direction. You should keep the lens as still as possible and the IS system will counteract the vibration of your hands (when handholding the lens).
Mode 2 is panning mode. The lens will only stabilise in the vertical direction, but not in the horizontal direction. That means you can drag the lens along with a moving subject in the horizontal direction. Good when you're making photos of fast moving race cars, for example.
Doesn't the manual of the lens explain this?
IS does NOT help to stop motion of a moving subject. It only helps to counteract the slight shaking of your hands. If you want to stop motion, you must use a fast shutter speed or flash, whether you're using IS or not.
Canon EOS 5D Mark III
sdommin
Joined Dec 2002
Nov 24, 2004 06:14 |  #6
Mode 1 is for regular, handheld photography. It assumes that the movement of the lens, due to your holding it, will be in all directions (random movement).
Mode 2 is for moving objects that move in one direction only, such as a car driving by you. This way, the lens won't bother to try and correct the movement that you are intentionally giving it.
If you're using a tripod, just turn the IS "off".
Scott
http://www.pbase.com/s​dommin/favorites (external link)
ron ­ chappel
Honorary Moderator
Joined Sep 2003
Nov 24, 2004 06:30 |  #7
Jesper and scott said it exactly right,i think the manual was just abit wrongly phrased.
In fact i wonder if it's a missprint.Maybe they meant to say "non moving shots" instead of "moving shots"
Using an IS lens in the wrong mode when panning is interesting.It gives and odd 'stop ,start' effect to the subject when it can't cope.
Kinda like the way they draw fast movement in comic books :lol:
phili1
Joined Oct 2003
Nov 24, 2004 07:16 |  #8
Ok here is the exact instructions in the book
Page e9
Mode 1 Panning shots where there is considerable camera movement.
Mode 1 Shots from vechiles where there is considerable movement.
MOde 2 Shots othere then Panning shots
Then on the page before: page e8
Mode 1 If you are taking shots of a moving subject.
Mode 2 If you are taking shots of an erratically moving subject.
So you see why I am confused it contridicts itself.
They tell me Mode 1 is for panning and you tell me Mode 2 is?
Cadwell
Joined Jan 2004
Nov 24, 2004 07:46 |  #9
On the Canon EF 100-400L IS USM, IS mode 1 is for shooting with the camera held more or less stationary. IS mode 2 is for panning.
(regardless of what your manual says).
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
jyrgen
Joined Aug 2003
Nov 24, 2004 07:56 |  #10
"They" had probably the manual translated by the lowest bidder. Some of "us" have probably actually used the lens in said mode. Having recently acquired this lens, I have not tried panning mode yet, but I would put my money on the guys here :D
Canon 35/1.4 | Canon 50/1.4 | Canon 135/2 | Canon 17-40/4 | Canon 24-105/4 | Canon 70-300/4.5-5.6
Canon 5D | Canon Speedlite 430EX | Manfrotto 055 ProB + 488RC2 | Kenko ext tubes & 1.4x TC
phili1
Joined Oct 2003
Nov 24, 2004 08:15 |  #11
Thanks guys, I can usually desifer things but there remarks were contridictory.
I think thats why I had a hard time on the flights.
PacAce
Joined Feb 2003
Nov 24, 2004 08:15 |  #12
I bet it's more like the original poster misreading the instruction manual and getting confused. If you look in page 7 of the instruction manual (in English), it is clearly stated in perfect English what modes 1 and 2 are for.
I bet the original poster was misreading what's written on the left hand column of page 9. ?!
...Leo
phili1
Joined Oct 2003
Nov 24, 2004 08:33 |  #13
For Leo
This is what the manual I have says
Page e9
MOde 2 Shots other then Panning shots
Now everybody here is telling me that mode 2 is for panning.
What did I misread.
Maybe you should reread what I posted.
sdommin
Joined Dec 2002
Nov 24, 2004 08:44 |  #14
Page e9
Read the entire paragraph. It says "The image stabilizer may NOT be effective in the following types of situations...
Then it lists what you have above.
Scott
PacAce
Joined Feb 2003
Nov 24, 2004 08:48 |  #15
Phili1, as I stated earlier, you did misread the manual. Look at your manual again and note the line above what you first quoted above:
The image stabilizer may not be fully effective in the following types of situations:
And re your quote in page E-8, what you quoted (without the "Mode") applies to Mode 2. The numbers in circle are NOT the mode numbers but rather enumerative numbers.
...Leo
7,191 views & 0 likes for this thread
Image stabilization
version 2.0 /
Latest registered member is Nidge
818 guests, 438 members online
