#1 |
I've just started learning how to use PS Elements 6 for Mac, and being the technological bonehead I am, I am of course running into problems of my own design. I have an image on my computer titled IMG_1260.psd that I believe I need to convert to .jpg format, but I'm stumped as to how it's done.
Any suggestions will be appreciated! And I think I'll spend the bulk of the day learning Elements.
Canon XTi w/BG-E3 Grip 17-85 IS USM, 28-135 IS USM, 100-300 f/5.6 EF'L', 100 1:1 Macro Hoya/Cokin filters Support by Slik and Induro. Transport by Tamrac. Processing by the seat-of-my-pants. Screw-ups by myself! |
| sponsored links |
#2 |
It sounds like you need to convert the file to 8bit to enable it to be saved as a jpeg.
-- K e v i n -- Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4 Canon EOS 3, 24-105L, 135L |
#3 |
File
Save As change File Format to jpg, click save done |
| sponsored links |
#4 |
Not on a 16bit psd file you won't - you need to convert to 8 Bits/channel first
In CS3 it's 'Image' - 'Mode' - '8 Bits/channel' - Then 'save as'...
#5 |
When I opened the image in Elements, the file name ended RGB/8, so I followed beezwax advice and it worked. Thanks! I posted the image in the Landscape section.
#6 | |
thats is what happens when you do a "SAVE" not "Save As" the save as command makes it to where you can change the attributes |
#7 |
Sometimes you will have a PSD file which has more than one layer and it will need to be flattened (see bottom of layers menu) in order to have some save options be available to you.
Wayne 5D; 7D; 40D; 400D; S90; Canon EF-S 10-22, EF-S 17-55 IS, EF 24-70 f/2.8L, EF 24-105 f/4L IS, EF 70-200 f/4L, EF 70-300 f/4.5-5.6 DO IS, EF 50 f/1.8 II, EF-S 60 f/2.8 macro, EF 100 f/2.8 macro, EF 200 f/2.8L II; Domke stuff: F-2, J-1, F-4AF, F-5XB, F-802; Think Tank Retrospective 20; Gitzo 2941 w/Kirk BH-3; more other stuff than I care to admit to |
#8 |
as kevin_c pointed out you can't save to jpg if it is in 16 bit
Canon EOS 50D gripped Canon EF-S 60mm f/2.8 Macro USM, EF 28-105mm f/4-5.6 USM, EF 75-300mm f/4-5.6 III USM Canon EF-S 18-55mm f/3.5-5.6 IS Walimex 650-1300mm Canon MR-14EX, Sigma EF-500 DG Super Flash, CELESTRON C6-SGT |
#9 | |
However, if I go to 'Save for web & devices' the jpeg option is there and this then automatically converts it to 8 Bit mode, but a 'normal' (full exif) jpeg can only be saved by converting to 8 Bit.
| Thread Tools | |
| Display Modes | |
| Jpeg to PSD? | InskiP | RAW, Post Processing and Printing | 10 | 9th of May 2007 (Wed) 17:07 |
| JPEG >> PSD >> Smaller JPEG? | wonny | RAW, Post Processing and Printing | 3 | 28th of May 2006 (Sun) 11:24 |
| help me! converting psd to jpeg | rayray | RAW, Post Processing and Printing | 9 | 27th of April 2006 (Thu) 07:52 |
| Shooting JPEG or RAW and convert to JPEG | pharris | RAW, Post Processing and Printing | 10 | 25th of December 2005 (Sun) 23:00 |
| converting PSD to Jpeg | phisheyelilly | RAW, Post Processing and Printing | 10 | 23rd of January 2005 (Sun) 18:59 |
