#1 |
I want to expand my portable lighting gear so that I can be more creative. I like the IR system, but it has its limitations, so I am thinking of a radio slave. Most of them do not work with TTL (PWs, EL-Skyport, Quantum 4i, etc.). The only ones I know they do is the new Radiopopper and the Quantum FreeXWire.
My question is: In practical terms, what is the difference between working wirelessly in Auto vs TTL?
20D - 10-22mm - 17-85mm - 50 f/1.4 - 70-200 f/2.8L IS - 100mm Macro - 1.4x II - 420EX - Canon 550EX |
| sponsored links |
#2 |
I'm assuming you mean manual vs. ttl? You wouldn't really want to use multiple flashes in auto mode off camera. The main difference is the camera+flashes don't do your metering for you, also have to sneakernet setting changes among your lights. Its not much different from working with studio lights, minus modeling lights.
#3 |
I really mean Auto. I attended a Lighting seminar conducted by a local wedding photographer who used a Quantum Radio Slave 4i attatched to his Nikon SB-800s in Auto mode.
| sponsored links |
#4 |
This is just my very humble $.02 worth, but I think how "helpful" having auto flash capabilities (ETTL or otherwise) for multiple off camera flashes is really going to depend on how you plan to use them. If you're doing something like architectural photography where your trying to evenly light an entire room with multiple flashes, yea, it might work, but if you're looking to do something like portrait work or something similar, I would think having things set to "auto" would be a big hindrance since the system is going to try and "balance" the lighting to light the whole scene. As an example, let's say you're using a 3 flash system to light a model for a portrait...flash #1 is your side light, #2 is your front light and #3 is your back light. While I could be wrong, even a very sophisticated system isn't going to know that #3 is only being used as a back light, so it's going to fire that flash at the same power as the other two...see what I'm getting at? In a situation such as this, you're probably better off doing everything manually anyways and setting the power of each individual flash separately so that you can get exactly the kind of lighting that -you- want (part of that whole creative process) and not what's predetermined by the automatic settings trying to balance the whole scene.
Again this is just strictly my opinion, but I really think it's just better to use a regular trigger and either adjust the power on the flashes manually or simply move the lights around to where you want/need them to be. I don't know if that really helped you or not, but good luck with it either way! Peace, Jim
"It is horrifying that we have to fight our own government to save the environment. " - Ansel Adams Walczak Photography - www.walczakphoto.izfree.com Gear List |
#5 |
Rumor mill is that PW is coming out with something similar to the radio poppers.... but why let your camera decide what you should set your flashes at?
#6 | |
Moderator
...Leo |
#7 |
Interesting, I've not heard of that combination before. As im unsure of setup or how well it does or doesnt work I cant comment.
#8 |
In Auto mode, the speedlight determind the flash output within it's sensor area. In ETTL, the camera decides the flash power based on returned preflash, so even the subject is not directly infront of the flash, the camera can make the "fly by wire" corrections.
5D, 24-70L, 70-200L IS, 50 f1.4, 100 Macro, 580 & 430EX |
| Thread Tools | |
| Display Modes | |
| LC-4 vs LC-5 Wireless what are the differences? | tom in mpls | Accessories & Storage | 0 | 31st of August 2007 (Fri) 14:15 |
| Help with e-ttl wireless flash system, using a Sigma | bleklerat | Small Flash and Studio Lighting | 6 | 30th of March 2007 (Fri) 07:40 |
| whats the difference between auto/TTL flash? | Yella Fella | Small Flash and Studio Lighting | 6 | 16th of March 2007 (Fri) 18:49 |
| TTL auto flash... | Yella Fella | Small Flash and Studio Lighting | 1 | 13th of September 2006 (Wed) 10:36 |
| Help-will this FLASH cord work with my Rebel XT SLR camera? TTL vs E-TTL ?? | OverRunWithSons | Small Flash and Studio Lighting | 9 | 5th of January 2006 (Thu) 23:10 |
