Thread started 29 Apr 2008 (Tuesday) 11:43
Prev/next
where's the sweet spot for a 24-70L?
AlanU
Vancouver, BC
Apr 29, 2008 11:43 |  #1
I've been taking majority of my pictures indoor/home (moderate lighting) and find my XTI mated with my 24-70L to be excellent/tack sharp at f/5.6 to 6.3 with my 580EXII. I just find at f4 the images to be good but not tack sharp. No doubt all the pictures would be phenominal with a 5x7 print. The price of this glass makes me so concerned. I still have plenty of time to send it back to canon if this is an issue. My camera has been back to Canon already and has been calibrated so the camera is probably not a variable "if this is a focussing issue." or is this simply a sweet spot issue of my particular lens?
Is this due to my pixel peeping behaviour or am I just being unrealistic. My 70-200L truly appears to be tack sharp even at f/2.8 to 3.2 indoors with the same lighting. I'm just wondering if the small sensor in my XTI just cannot take advantage of the 24-70L.
The 24-70L has never disappointed me when outdoors. Perhaps this is just the fact that the quality of light is my issue for indoors.
TIA I appreciate any input.
5Dmkiv |5Dmkiii | 80D | 24LmkII | 35mm f/2 IS | 85 mkII L | 100L | EF-S 10-22 | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji X-T2 w/battery booster | 16mm f/1.4 | 56 f/1.2 | 10-24 f/4.0 | 55-200 | EF-X500
alt4852
alt4852's Avatar
Alexandria, VA
Apr 29, 2008 12:53 |  #2
when i go out to shoot with it, i primarily keep it within the f/3.2-f/5.6 range. i don't like shooting wide open unless i really need to, and i've found that stopping it down even slightly gives it a major sharpness edge. f/5.6 is sharp enough to cut your finger on, and i've never really found a need to go higher than that on a day to day basis unless i'm looking for really vast DOF or i'm shooting out in bright daylight. with the 580exii indoors, f/5.6 is probably what i'd offer as the closest the 24-70mm has to a sweet spot. i think if you find f/3.2 too soft, you're probably a pixel peeper that needs to seek some professional help. good luck! ;)
5D3 | Z21 | 35L | 50L | 85L | 135L
Cap0ne
Cap0ne's Avatar
Bucharest, Romania
Apr 29, 2008 14:24 |  #3
Sweet spot on my 24-70 is at 50mm @f5.6
But i'm using it mostly at f2.8 (that's why we pay a lot of money on 2.8 lenses, cause we need to use them wide open, don't we ? :) )
5D Mk2, 16-35 II, 35 1.4, 135 2, 2x 580EX2
Amateurs are worried about equipment, Professionals about money and Masters about light...
Through my lens
http://bogdanmarcu.blo​gspot.comexternal link
Double ­ Negative
*sniffles*
Double Negative's Avatar
New York, USA
Apr 29, 2008 15:05 |  #4
I find it to be fully usable at any aperture or focal length. Like any lens, it gets sharper as you stop it down to f/5.6-8.0, but still very usable outside that range.
La Vida Leica!external linkLitPixel Galleriesexternal link -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
ed ­ rader
"I am not the final word"
ed rader's Avatar
silicon valley
Apr 29, 2008 16:08 |  #5
AlanU wrote in post #5427366external link
unrealistic. the longer zoom is a sharper lens.
ed rader
5D4, 80d, 16-35L III, 24-70L II, 70-200L F4 IS, 100-400L II, 430exII, gitzo 3542, markins Q10, kirk, really right stuff
Steve ­ Beck
Greenville, SC
Apr 29, 2008 20:08 |  #6
Most lens's are sharpest at one stop above there rated stop.
Gear List? My gear is bigger than yours? Just shoot have fun...
Double ­ Negative
*sniffles*
New York, USA
Apr 29, 2008 20:11 |  #7
^ Actually, it's closer to two. So for an f/2.8 lens... f/5.6 would be sharpest.
Mark_Cohran
Mark_Cohran's Avatar
Joined Jul 2002
Portland, Oregon
Apr 29, 2008 20:30 |  #8
Double Negative wrote in post #5430438external link
Actually, it varies from lens to lens, so you'll have to figure it out for each one. :)
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Tumblr Site (external link) (NSFW)
V8Rumble
V8Rumble's Avatar
White Rock, BC
Apr 29, 2008 23:22 |  #9
Yeah. The 70-200 f/4 is razor sharp at f/4
30D | 18-50 EX | 30 EX | 55-250 | 150-500 OS HSM
Double ­ Negative
*sniffles*
New York, USA
Apr 30, 2008 06:17 |  #10
Mark_Cohran wrote in post #5430583external link
True, true. "Generally."  :p
cdifoto
Don't get pissy with me
cdifoto's Avatar
Apr 30, 2008 06:19 |  #11
Attached to your camera.
Did you lose Digital Photo Professional (DPP)? Get it hereexternal link. Cursing at your worse-than-a-map reflector? Check out this vid!external link
2,543 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00269 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is Eggiez
999 guests, 478 members online
Simultaneous users record so far is 6106, that happened on Jun 09, 2016
