Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 5th of May 2008 (Mon)   #1
Orlandoech
User is banned from forums
Default Canon 40D & "BUSY" annoyance...
I have a Canon 40D and when I take car motion shots, I tend to get an annoying "busy" a lot. Im using a 2GB Sandisk Ultra III card.
What fast 4GB card would guys recommend to avoid getting the "BUSY" flashing at me...
Orlandoech is offline   Reply With Quote
Old 5th of May 2008 (Mon)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: Canon 40D & "BUSY" annoyance...
What are your camera settings? Are you shooting RAW or JPEG? Are you shooting in "burst mode"? Do you have High ISO Noise Reduction set? Do you have Highlight Tone Priority set? Both those kill your buffer size. Rob Galbraith has tested a number of CF cards for the 40D; you'll actually find that the larger cards are slightly slower than the same model card in smaller capacity.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 5th of May 2008 (Mon)   #3
goldboughtrue
Is it Ultra II or Extreme III? Even then, both those cards are plenty fast for the 40D (I use both versions). This thread says it could be a CF card problem. Does it happen with any other memory cards? The only other thing I can think of is if you max out the burst and the camera has to write the info.
http://www.pbase.com/goldbough
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
goldboughtrue is offline   Reply With Quote
Old 5th of May 2008 (Mon)   #4
Orlandoech
I shoot raw and i think i have a one of those settings enabled, ill turn em off. ty
Old 5th of May 2008 (Mon)   #5
DDCSD
GIVIN' GOOD KARMA
DDCSD's Avatar
What Jon is wondering, is if you are shooting "Rapid Fire", just holding the shutter button down and letting the shutter fire away.
Derek
Bucketman Karma Fund
POTN FF L2 MadTown Birds
Full Gear List & Feedback
DDCSD is offline   Reply With Quote
Old 5th of May 2008 (Mon)   #6
Orlandoech
I was shooting in both H mode and the slower 3.5fps mode i think it is.
Old 5th of May 2008 (Mon)   #7
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
With RAW, the buffer's only 17 frames and IIRC High ISO Noise Reduction knocks that back to around 6-7 frames. Turn that off and your results should improve.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 5th of May 2008 (Mon)   #8
Orlandoech
Awesome thanks guys!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon 40D stuck at "buSY" mikaelrules Canon EOS Digital Cameras 25 5th of May 2012 (Sat) 16:11
"Echo", "Cleopatra", "Kahn", & "Yeager". PhotosGuy Wildlife 24 24th of March 2010 (Wed) 21:16
40D "busy" help... jacobsen1 Canon EOS Digital Cameras 2 12th of April 2008 (Sat) 23:34
"BUSY" message flashing on LCD when plugged in via USB verty Canon EOS Digital Cameras 13 7th of November 2006 (Tue) 02:03
