Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 8th of May 2008 (Thu)   #1
dave-o
dave-o's Avatar
Default Newb. strobe-->sync-->camera
Hi all,
I'm new to strobe photography and have been doing some research but seem to be missing some info.
I have an XTi and was planning on picking up a pair of alien bees for some architectural interiors. I also have a 420EX mounted.
The main question is: Do the sync cords plug in directly to the camera, or do I need another sort of port to plug them? Especially using two strobes.
dave-o
...if not it'll do 'til the mess gets here...
dave-o is offline   Reply With Quote
Old 8th of May 2008 (Thu)   #2
PacAce
Moderator
PacAce's Avatar
Default Re: Newb. strobe-->sync-->camera
Originally Posted by dave-o View Post
Hi all,
dave-o
Most cameras have a PC sync socket you can plug a strobe into via a PC sync cable. However, the DRebel series cameras do not have such a socket so you'll need to get a hotshoe-to-pc adapter. This is a gizmo that mounts on to your camera hotshoe. It has a PC socket where you can plug a strobe into.
...Leo
PacAce is online now   Reply With Quote
Old 8th of May 2008 (Thu)   #3
SkipD
SkipD's Avatar
Hi all,
As Leo said, you'll need a hotshoe-to-PC adapter. Plug one AB strobe into the camera and the second will trigger off the first using the built-in optical slave.
I would strongly suggest that you not try using the 420EX with the AlienBees units. There's very little way to get it to sync properly with them, as the 420EX has no manual mode. Besides, you're going to need the hotshoe for the PC adapter.
Another way to trigger the AB units would be with a radio slave system. It, too, will require using the hotshoe but this time it would be for the radio transmitter.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 8th of May 2008 (Thu)   #4
PacAce
Moderator
PacAce's Avatar
Oops. Missed that little sentence about the 420EX. Thanks for clarifying that, Skip.
...Leo
Old 8th of May 2008 (Thu)   #5
dave-o
dave-o's Avatar
does the radio slave system need a direct line of sight (or rather, line of wave) to trigger? or is it still effective tucked away?
and either way, it sounds like I can't have a flash unit mounted to the camera.
Old 8th of May 2008 (Thu)   #6
poloman
poloman's Avatar
Right...no flash on camera.
Radio slave triggers are the way to go.
One advantage to this that you may not think of right away is that with radio triggers your lights won't be set off by someone using a point and shoot camera. They also eliminate a lot of extra cords and therefore reduce your liability and set up time. Also helpful when you are trying to set ratios on your lights. It is easier to pop one light at a time.
Get a Vagabond II and you will be portable.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
poloman is offline   Reply With Quote
Old 8th of May 2008 (Thu)   #7
kacie
Dave-I just got two Promasters 7500EDF and I use them off camera, my pop up flash is the trigger.
kacie is offline   Reply With Quote
Old 8th of May 2008 (Thu)   #8
kacie
Also you might find some useful info here:http://strobist.blogspot.com/2006/03/lighting-101.html
Old 8th of May 2008 (Thu)   #9
shooterman
village idiot, actually a genius!
Doesn't the pop up pre-flash set off the off camera flashes? I've tried using my pop up in the past also and life wasn't very fun, LOL.
Randy
ModelMayhem
shooterman is offline   Reply With Quote
Old 8th of May 2008 (Thu)   #10
m3rdpwr
Originally Posted by shooterman View Post
Doesn't the pop up pre-flash set off the off camera flashes. I've tried using my pop up in the past also and life wasn't very fun, LOL.
I hear some people cut a piece from an exposed or unexposed (Can't remember) 35mm film lead to cover the built in flash.
It allows enough light to trigger the slaves, but not enough to contribute to the photo.
But hey, that's just what I hear...
-Me
m3rdpwr is offline   Reply With Quote
Old 8th of May 2008 (Thu)   #11
PacAce
Moderator
PacAce's Avatar
If you got something like this, you can have a flash mounted while still connecting a wireless remote or a PC sync cord. The flash will need to be in manual mode,though (which is the way it should be anyway).
http://flashzebra.com/hotshoes-shoes/0064.shtml
...Leo
Old 8th of May 2008 (Thu)   #12
PacAce
Moderator
PacAce's Avatar
-Me
With an exposed slide film over the flash head, most of the light passing through is the IR light to trigger optical slave units. However, it still won't get around the preflash issue presented by the built-in flash.
...Leo
Old 8th of May 2008 (Thu)   #13
m3rdpwr
I know the pre-flash is an issue, but it can be worked around with a Canon xxD model camera using both the hot shoe and the pc socket together.
(Bob Atkins does this.)
Do you in fact get a pre-flash with the built in flash when the camera is set to manual? (Something about not using focus assist light or something in Custom Function.)
I'm curious to try and test this now.
Anyone want to lend me a mono light?
(Plenty of 580EX's around.)
-Mario
Old 8th of May 2008 (Thu)   #14
kacie
I have the xti and use manual -no pre flash and you can use anything to cover the pop up, my hand sometimes but mostly use piece of white cloudy plactic to cover, sometimes depending how far away the subject the pop up flash has no effect.
Old 8th of May 2008 (Thu)   #15
PacAce
Moderator
PacAce's Avatar
A pop-up flash will also fire a preflash no matter what setting you put the camera in. If you are able to get the off-camera flashes to fire for the main exposure, you're probably using the flashes set to less than 1/2 power. And the fact that you're covering the pop-up flash would explain why you're not having exposure issues with the pop-up flash contributing too much light. This might be what m3rdpwr was referring to above regarding the use of an exposed slide film to prevent the visible flash light from affecting the exposure.
...Leo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Studio Strobe Sync Woes DaveMcKeen Small Flash and Studio Lighting 7 24th of September 2007 (Mon) 18:08
High Speed Flash Sync With Strobe? aaronrider Small Flash and Studio Lighting 33 1st of September 2007 (Sat) 17:20
MkII Strobe Sync Speed? dmwierz Canon EOS Digital Cameras 1 13th of February 2006 (Mon) 19:50
20d Studio strobe sync question. Sam Small Flash and Studio Lighting 7 31st of October 2005 (Mon) 17:54
Newbie: I need help finding a strobe sync adapter thingy ofwhatiam Accessories & Storage 8 31st of October 2005 (Mon) 09:06
