Thread started 08 May 2008 (Thursday) 12:53
POLL: "Has the new 1D MK3 1.2.3 firmware affected calibration of your lenses?"
No, not at all
36
61%
Yes, for the majority of lenses
9
15.3%
Yes, just for minority of lenses
9
15.3%
Yes, it removed need for microadjustment on my lenses
5
8.5%
59 voters, 59 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
1D MK3 Micro Adjustment Poll (1.2.3)
drisley
"What a Tool I am"
Joined Nov 2002
May 08, 2008 12:53 |  #1
Just wondering, what percentage of people's microadjustment settings were affected by the new firmware 1.2.3
I've heard many stories that some people no longer need microadjustment on some lenses, while others say no difference at all.
1D Mark III - 5D Mark IV - 24-70/2.8L - 70-200/2.8L Mark II - Samyang 14/2.8
JC4
May 08, 2008 12:58 |  #2
I originally micro-adjusted my 1d-III. A couple lenses were off in the +/- 15 range, so I sent them to Canon. Half the rest were off just a bit +/- 5. After the sub-mirror fix(mostly an adjustment to spec on my 1d), I was able to turn off the mircro feature. I've only shot with a few lenses since 1.2.3, but they've all worked perfectly. Micro-adjust disabled.
So, NO, no adjustment needed after 1.2.3.
John Caputo
drisley
"What a Tool I am"
Joined Nov 2002
May 08, 2008 13:01 |  #3
Thanks JC4
Mr. ­ Clean
May 08, 2008 13:04 |  #4
Well...I'm not sure where my settings fall.
I just received my Mark III yesterday, took some quick snaps at work but the second I got home I upgraded the firmware. I adjusted my 70-200, 24-70 and 50 1.4. My 100 f2 that is calibrated was spot on, my 120-300 is loaned out.
Not sure what to make of that since I do read that some people no longer need the microadjustments they had made previously.
Mike
some shots @ Zenfolio (external link)
mbellot
"My dog ate my title"
May 08, 2008 13:07 as a reply to  @ Mr. Clean's post |  #5
I used the Live View focus check with 1.1.3 and found 0 for my lenses was optimal so I left MA disabled.
Installed 1.2.3 and nothing has changed.
Anke
May 08, 2008 13:08 |  #6
Strangely, yes. My 100-400 went from +17 to +12, but then it could just be my bad eyesight and my feeble brain believing it had to change because others peoples did.
Anke
jmpsmash
May 08, 2008 13:21 |  #7
not affected for me.
for those who answered yes. as i believe that the microadjustment process may vary from try to try, i would suggest this experiment. repeat the microadjustment process again, and see if you get the same results. i have found that i sometimes will come up with a slightly different set of numbers for all my lenses, without any thing else changing.
EOS 1D MarkIII | 85 f/1.8 | 35 f/1.4L | 70-200 f/4L | 24-70 f/2.8L | Tamron 17-35/2.8-4 | 580exII
Badminton Central (external link) / Badminton Photography Forum (external link) / 16feathers.com (external link)
drisley
"What a Tool I am"
Joined Nov 2002
May 08, 2008 13:22 |  #8
You know, I think it depends on testing method. I NEVER could get accurate results with any test charts or moire patterns etc.
The only thing that worked properly for me was to go out and shoot real subjects, using trial and error.
Bill ­ Roberts
revolting peasant
May 08, 2008 13:34 |  #9
drisley wrote in post #5485937 (external link)
I'm just laughing at that one because you're SO right! You can agonise over mtf results and focus charts all you like. You can't actually beat getting out there and using it for taking photos :lol: it soon shows the cr*p
I'm not saying they don't help, but sometimes we forget what it's all about.
cheers
BiLL
drisley
"What a Tool I am"
Joined Nov 2002
May 08, 2008 13:39 |  #10
Heh, perhaps I dont have a good enough tripod to use charts. But I got different results EVERY time, with the majority showing 0 adjustment was best. But outside in the real world it was a completely different story.
For example, one day I went out and shot this tree (external link), first at 0, then at +20, and whittled down to +10 being the best. Then I tried many other subjects, and each and every time +10 gave the best result. And I did this hand held, no tripod, because that's how I normally shoot. My formerly "soft" 70-200 is now "razor sharp", almost as good as my ol' 135L :)
bsawle
May 08, 2008 17:18 |  #11
No micro adjustment needed before or after the upgrade.
Bruce
Way to much Canon and Nikon equipment.
drisley
"What a Tool I am"
Joined Nov 2002
May 08, 2008 17:36 |  #12
So far it looks like the majority aren't seeing any diff in calibration after the firmware update.
M ­ Powered
May 08, 2008 17:37 |  #13
Initially I thought I had to change my MA but after a shoot this past Sunday, my MA had to be the same, so firmware did nothing for my MA settings.
Canon 5D Mark III | EF 24-70 f/ 2.8 L II
http://www.keslertran.​com (external link)
http://keslertran.tumb​lr.com (external link)
agphotography
May 08, 2008 19:02 |  #14
I most definitely noticed a difference. especially in my 16-35L. I need to re-calibrate them all to make sure they are still working properly, but my 16-35 is definitely out of wack.
-Abram-
www.goglanianphoto.com (external link)
500px (external link) / Flickr (external link)
Tumblr (external link)
Galaxy99
May 08, 2008 19:09 |  #15
mbellot wrote in post #5485850 (external link)
I can't figure out Live View focus check method for microadjustment after reading the original article. Can anybody here brief it in an earlier way for me? :o
4,151 views & 0 likes for this thread
Latest registered member is jainlemos
748 guests, 426 members online
