Thread started 15 May 2008 (Thursday) 11:32
Wood walking stick monopod...what hardware for screw mount?
Laramie
Still livin' the cowboylife
May 15, 2008 11:32 |  #1
So I'm into woodworking a little and am working on some wood walking sticks that I want to use as a monopod. Here's what I'm working with. I'm thinking of just getting a screw like this, and tapping a hole on the stop and permanently screwing it in, then i'll have to screw the whole stick onto my cam. Ideas and thoughts?
IMAGE: http://www.bhphotovideo.com/images/items/391060.jpg
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i49.photobucket​.com …ley/20080515-IMG_1006.jpg (external link)
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
Jon
Joined Jun 2004
May 15, 2008 11:37 |  #2
Look for a hanger bolt (external link) - wood screw thread at one end and 1/4-20 at the other.
Jon
Cocker Spaniels
Laramie
May 15, 2008 11:40 |  #3
Jon wrote in post #5530039 (external link)
Thanks Jon!!! That's why I love this place. My local Ace should have these. I will pick one up!
jhom
May 15, 2008 11:46 |  #4
Mounting studs typically used for monopods and tripods are either 1/4"-20 or 3/8"-16.
Jim
tracknut
Joined Jun 2005
May 15, 2008 13:04 |  #5
Another thought, depending on how fancy you want to get. You could put an "insert nut" into the top of the walking stick, which is a wood thread on the outside and a machine thread on the inside. That would facilitate threading the machine screw like in your initial note, in and out, without damaging the wood side of the fitting. You could even have a matching wood "top" on the walking stick, which screws into the fitting so that when you're not using it as a monopod, the fittings and such don't show.
Dave
Performance/sport dog photographer (external link)
Facebook (external link)
"Always available to shoot your dog"
Laramie
May 15, 2008 13:07 |  #6
tracknut wrote in post #5530551 (external link)
Dave
This is actually what I originally wanted to do. I just didn't know what sort of threaded sleeve would work.
Is this a specialty part still find it an an Ace Hardware?
Laramie
May 15, 2008 13:11 |  #7
Like this Dave?
IMAGE: http://www.woodpeck.com/media/main_knockinflange.jpg
tracknut
Joined Jun 2005
May 15, 2008 13:16 |  #8
Exactly, yes. I was just poking around online to make sure I had the term right. I see various versions, you might also search on "tee nut". Some are threaded with a wood thread on the outside, some like what you show, and the tee nut seems to usually be wacked in with a hammer (which looks a bit non-professional to me). But all are geared to the same idea, installing a female machine thread into wood, such that a machine screw can be used in a stable way.
Dunno if they can be found at Ace...
Dave
Jon
Joined Jun 2004
May 15, 2008 13:21 |  #9
I think I'd go with the hanger bolt and maybe put a tee nut in the "cap". Coat the hanger bolt with epoxy (or put epoxy in the hole first) and it won't be backing out on you.
Jon
Cocker Spaniels
tracknut
Joined Jun 2005
May 15, 2008 13:22 |  #10
I'm thinking the hanger bolt on the bottom half of the walking stick, and the insert nut in the "cap" on the top of the walking stick, that will screw on to the hanger bolt when your camera isn't mounted in it. That might be the ticket.
Dave
Edit: Wow, sorry Jon, I really didn't just cut/paste your note!
Laramie
May 15, 2008 13:25 |  #11
Jon wrote in post #5530643 (external link)
So use the hanger boat, and the tee-nut would just add a little more strength to the the attachment point? I could always countersink the tee-nut into the cap so it looked clean.
tracknut wrote in post #5530656 (external link)
Dave
Yea, I agree with both ya'll. Having it anchored through the hangbolt will give more strength and stability.
When not attached to camera, I'm sure I could fab up some sort of cap to cover the bolt.
KirkHMB
May 15, 2008 14:48 |  #12
http://www.leevalley.c​om …p=44203&cat=3,4​1306,41311 (external link)
Item C would be a little higher end than the T nut. Those things you showed above are somewhere in between T nuts and this. Those typically are driven in by deadheading a bolt into the fitting, then driving it into the hole in the end of the stick.
Another woodworker here......
shooting club VB and club soccer, hoping to get back to landscape work soon.
Laramie
May 15, 2008 14:55 |  #13
KirkHMB wrote in post #5531178 (external link)
That insert is what I was looking for. will still sit flush and will at the strength. Between this, a long hanger bolt and some 2-part epoxy, it will be in there for life
4,172 views & 0 likes for this thread
Latest registered member is gary gruber
746 guests, 355 members online
