Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Macro
Reply
Thread Tools Display Modes
Old 19th of May 2008 (Mon)   #1
rab3rd
Default Macro questions
I am currently saving up for a 5d, after I buy that I am going to save for the MP-E 65mm. What type of lighting are you guys using and is bugs all that gets shot?
rab3rd is offline   Reply With Quote
Old 19th of May 2008 (Mon)   #2
rab3rd
Default Re: Macro questions
Ok, thanks then....
Old 19th of May 2008 (Mon)   #3
alliec
alliec's Avatar
Most guys that use the MPe-65 me included either use the MT24ex or an external flashgun mounted of camera on a flash bracket. I have used both a 430ex speedlite and am currently using the MT24ex twinflash, both give excellent results but will need some form of diffusion to soften the light. I primarily use the MPE for photographing the smaller insets and extreme close ups of the larger bugs. With a 5d you will be able to get slightly larger bugs but a 1:1 macro lens will still be needed such as Canon 100mm, Tamron 90mm, Sigma 105mm etc for the larger insects and such.
Alistair
My Flickr
http://www.flickr.com/photos/alliec2007/
350D, 30D, Tamron 90mm, MP-E 65, 2 x 18-55, 50 1.8 II, 430EX Speedlite, MT24ex and Kenko Extension Tubes.
alliec is offline   Reply With Quote
Old 19th of May 2008 (Mon)   #4
rab3rd
Thanks, doent the MP-E do 1:1?
Old 19th of May 2008 (Mon)   #5
alliec
alliec's Avatar
it goes from x1 to x5 life size, but dosent focus to infinity. You have to within 4inches at x1 and 1.6 inches at x5 to achieve focus. I think you will only be ablt to fit bugs about 25mm maximum in the frame, hence why a standard macro lens is also required if you want to shoot larger insects.
Alistair
My Flickr
Old 19th of May 2008 (Mon)   #6
rab3rd
thanks, good to know. So a 100mm (or 60mm) macro would be a more useful lens to start with I am guessing
Old 19th of May 2008 (Mon)   #7
alliec
alliec's Avatar
Yes definatley, the MPe-65 is pretty specalised, manual focus only etc. Get the 60mm or 100mm and some extension tubes (you will get 2:1 magnification then) and get to grips with that then get the MPe, it is an awesome lens.
Here is a shot with it.
Alistair
My Flickr
Old 19th of May 2008 (Mon)   #8
rab3rd
Nice, but that only makes me want the MP-E 65 even more......Ever shot anything other than bugs with it?
Old 19th of May 2008 (Mon)   #9
Ran_photography
Ran_photography's Avatar
Idt you can use the 60mm on a 5d can you? I thought it was a full frame? Aren't EF-S lenses ( such as the 60mm ) unable to be used on a full frame? I may be wrong. I'm not even sure what EF-S means.
Canon rebel Xti
Canon 60mm macro, 70-300mm, 10-22mm, 50mm 1.8, 18-55 kit lens
Ryan Nelson, 18
http://myspace.com/ran_photography
http://flickr.com/photos/ran_photography
Ran_photography is offline   Reply With Quote
Old 19th of May 2008 (Mon)   #10
troypiggo
troypiggo's Avatar
That's correct. On the 5D you can only use EF lenses, not EF-S.[1]
I'd go with either the Canon 100mm macro lens, or the Sigma 105mm macro. The Sigma is cheaper and just as good, if not better. Better do some researching there...
As Alistair recommends, get the 100 or 105 first. They only go 1:1 max mag (without tubes), but you can also use them as portrait lenses etc because they can focus to "infinity". The MPE-65 can only shoot 1:1 to 5:1. You could not use it to shoot a portrait of a person for example. The biggest object you would be able to shoot is something the size of you sensor IIUC.
[1] Think I may have read somewhere that if you put an extension tube between EF-S lens and full-frame camera you can use it, but you may get vignetting or something. The "S" stands for short backfocus or something like that.
"Interesting. You're afraid of insects and women. Ladybugs must render you catatonic." - Sheldon
Photoblog | Flickr | Gear List | Macro Rig | Astro Rig | Astro Software Post
troypiggo is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Macro setup questions. Chako Canon EF and EF-S Lenses 19 14th of August 2007 (Tue) 19:53
Macro questions. Andrew Pratt Canon EF and EF-S Lenses 5 19th of April 2007 (Thu) 20:08
100mm 2.8 Macro Questions TheElitist Canon EF and EF-S Lenses 8 26th of December 2005 (Mon) 19:42
Macro lens Questions Mitcon Canon EF and EF-S Lenses 2 18th of June 2005 (Sat) 05:38
===> More Macro Questions <=== C.S.I. Canon EOS Digital Cameras 5 19th of November 2004 (Fri) 09:31
