Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Motorsports
Reply
Thread Tools Display Modes
Old 17th of December 2004 (Fri)   #1
transcend
transcend's Avatar
Default Go-Karts
Went to the track last night - after having reprocessed, they turned out pretty good!
17-40mm at 17,,
pattern metering
iso 400
f b.o
1/350
high speed sync on 380ex
transcend is offline   Reply With Quote
Old 18th of December 2004 (Sat)   #2
Red
Red's Avatar
Default Re: Go-Karts
Blown out? Blown up, even! There's gone!!
Digital Rebel/300D, 18-55mm kit lens, 24-85mm USM, Nifty-Fifty, 70-210mm f2.8, 70-300mm APO Macro, Passion
Red is offline   Reply With Quote
Old 18th of December 2004 (Sat)   #3
transcend
transcend's Avatar
Heh, ya I will repost now. I reprocessed them..and the results were drastically different!
Old 20th of December 2004 (Mon)   #4
Red
Red's Avatar
Nice low down angle. I took a ton of Go-karting photos the other weekend and found that unless someone had the back-end right out or were mid-air, there was no feeling of any speed. Seems like you've got the same
Old 20th of December 2004 (Mon)   #5
gmen
gmen's Avatar
I agree with Red - good to see a low angle.
Did you try any panning shots? Sadly, in these shots the karts look as if they are parked.
Also, the very dark backgrounds make the use of flash seem somewhat harsh - perhaps it would be better to expose a little more for the ambient light.
This looks tough to shoot though - I don't envy you!
gmen is offline   Reply With Quote
Old 20th of December 2004 (Mon)   #6
mr.photoguy
Nice, here are some of mine.
http://community.webshots.com/script...umID=226877139
I like the photo's, but there isn't any movement, or blur to the tires.
Bruce
~~Your learn a lot more when your camera is out of hybernation....~~
my pbase page
C20D
10mm 2.5
mr.photoguy is offline   Reply With Quote
Old 22nd of December 2004 (Wed)   #7
transcend
transcend's Avatar
I agree, next time i will shoot with a lower shutter speed to try and get some blur out of the tires. The problem being the necessary use of the flash is going to stop the action anyways. Any good ways to get around it?
I have never shot go karts indoors before (or at all).
Most of my shooting is cycling based.
Old 22nd of December 2004 (Wed)   #8
gmen
gmen's Avatar
Bias your exposures a little more towards the ambient light... then you'll show some more motion in the images... try setting your camera an flash manually rather than relying on the camera's metering...
Old 22nd of December 2004 (Wed)   #9
transcend
transcend's Avatar
Th eproblem was I had to stop down ALOT due to having a 380 ex flash. I can't manually control the power. I used -2 FEC as well, this has been an ongoing issue with having a low budget flash. When i can afford one I will probably pick up a 580ex, but in the mean time I have to make do.
Old 23rd of December 2004 (Thu)   #10
Red
Red's Avatar
I've found that most karting centres have a wide opening along one wall. Try to position yourself close to that, but not facing it. Also, a wider appeture with a slower shutter speed should give you some action feel, a good amount of light, and a nice shallow DOF that focuses on one kart
Old 28th of December 2004 (Tue)   #11
skyphix
I know that this is a somewhat Old thread... so I apologize for digging it up...
If you have a Tripod and the room:
But something that may work, use a slower shutter speed and bigger apature. Focus on the Kart and follow it while the photo is being taken. I dont know how good the lighting is, but forego the flash and try something like f3.5 and a 1" exposure and work from there. It will probably be overexposed and the speed streaks a bit too long at that length, but its a starting poitn, and you should get some motion blur in the background while keeping the Kart in focus. This will probably take a lot of practice ( I haven't really perfected it either ), but once completed, provides an astounding feel for the speed.
skyphix is offline   Reply With Quote
Old 28th of December 2004 (Tue)   #12
OneManArmy
User is banned from forums
The colors look great in those for being so dark. I can barely tell it was done using a flash. And in general, I hate the way flash makes photos look; I'd much rather use a fast prime indoors or in low light.
OneManArmy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Some Karts (NZ) AndrewOfNZ Motorsports 3 5th of May 2007 (Sat) 05:31
Kiwi Go-Karts iKirst Motorsports 12 5th of April 2007 (Thu) 02:00
Karts Vini Motorsports 9 15th of January 2007 (Mon) 11:55
Go-Karts milleker Motorsports 9 5th of September 2006 (Tue) 10:09
