Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 17th of December 2004 (Fri)   #1
gmitchel
User is banned from forums
Default Sepia Tone Quick & Easy
I use a twist on a B&W conversion technique to make sepia tone
images.
You use a pair of Hue/Saturation adjustment layers. The lower layer
is set to Color blend. The uper layer is left a Normal blend.
Instead of setting Saturation to -100 for the upper layer, you
instead set Hue to 50, Saturation to 20, and Lightness to +5. Voila,
a sepia tone.
You can make contrast adjustments to the lower layer. You can adjust
saturation and hue with adjustments to the upper layer. You can even
pick a different tone altogether.
http://www.thelightsrightstudio.com/.../2004DEC06.htm
I modified my TLRSepiaTone action set to use the technique, too.
http://www.thelightsrightstudio.com/...RSepiaTint.htm
Cheers,
Mitch
gmitchel is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lightroom sepia tone Bob Sherwood RAW, Post Processing and Printing 2 8th of April 2007 (Sun) 11:12
which one works? going for a sepia tone michael_ Critique Corner 7 20th of November 2006 (Mon) 09:09
quick & easy portable portrait light setup? Photorebel Small Flash and Studio Lighting 9 13th of June 2006 (Tue) 11:43
Sepia Tone Help Kristy RAW, Post Processing and Printing 3 25th of January 2006 (Wed) 10:40
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
