Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 30th of May 2008 (Fri)   #1
Zepher
Zepher's Avatar
Default Katana vs Alias
Bored in a hotel room and took a picture.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶______________________________________
Zepher is offline   Reply With Quote
Old 30th of May 2008 (Fri)   #2
jfc3po
Default Re: Katana vs Alias
DOF is too shallow....probably would have been better if both of the phones were in focus...
Canon 30D : EF 28mm 2.8 : EF 50mm 1.8 II : EF 85mm 1.8
Jimmy
http://flickr.com/photos/jfc3po1
jfc3po is offline   Reply With Quote
Old 30th of May 2008 (Fri)   #3
amonline
amonline's Avatar
The first thing you should always do when you get a lens is read the manual for the "minimum" focusing distance.
aLan
5DII x2, 15FE, 24L, 35L, 50L, 85L, 100M, 70-200L
amonline is offline   Reply With Quote
Old 30th of May 2008 (Fri)   #4
AV Mode
AV Mode's Avatar
I think the very shallow dof is what makes this composition interesting, I find this does have a pleasant look.
Cheers
AV Mode is offline   Reply With Quote
Old 31st of May 2008 (Sat)   #5
roentarre
roentarre's Avatar
Great control of DOF
http://www.mydailysomething.com
roentarre is offline   Reply With Quote
Old 31st of May 2008 (Sat)   #6
amonline
amonline's Avatar
You guys are completely missing the fact that the image is not even in focus. See my previous post. There is no DOF.
aLan
Old 1st of June 2008 (Sun)   #7
Zepher
Zepher's Avatar
The image is composed of a bracketed series of images (3 images, 1 stop a part). the focal point was the talk button and was shot at f/1.4 @ 50mm, which creates a very thin area that is in focus.
here are the 3 shots,
100% crop of Image #2
Manny Desantos
Old 1st of June 2008 (Sun)   #8
amonline
amonline's Avatar
Looks like you were too close. The minimum focusing distance of the lens is about 18 inches. Either that, or your RAW sharpening is set to zero. If you think you were over 18" and on a tripod [properly supported], that lens should be much sharper.
aLan
Old 1st of June 2008 (Sun)   #9
Zepher
Zepher's Avatar
It was hand held, shot in large jpeg. No color or contrast adjustments, just resized and aligned, then cropped. I was about 2-3 feet from the table sitting on the bed.
Manny Desantos
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Suzi Katana 1100 -another Carzee Transportation 2 27th of July 2006 (Thu) 03:10
Suzi Katana 1100 Carzee Transportation 6 23rd of July 2006 (Sun) 06:31
Alias Sydor25 Still Life, B/W & Experimental 9 24th of April 2005 (Sun) 17:54
