FORUMS Photo Sharing & Visual Enjoyment Wildlife
Thread started 22 Dec 2004 (Wednesday) 00:13
Prev/next
Can anyone help me identify this bug?
jwcdds
jwcdds's Avatar
Joined Aug 2004
Santa Monica, CA
Dec 22, 2004 00:13 |  #1
It's predominantly black (actually completely except for the wings). This one measured ~1/4", or 6-7mm, in length.
Here's a profile view:
IMAGE NOT FOUND IMAGE IS A REDIRECT OR MISSING!
Frontal view:
Back view:
I have absolutely no clue what it is. Looks like it has a neck leading up to the eyes and a very long feeder/mouth projection.
Thanks for looking. :)
Julian
shawnee_rebel
shawnee_rebel's Avatar
Joined Aug 2004
Pacific Northwest
Dec 23, 2004 09:05 |  #2
Would that be a garden assassin bug by chance? Just guessing here.
CyberDyneSystems
Admin (type T-2000)
CyberDyneSystems's Avatar
Gallery: 78 photos
Joined Apr 2003
Rhode Island USA
Dec 23, 2004 11:17 |  #3
It's a true "bug".. possibly a "coried bug", or more likely a "cone nose bug" or "kissing bug" or as Shawnee mentions.. assasin bug.
Common Name: Kissing bug, conenose bug, masked hunter
Scientific Name: Triatoma sp.
Order: Hemiptera
Description: These species appear similar and both occur in and around dwellings. Adults are 6/8 inch long, flattened insects with elongated, cone-shaped heads bearing a pair of five to six-segmented, elbowed antennae and a prominent "beak" (proboscis). The beak of Triatoma is more tapered, slender and straighter than that of Reduvius. Their bodies are dark brown to black, but the abdomen of the bloodsucking conenose is widened, with flattened sides sticking out beyond the margins of the wings and marked with six equally-spaced reddish-orange spots.
Bites of kissing bugs are occasionally misdiagnosed as "spider bites." The wheel bug, Arilus cristatus (Linnaeus), will also produce a painful bite if handled recklessly. Bed bugs, Cimex lectularius Linnaeus (Heteroptera: Cimicidae), also feed on human blood, but are not closely related to kissing bugs and are seldom encountered today. These bugs are wingless, grow to be about 1/4 inch long and have oval, flattened, brown bodies. The common bed bug, (C. lectularius Linnaeus) feeds on human blood, feeding at night and hiding during the day in cracks and crevices.
Life Cycle: In the Reduviidae, barrel-shaped eggs, some with ornate fringed caps, are deposited singly or in small clusters in areas frequented by females. Tiny wingless nymphal stages hatch in 8 to 30 days, depending on species and temperature. Nymphs develop through five (Reduvius) or eight (Triatoma) stages (instars) before becoming adults with fully-developed wings. The masked hunter overwinters as a partially developed nymph. Other species overwinter in the egg or adult stages. Generally, one generation is produced annually, although the bloodsucking conenose requires three years for development.
Habitat and Food Source(s), Damage: The mouthpart system (proboscis) is held bent back under the body when at rest. Piercing stylets are held within a sheath (labium). When feeding, articulation allows the proboscis to be pointed forward. Stylets can be extended beyond the end of the labial sheath into the blood meal host or insect prey. The masked hunter occurs in and around homes, entering homes to feed on bed bugs, Triatoma, and other insects. Adults are often attracted to lights. Nymphal stages "mask" their bodies by picking up debris such as dust and lint on their sticky bodies. The conenose bugs feed on blood of rats and other animals, including humans. They often live in nests of wood rats and other nesting rodents. Conenose and masked hunter bugs should be handled carefully.
Pest Status: Considered beneficial because they prey on insect pests; this and many reduviid species are medically important because they can "bite" with their sucking mouthparts. Species in the subfamily, Triatoma (also called conenoses or "kissing bugs" because of their habit of biting around the mouth), feed only on the blood of vertebrates. In southern Texas and southward, they can transmit the Chagas’ disease agent (Trypanosoma cruzi Chagas) among small animals, dogs and man. The bloodsucking conenose, Triatoma sanguisuga (LeConte), is also called the Mexican bed bug. During blood feeding, their bites are hardly felt by their hosts. However, bites, usually produced in self-defense, can be quite painful and can cause severe reactions in sensitive people, including burning, itching, swelling, red blotches, welts, rashes, fainting spells, nausea, diarrhea and anaphylactic reactions. Bites of the masked hunter, Reduvius personatus (Linnaeus), and other predatory assassin bugs can also be painful.
Common Name: Assassin bug
Scientific Name: Zelus renardii (Kolenati)
Order: Hemiptera
Description: Common species in cotton include the leafhopper assassin bug, Zelus renardii (Kolenati), and the spined assassin bug, Sinea diadema (Fabricius). In both species, the head supports a strong beak. The leafhopper assassin bug is about 1/2 inch long and red, brown to yellowish-green. The front legs have no spines and are covered with a sticky substance with which they catch their prey. The spined assassin bug is similar in size but is dark brown to dull red-brown, not bicolored. The front legs are slightly swollen and covered with spines. The abdominal margins are expanded and flat with a pale spot on the rear margin of each segment.
Life Cycle: Assassin bug females deposit masses of brown, cylindrical eggs periodically. Immature nymphs resemble adults but are wingless and develop through five molts (instars) into adults in about two months. Nymphs of the spined-shouldered assassin bug are distinctly swaybacked.
Habitat and Food Source(s), Damage: In cotton fields, assassin bugs prey on a broad range of prey including fleahoppers, lygus bugs, aphids, caterpillar eggs and larvae and boll weevils. They will also eat other predaceous insects such as lady beetles and big-eyed bugs.
Pest Status: Beneficial insects/natural enemies; predatory on insect eggs, larvae and adults; capable of biting.
just a guess.
CDS' HOT LINKS
9,757 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00129 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is dkiom
1019 guests, 484 members online
