Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 3rd of June 2008 (Tue)   #1
coolman23
Default Help with 100mm USM Macro mount
I borrowed a 100mm macro from a friend and can't get the thing to mount on my 20d. It sets in properly but won't turn or lock. Any ideas what the problem could be? Thanks.
coolman23 is offline   Reply With Quote
Old 3rd of June 2008 (Tue)   #2
Greg_C
Greg_C's Avatar
Default Re: Help with 100mm USM Macro mount
Make sure that none of the screws on the rear of the lens are loose. One could be causing this ..... maybe. It is a EOS mount lens isn't? (silly I know)
Oh. and welcome to POTN.
Greg
Blog | Photogallery | 1DmkIV + other stuff
Sanity is a madness put to good use.
Greg_C is offline   Reply With Quote
Old 3rd of June 2008 (Tue)   #3
SarahJD
SarahJD's Avatar
That was my first thought too -- is it a Canon mount?
Sarah
5D MKlll | 5D MKll | 15FE | 24L II l 35L | 45 TS | 50L | 85L II | 100 macro | 135L | 16-35L II | 24-70L | 70-200 2.8L IS | 580 EX II
SarahJD is offline   Reply With Quote
Old 3rd of June 2008 (Tue)   #4
coolman23
Hi,
Yes it's a Canon mount. I've been comparing this to my other lenses and for the life of me cannot see where the problem could be. Oh, and thanks for the welcome.
Old 3rd of June 2008 (Tue)   #5
snails
"I used the last of it to tip the strippers."
snails's Avatar
Check to see if one of your other lenses will mount on the camera.
If both lenses will not mount double check the body, I'd look for a stuck latch, friction springs or any physical damage.
If your lens fits and the 100mm doesn't, compare the mounting hardware between the mounting lens and the one that will not. I would be looking for loose screws, or physical damage.
Can you tell I'm an engineer?
Scott - www.scott-photo.com - gear list
Camera Bag Reviews - The Complete List
You don't want my advice.
snails is offline   Reply With Quote
Old 3rd of June 2008 (Tue)   #6
SarahJD
SarahJD's Avatar
I don't have any other ideas -- sorry. Let us know if you figure out the problem. And I forgot my manners -- WELCOME!
Sarah
Sarah
Old 3rd of June 2008 (Tue)   #7
coolman23
Well it must be something with the mount that's off although it sure isn't very noticeable to the naked eye (at least not mine). I found an old Rebel x film camera that had the plastic receiving mount and it was able to fit on that with some but not much resistance.
Anyway, it looks like now I need to go and buy my own - which isn't a bad thing.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: Tripod Mount Ring B for 100mm f/2.8 USM Macro Tixeon Classifieds: Buy 0 8th of July 2007 (Sun) 15:32
Canon Tripod Mount Ring B for 100mm f/2.8 USM Macro devil350 Canon EF and EF-S Lenses 11 1st of March 2007 (Thu) 10:58
Is the tripod mount ring really necessary for the Canon 100mm Macro? FlipsidE Canon EF and EF-S Lenses 8 24th of December 2006 (Sun) 10:49
20D - 100mm Macro and Tripod Mount. JohnW2607 Canon EF and EF-S Lenses 7 21st of January 2006 (Sat) 22:05
ring mount 100mm macro nino Canon EF and EF-S Lenses 11 31st of May 2005 (Tue) 14:30
