Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 4th of June 2008 (Wed)   #1
Flagpole
Question Advice on lighting set-up
Hi all!
I am planning to do some lingerie/nude shoots with my girlfriend some times in next few weeks. Since I haven't done anything like this before I was hopping that someone can help me out with some questions about the setup one can use for such a shoot at home. Here is the diagram of the room I am planning to use and the lighting set-up:
I am hopping someone can help me with some lighting ideas to create best possible lighting setup with limited means. I am not planning to hire any equipment and will use what I am planning to buy from the web (reflector+cheap tripod to mount the 2nd flash unit) and a couple of remote fired flashes (Nikon SB800&420EX). I am planning to bounce the flashes off the ceiling with diffusion domes attached. I also have a Lumiquest 80/20 which I can fit to the 420EX which is what I used in the past on it for my Canon PS G2. My main queries are below:
1. Is the above set-up an overkill or should this be adequate to create a very soft and diffused light? Should I just go with the ambient and a reflector?
2. Is there a better way to arrange the equipment I have?
3. Given that 420EX will only fire at full power off camera should I bounce it backward or just play with the distances until I can get the same power as with SB-800?
4. Would mirrors on the wardrobe present an extra difficulty?
5. Do I need to worry about any lighting ratios in the above setup? I assume I would have 4 light sources: ambient from the window, fill from reflector and 2 fills from the flash units.
6. Would a lighting meter or flash meter be of any use to balance the lights?
Any help would be greatly appreciated as I am trying to really get it sort out before trying it live
Flagpole
Sydney, Australia
G2, 420EX, Tiffen 0.75x & 2.0x, Lumiquest Pro Max
Flagpole is offline   Reply With Quote
Old 4th of June 2008 (Wed)   #2
tim
Light Bringer
tim's Avatar
Default Re: Advice on lighting set-up
If it's your first shoot of this type lighting probably won't be the biggest issue. Use window light, if it's dark simulate window light with a little fill from the other side.
tim is offline   Reply With Quote
Old 4th of June 2008 (Wed)   #3
Curtis N
Master Flasher
Curtis N's Avatar
Keep it simple.
Start with one light source, be that window or flash, then maybe add a reflector if needed. Play with extra lights only after you're comfortable with the single source.
You'll want to soften the flash somehow. This means creating a larger apparent light source. Consider umbrellas, or even a white sheet taped to the wall with the flash firing into it.
To use the 420EX (full power) in the mix, start with that unit (preferably bounced off something), meter for it, then add the SB-800 which you can adjust.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 5th of June 2008 (Thu)   #4
Flagpole
Thanks all for the replies. I think I'll go with the single light and possibly a reflecter. If those aren't enough I may throw the extra flash unit in. Will try to do some testing and metering before attempting the real shoot. Should be fun
Flagpole
Old 7th of June 2008 (Sat)   #5
sfaust
sfaust's Avatar
I would probably chuck the reflector and use a white bed sheet as a diffusion panel. Hang the bed sheet such that it acts as a large softbox at one corner of the bed. Some of the light go through the sheet and act as a soft diffused light similar to a softbox. The rest will bounce off it and head toward the wall behind it and bounce around the room as fill.
I would then use the 420EX as an accent and fill light. By that I mean I would position it off to the rear/sides, or directly behind your GF so that some of the light hits her directly and creates a highlight, hair light, or rim light. The flash should be pointed so some of it hits her directly, and some of it misses and heads forward of her toward the bed sheet, walls, ceiling, etc, for bounce/fill. You will need to make sure its hidden behind her from the cameras view.
With that setup, you should be able to get a soft diffused light on your GF, with some harder light as a rim or hair light. For the most part, the only light you will have to move around would be the 420EX to keep it hidden from the cameras view depending on your cameras position.
The 420EX will dictate the exposure since it will be full power as you mentioned. The SB800 should be adjusted to be within about a stop of the 420EX, either overexposed to subdue the effect of the 420EX, or underexposed to enhance it. If you can get access to the window, you can even put the 420EX outside the window, and reduce the SB800 about 2 stops to get the 'sun through the blinds' effect. The SB800 at 2 stops under that will give you a nice fill ratio to keep the shadows from blocking up.
I would also put another bed sheet in front of the mirror so it doesn't case you fits with direct light bouncing around. I'm surprised it wasn't mentioned already other then in your question. Yea, it can cause havoc if you let any direct light hit it.
If you want to keep it simple, use the sunlight from the windows which would be a nice effect by itself, and either use the reflector to create fill, or use the SB800 behind a sheet for diffused fill that you can dial up or down as you prefer.
A light meter would be a good help, but you can also dial in the the lighting on the LCD panel. To do this, start with the 'constant' that you can't change. In this case, that would be the sunlight if you decided to use that. Get the exposure dialed in for the effect you want on the sunlight, then start adding in the fill from the SB800 until you get the effect you want there.
You can also open the blinds all the way, then cover the window with a bed sheet and use that as a large softbox. Then use a reflector to add in fill, or use the SB800 as a hard light source for accent, hair light, rim lighting, etc.
Lots of ways you can approach this. I hope this gives you some ideas to kick around.
If you want to be a bit more adventurous, here is a creative way to use that mirror to create some interesting lighting with only a single strobe.
You can tape patterns on the mirror, then hit it with direct light from the strobe, and it will create shadow patterns on your scene or subject. For example, I use a small 2'x3' acrylic mirror for that purpose. I tape random shapes of black paper to it, then hit it with a hot light or strobe and bounce the light onto my scene. The area without paper show up as light, and the areas with paper are shadow.
Here is an example of it in use, but with a clear mylar sheet instead of a mirror. Same principle, but lighted through the mylar, rather than bouncing off it. You are seeing the back side of the tape which is actually black from the front. But the same principle applies. Note the interesting effect it has on the lighting on the wall. Position your subject to take best advantage of it, and you'll get some nice drama in your lighting and final image.
Here is the result of the above lighting. It could also have been done with a strobe, but I used hot lights since one was already setup. While a more advanced technique, its as simple as it gets as far as equipment: 1 light, sheet mylar, tape.
Stephen
Commercial Photography
My Photography Blog
sfaust is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best way to set up my lighting Woodja Small Flash and Studio Lighting 10 24th of April 2008 (Thu) 17:14
what set up for lighting widgetrich Small Flash and Studio Lighting 15 28th of December 2007 (Fri) 13:06
lighting set up help webejamn Small Flash and Studio Lighting 9 20th of March 2007 (Tue) 17:43
I need advice lighting up my set (with florescent lights) adifrank Small Flash and Studio Lighting 2 18th of May 2006 (Thu) 06:27
Lighting set-up for a newbie? Noni Small Flash and Studio Lighting 4 31st of May 2005 (Tue) 01:44
