Reply
Thread Tools Display Modes
Old 25th of December 2004 (Sat)   #1
Superbaldguy
Default Speedlite 220EX vs. Sunpak PZ40X
I'd like to get an external flash for my G6, but the 420EX and 550EX are simply too big and cumbersome. The G6 is the ultimate available-light digicam (with its fast f/2~f/3 aperture) and I rarely have use for a flash, anyway, except for fill work at close distances. If I have anything really important to shoot with a bigger bounce flash, I'll use my EOS film system and 540 EZ.
So, I'd like a smaller, throw-in-the-bag unit for those times when I'd like something morso than the dinky built-in flash. I like the 220EX as it will work with the Off-Camera Shoe Cord (I have two of those!), meaning I can get it off the camera, but it can't bounce; the Sunpak PZ40X has bounce.
What would you suggest? These flashes are about the same in cost. I assume you can dial in the flash exposure compensation with the 220EX.
Superbaldguy is offline   Reply With Quote
Old 27th of December 2004 (Mon)   #2
Superbaldguy
Default Re: Speedlite 220EX vs. Sunpak PZ40X
Another related issue is whether or not the Sunpak could be adjusted by the flash exposure compensation on the G6 (I doubt it). If not, I will stick with the Canon flash as this feature is invaluable for fill-in situations which is the main reason for having the smaller flash unit.
Old 30th of December 2004 (Thu)   #3
Superbaldguy
Opinions are in short supply on the Sunpak, anywhere, so I decided to get the 220EX. I didn't need a super-powerful flash unit, just one that could supplant the built-in one and provide adequate fill-in coverage at close distances.
I already have the 540EZ for my EOS film camera system, where I certainly need a unit with more power and flexibility
Old 30th of December 2004 (Thu)   #4
pradeep1
pradeep1's Avatar
Sorry SuperBaldGuy, I thought this was the same post as before where I could only offer you a meager opinion on battery and capacity.
I second your choice of using the 220EX for your stated purpose. I'd check the 540EZ out at this link if you have not already:
http://www.botzilla.com/photo/strobeVolts.html
But I don't think the 220EX will be able to use the G6's FEC, so that may be an issue for you. Check out this link:
http://eosdoc.com/manuals/flash/ETTLDx/
Pradeep Satyaprakash
Please view my portfolio.
pradeep1 is offline   Reply With Quote
Old 30th of December 2004 (Thu)   #5
Superbaldguy
No problem.
Too bad the 540EZ couldn't work on a digital camera.
Old 31st of December 2004 (Fri)   #6
figueira
Ok, it has no bounce... but you can bounce it if you are holding it off-camera with your hands or with a proper arm... and point it to the ceiling, walls, whatever....
figueira is offline   Reply With Quote
Old 31st of December 2004 (Fri)   #7
Superbaldguy
Yes, I could do that although its modest power would mean using higher ISO's.
The nice thing about the Canon Speedlites are the little touches - like auto power shutdown after 90 seconds and instant on if you touch the shutter release........
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
sunpak pz40x ll Spireite Small Flash and Studio Lighting 0 25th of December 2005 (Sun) 12:36
help with my speedlite 220ex davrosxuk Canon G-series Digital Cameras 1 6th of June 2005 (Mon) 08:25
Sunpak PZ40X or Canon 420ex Mogwyth Small Flash and Studio Lighting 2 13th of September 2004 (Mon) 19:23
