FORUMS Canon Cameras, Lenses & Accessories Small Compact Digitals by Canon
Thread started 10 Jun 2008 (Tuesday) 06:13
Prev/next
A650 vs SD950 w/ CHDK firmware
Sess
Jun 10, 2008 06:13 |  #1
I'm trying to decide between the A650external link and the SD950external link. From various reviews and a lot of comparing full resolution shots under identical conditions (reviews at www.imaging-resource.comexternal link) the overall quality of the two cameras is very close. So that just leaves the features. The A650 is bigger, heavier, more zoom, and manual features (Tv, Av, M, etc). The SD950 is slimmer, lighter, and uses a rechargeable Li-Ion battery.
However, using the CHDK firmware (http://chdk.wikia.com/​wiki/CHDKexternal link), shouldn't I be able to use every A650 feature on the SD950? Using CHDK, shouldn't I be able to use Tv, Av, bracketing, etc?
Assuming my understanding of CHDK is correct and that I would use it on either camera, what is the ultimate difference between these two cameras?
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 10, 2008 06:29 |  #2
At a minimum, CHDK won't compensate for the A650's greater zoom range or the flip-out LCD display. But as yet, CHDK doesn't support the SD950; in fact the situation's described as:
external link
Since the A650 uses the same OS and there is a version for that, I take this to mean that someone's applied themselves to the A650; someone (else?) could build on that to support the SD950, but as yet that hasn't happened successfully. If you go with the SD950 now, you will have the basic SD950 until such time as someone makes the port, and then you'll only get such features as they've enabled. If you get the A650, you'll get the P, Av, Tv and M which are built into the basic A650, plus all the CHDK features right from the start.
Jon
Cocker Spaniels
Sess
Jun 10, 2008 06:57 |  #3
Jon wrote in post #5694606external link
Thanks for the quick response. I didn't realize that particular camera wasn't supported yet. Well for the purposes of discussion, let's assume that someone will get CHDK working on the SD950, and that some of the obvious initial features would be Av, Tv, M, and bracketing. Under those conditions, and aside from the obvious things like the fold out screen and the additional zoom, what do you think would be the ultimate differences between the cameras? (If you haven't figured it out, I'm basically looking for an excuse to go with the smaller, lighter, fits in my pocket camera, but without sacrificing manual controls and image quality).
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 10, 2008 07:19 |  #4
Judging from the current writeup, enabling those modes isn't in anyone's plans. THere are functions that allow you to set a shutter speed, or an aperture, but I'm not clear that those functions will give you good exposures in a "fully automated" mode as the SD950's limited to, or that you'd be able to meter with the camera for full manual mode. In either case even if the functionality was there, you'd find it much more tedious to set Av, Tv or M shooting on the fly. If you really want those features, get the camera that offers them out of the box. If you think they might be nice to have but you're not really committed to using them, and someone gets a version running for the SD950, and you write some scripts to simplify the shutter speed selection process, the SD950 would offer that, but I'd be willing to bet that you'd quickly abandon efforts to set shutter speed/aperture or else move up to a camera that has them built-in. If you want manual controls and a smaller camera than the A650, look at the A720 or venture outside the Canon line.
Jon
Cocker Spaniels
Sess
Jun 10, 2008 07:45 |  #5
Well, usually I'd be using the camera in automatic. One fun thing I'd like to do is force the aperture wide open to blur out the background and have only my subject in focus.
But I really want to have some fun making HDR images. The easiest way to make HDR images is with auto bracketing (which neither camera has for some reason, but which is a highly customizable feature of CHDK). Even cameras that don't have exposure bracketing often allow adjustments around +/-2, but sometimes a larger range is beneficial and it's always nice if you don't have to touch the camera between exposures.
Generally, there isn't a lot of fiddling with the camera to do this. Once exposure bracketing is set up, you can just point and click (on a tripod of course). And of course it's not like I'd be doing HDRI all day long. That's really something you do when you notice a view that you just know would really look amazing with HDR processing. So even if it takes a bit of fiddling to get it going, I don't think it would be very prohibitive.
By the way, a lot of the information I've written hear is merely what I've gleaned from hours and hours of reading and what experience I've gotten using my old Canon A1, so it's very possible I'm horribly misunderstanding a few things.
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 10, 2008 08:15 |  #6
Don't expect too much DoF even wide open with either of these. Take a look at the On-line DoF Calculatorexternal link.
Jon
Cocker Spaniels
Sess
Jun 10, 2008 18:16 |  #7
Jon wrote in post #5695022external link
Using the appropriate circle of confusion and the actual focal length (not 35mm equiv.) as instructed at the site, it looks to me like the cameras could easily produce a very long or very short DoF.
Any opinions on my intention to use one of these cameras for HDRI?
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 10, 2008 18:27 |  #8
HDR, sure, just remember the noise factor of the small sensor. But DoF - we must have different definitions of shallow DoF. And you'll really be better off with the A650 regardless.
Jon
Cocker Spaniels
Sess
Jun 10, 2008 19:20 |  #9
Jon wrote in post #5698381external link
Well this is where I was trying to get. Judging from your own experience, you think I'll be better off with the A650 regardless. Now do you mean regardless of what I said about only needing manual controls on rare occasions (like for HDR etc) and usually sticking to automatic? If so, then why? Sorry if it seems like I keep asking the same questions, but I don't have the benefit of your experience so I'm just trying to get as much information as possible before I make a decision.
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 10, 2008 19:27 |  #10
I'm extremely dubious about your being able to set aperture or shutter speed and still get auto exposure on a camera that doesn't provide aperture and shutter priority. Why not get the camera that will give you those out of the box? My wife's never going to want to set aperture or shutter; she's got an SD600. I want that control available without setting 6 different settings; I have an A620 and an A630 for that.
Jon
Cocker Spaniels
Sess
Jun 11, 2008 15:35 |  #11
Jon wrote in post #5698697external link
It seems that this particular thread can't move forward until information about the actual capabilities of CHDK are made more clear. So I've read a lot there and posted a few questions on the forums. I'll post back here when I get some answers.
Sess
Jun 11, 2008 21:48 |  #12
Well I've gotten a lot of information and it looks like CHDK can indeed add features such as priority modes to cameras that didn't have them (as opposed to simply modifying or extending existing priority modes). More information is available in my thread: http://chdk.setepontos​.com/index.php/topic,1​671.0.htmlexternal link
RowdyReptile
RowdyReptile's Avatar
Jun 16, 2008 13:10 |  #13
Of course I'm used to the manual controls of my SLR but am looking for something compact I can always have with me. I was glad to see the Manual mode on the SD950 but am disappointed to realize it doesn't have Av and Tv modes. The manual modes it does have are shown here: http://www.steves-digicams.com ...iews/canon_sd950_pg​3.htmlexternal link
Still, I think I'm willing to give that up to get everything else offered in the SD950 package (at that size). It surprises me, then, that the SD950 offers RAW when the A650 doesn't.
Comparison here:
http://www.amazon.com ...4W&ASIN.3=B000V1VG2​E&bf=0external link
6D, 50D
24-105L, 50mm f/1.4, 100mm macro, 70-200 f/2.8L IS, Rokinon 8mm fisheye, 10-22mm, Speedlite 580EX II (2). Flickrexternal link
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 16, 2008 15:17 |  #14
That Amazon comparison is incorrect. Neither offer RAW. The A650 accepts the CHDK hack which gives you a form of RAW; the SD950 doesn't, as yet. Without a hack, you'll have no direct control over the shutter speed or aperture on an SD950. All you'll be able to do to control exposure are set ISO and EC.
Jon
Cocker Spaniels
RowdyReptile
Jun 16, 2008 15:44 |  #15
Jon wrote in post #5732582external link
Ok, thanks. Should have known. But then I see the CNET review dings the SD950 for sluggish performance:
http://reviews.cnet.co​m ...91168.html?tag=prod​.txt.1external link
6D, 50D
5,758 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.0034 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is sorrentino
842 guests, 395 members online
