Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 12th of June 2008 (Thu)   #1
Ryan W
Default Wacom light Blinking
Okay ...
I've installed all the drivers for the Wacom Bamboo and when it's plugged in all it does is flash (quite slowly) It works so well on my laptop I love it
I phoned Wacom and they said maybe it's not getting enough power from the USB ... so I've tried them all now and none work :S
I run external hard drivs and stuff off the USB's and they all work fine :S ?
Any ideas ?
Canon 400D (XTi), Sigma 24-70 2.8 (LOVE IT!), 18-55mm f/3.5-5.6 kit lens, 50mm f/1.8 Nifty 50, 90-300 mm cheapo! And a new Metz AF-4C Flashgun Woooo.
And a passion for photography.
www.rtwphotography.wordpress.com
Ryan W is offline   Reply With Quote
Old 12th of June 2008 (Thu)   #2
Stocky
Stocky's Avatar
Default Re: Wacom light Blinking
how about a powered USB hub?
Stocky is offline   Reply With Quote
Old 12th of June 2008 (Thu)   #3
Ryan W
I dont know what that is ... but I'll check around for one thank you very very much
Old 12th of June 2008 (Thu)   #4
Ryan W
Do you think this would be okay?
http://www.aria.co.uk/Products/Compo...roductId=22173
Old 13th of June 2008 (Fri)   #5
Stocky
Stocky's Avatar
That should be fine. I have used a variety of name brand and knock off USB products and the biggest difference is how long they last. If you aren't going to be plugging and unplugging your tablet all of the time then a cheap one should be fine.
Old 20th of June 2008 (Fri)   #6
Ryan W
Urgh! Mine came this morning ... All excited! Then it just did the same thing again! I'm getting very pee'd off now!
Any sugestions?
This is the message I get ...?
Old 20th of June 2008 (Fri)   #7
Bobster
Bobster's Avatar
have you tried it with all other USB devices unplugged?
Robert Whetton Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood | Gear | Tweet | Google+ | Get your focus spot on
Bobster is offline   Reply With Quote
Old 20th of June 2008 (Fri)   #8
Ryan W
Nope ... Will now though ...
Old 20th of June 2008 (Fri)   #9
Ryan W
No difference ... Accept the found New Hardware thing has stopp comming up altogether now :s and instead of making the 'du du' it goes ... 'du du du' (real quick)?
Old 20th of June 2008 (Fri)   #10
Bobster
Bobster's Avatar
do you have another machine you can try it on?
Old 21st of June 2008 (Sat)   #11
Ryan W
Sorry yeah - It works perfectly on my laptop ...
Right ... I just trieda new USB Mouse (been using an old one for a while) and the same message was coming up on that to (Data Invalid) ?
Thanks for all your help
Old 21st of June 2008 (Sat)   #12
Colorblinded
Colorblinded's Avatar
That triple "du du du" usually means there's an error with the device setup. Have you tried uninstalling the software (and drivers) if there is any and reinstalling it? Does the tablet show up in the hardware manager?
Colorblinded is offline   Reply With Quote
Old 21st of June 2008 (Sat)   #13
Ryan W
Hardare manager? How do I look at that? lol
thanks! Ryan
Old 21st of June 2008 (Sat)   #14
Ryan W
Deleted the Driver and Programs and reinstalled the driver, then it said there was a problem and to restart did that and still nothing ...
Here's what my Device manager looks like ...
Old 22nd of June 2008 (Sun)   #15
Ryan W
Any ideas?
Cheers
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon 430ex flash in slave mode - blinking red light? rherdman Small Flash and Studio Lighting 5 28th of February 2008 (Thu) 12:52
24-105 what is blinking green light at f4? sharp8888 Canon EF and EF-S Lenses 4 25th of January 2008 (Fri) 23:05
Blinking? victoria General Photography Talk 19 23rd of April 2007 (Mon) 21:17
Blinking 4.0 to Blinking 29 Just by Turning On Flash dphoto Canon EOS Digital Cameras 0 26th of September 2004 (Sun) 16:13
Battery Charger Light - Blinking Red/Green pdass Small Compact Digitals by Canon 1 24th of August 2003 (Sun) 14:17
