Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 28th of December 2004 (Tue)   #1
CDickinson
Default three eggs
Photographer friend of mine gave me an assignment a while ago - shoot eggs on a white plate on a white background. Well, having shot those eggs for weeks on end, I started playing around with them in PS. Intention was to introduce different elements inside the eggs or appearing to be inside the eggs or on the surface. And to see if I could get blending two images down to some kind of dull roar....
One shot.
Comments welcome, of course!
"Consulting the rules of composition before taking a photograph, is like consulting the laws of gravity before going for a walk" - Edward Weston
CDickinson is offline   Reply With Quote
Old 15th of January 2005 (Sat)   #2
wolffmale
Default Re: three eggs
great shot Very Moving...
wolffmale is offline   Reply With Quote
Old 15th of January 2005 (Sat)   #3
Qweevox
Qweevox's Avatar
Great picture! I'd like to see more and read how you did it.
Qweevox is offline   Reply With Quote
Old 16th of January 2005 (Sun)   #4
CDickinson
Thanks for the comments!
The photo is two shots - three eggs on a black plate...side lighting and a flash bounced off the ceiling. Second shot is leaves on maple this fall.
What I did was first made a copy layer of the eggs and discarded the background layer.
I added a second layer of the leaves and changed blending mode from normal to overlay then adjusted the percentage of opacity till the leaves were showing through less and the eggs stood out more. I brushed out areas of the leaves layer that were distracting - ie, I erased anything on the layer that was outside the edges of the eggs. I then used select color to intensify the yellows and blues.
Next I added a duplicate layer of the eggs and moved it on top of the leaves. Changed the blending mode to pin light and adjusted levels and select colors of white and black. This layer acted as a defining layer of the edges and white and deepened the black.
I went back to the leaves layer - once the eggs were defined, and adjusted again with burning and dodging areas of the leaves. I also blurred etc.
I saved this photo in layers in case I want to alter it again.
Then I flattened the image and saved that because I went in again at this poing and cloned black areas around the back edges of the eggs because the eggs were too assymetrical.
I'll post a few more egg shots because I actually worked four or five different image into the same shot of the eggs.
C
Old 17th of January 2005 (Mon)   #5
CDickinson
Ok. Two more shots of the eggs. Same techniques.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Everywhere Eggs! KloessJ Birds 5 25th of June 2007 (Mon) 11:43
Anyone know what these are? eggs maybe skylab Macro 8 22nd of June 2007 (Fri) 01:44
Eggs, anyone? Pastafarian Still Life, B/W & Experimental 9 12th of November 2006 (Sun) 14:15
Eggs glowie People 4 22nd of October 2006 (Sun) 07:26
Eggs...... CDickinson Critique Corner 4 19th of September 2004 (Sun) 15:33
