Thread started 15 Jun 2008 (Sunday) 01:33
remote camera setup examples anyone?
michael_
Jun 15, 2008 01:33 |  #1
ive got a gig in a few months and it will require the use of a remote camera setup to get as many shots as possible (its a car rally), i have the basic idea but wouldnt mind seeing others setups and eq and accessories required.
I have the following
2 x MarkIIIs
3 x PW IIs
will be getting one of these http://www.overxposed.​com/oxproplatform.html (external link) for the remote camera
now what other eq/accessories/cords wll i need to remotely trigger the 2nd camera either when i fire the main camera ie the same time or a few seconds later, ie i might be standing 100m away from the remote camera and want it to trigger as the vehicle goes past not 100m away or visa versa.
i am of the impression setting the remote camera to manual focus at fairly narrow apertureand or based on the hyoerfocal distance figures.
any help, links images would be great.
ichael ... (external link)
vettas media (external link) (me) | myGear (all my equipment) | sportshooter (external link) (my sportsshooter member page)
michael_
Jun 15, 2008 17:14 |  #2
interesting
Dan ­ Lorth
Jun 15, 2008 17:26 |  #3
I have heard, and mind you this is what I have heard, but I have heard that the PW IIs dont fire in continuous burst when used as a remote. It does fire single frames but does not work with continuous drive. You are on the right track with the base and the equipment, but it sounds like you should invest in some multimaxes to get what you want to do (drive mode and enable firing a few seconds after your main). Good luck, Id love to see the results if possible. I love remote cameras and Im very interested in them.
PacAce
Joined Feb 2003
Jun 15, 2008 18:32 |  #4
Dan Lorth wrote in post #5726997 (external link)
The reason the PW II (and the MutliMax for that matter) can not fire in continuous burst mode is not because they can't do it (because then can) but because the main camera triggering the remote camera is firing the transmitter in single shot mode (remember, the thing that's triggering the transmitter is the sync signal from the camera, the same signal which is used to fire a flash. If you pressed and held down the Test button on the transmitter, the remote camera will fire in burst mode as long as you keep the Test button held down (and assuming that the remote camera is in continuous frame mode).
...Leo
PacAce
Joined Feb 2003
Jun 15, 2008 18:37 |  #5
CIDER wrote in post #5724068 (external link)
2 x MarkIIIs
3 x PW IIs
I'm not exactly sure what kind of info you're looking for other than what you've already mentioned. What you posted is basically what I would do, too.
The only comment I can add relates to your desire to fire the remote camera after a delay of a few seconds. Unfortunately, that will not be possible with just the PW Plus II units. You'll need at least one MultiMax to serve as either a transmitter or a receiver in order the program in the delay time you want.
I'm assuming the you already have a remote release cable to connect the PW unit to the remote camera. If not, that's one of the key components required to make remote shooting possible.
...Leo
Dan ­ Lorth
Jun 15, 2008 18:44 |  #6
PacAce wrote in post #5727256 (external link)
thank you for the correction!
michael_
Jun 15, 2008 19:34 |  #7
PacAce wrote in post #5727273 (external link)
i dont have the cable, there seem to be a few different options on the PW site, so the only thing i can do with just the PWIIs is have the remote camera fire at the same time as the main camera?
PacAce
Joined Feb 2003
Jun 15, 2008 21:22 |  #8
CIDER wrote in post #5727546 (external link)
Yes, assuming that you have the remote release cable, with the PW Plus II units you will only be able to fire the remote camera at the same time the main camera fires off a shot.
...Leo
michael_
Jun 15, 2008 21:33 |  #9
so which do i need?
http://www.bhphotovide​o.com …ails&Q=&sku=198​050&is=REG (external link)
or
http://www.bhphotovide​o.com …ails&Q=&sku=198​049&is=REG (external link)
and is that all? then at a multimax to trigger seperately
PhotosGuy
Moderator
Joined Feb 2004
Jun 15, 2008 21:38 |  #10
There might be something helpful in the "Similar Threads" links at the bottom-left of this page, too.
PacAce
Joined Feb 2003
Jun 15, 2008 21:42 |  #11
CIDER wrote in post #5728169 (external link)
so which do i need?
or
You need the second one (the one with the N3 terminal on it) or something similar from another source.
...Leo
michael_
Jun 15, 2008 21:50 |  #12
cheers frank and leo
frank i tried searching before i started the thread and nothig cae up, weird.
PhotosGuy
Moderator
Joined Feb 2004
Jun 16, 2008 08:51 |  #13
Advanced search?
If you do a "Advanced" forum KEYWORD search in "Search Titles Only" for KEYWORD(s), you will find a lot of help.
Be sure and select the relevant area in the Search in Forum(s) fields.
If you do a "Advanced" forum KEYWORD search in "Search Titles Only" for a phrase in "KEYWORD(s)" with the quotes if it's a logical progression of words, (like +"depth of field") you will find a lot of help. This will put the threads that contain both at the top of the list, with threads that have one word or the other lower down.
Try it without the quotes for less related things like quartz temperature
johnms88
Jun 16, 2008 11:16 |  #14
Could you just hold the PW and hold down the test button when you wanted the shot? Sorry, but that seems too obvious for it to actually work...lol.
1Dmk2n:16-35L:24-70L:Sigma 70-200: 85 1.8 : 50 1.8: www.stuiephoto.com (external link)http://photography-on-the.net/forum/showthre​ad.php?t=776396
primoz
POTN Sports Photographer of the year 2005
Joined Dec 2004
Jun 16, 2008 15:20 as a reply to  @ PacAce's post |  #15
This actually makes sense, but in reality remote still works on 8fps even when PW is set in hotshoe of handhold camera. It might send trigger signals one by one, but main point is, that it works :)
PhotoSI (external link) | Latest sport photos (external link)http://www.photo.si (external link)
2,964 views & 0 likes for this thread
version 2.0 /
Latest registered member is Summers
670 guests, 294 members online
