#1 |
Is there any way to tell how many images were taken on a previously
used G9? My wife and I picked one up today that looks nearly spotless, but the first image from the SD card came back out as img_5569.cr2 I was wondering if there was a hardware counter mode I could look at that would tell me if this is just a continuation from one of our previous SD cards, or if the other owner had a field day... ? |
| sponsored links |
#2 |
No user accessable shutter count. If you use a card which has a higher image and folder number than the camera has known, it will use the higher number from the disk to start counting its images. It will always use the higher number, either from the disk or last known from camera.
#3 |
Check out this: http://chdk.wikia.com/wiki/G9
| sponsored links |
#4 |
I started a thread a week or so ago to ask the question "Is it possible to speify the starting point (or current numbering point)?"
Got a great answer: http://photography-on-the.net/forum/...d.php?t=514813 That doesn't help with your original question about true shutter count, but it's interesting info if you ever need to change the sequence. |
| Thread Tools | |
| Display Modes | |
| Image counter number | Colyn | Canon EOS Digital Cameras | 8 | 4th of January 2008 (Fri) 03:37 |
| CF card image counter | enerdream | Canon EOS Digital Cameras | 5 | 29th of November 2007 (Thu) 21:51 |
| eos image counter | wmotis | Canon EF and EF-S Lenses | 2 | 3rd of May 2007 (Thu) 23:23 |
| Image counter | canon shooter | Canon EOS Digital Cameras | 2 | 25th of November 2005 (Fri) 14:42 |
| Resetting Image Counter | DAVE THE SLAVE | Canon G-series Digital Cameras | 1 | 30th of October 2003 (Thu) 20:12 |
