Thread started 15 Jun 2008 (Sunday) 11:01
Prev/next
what causes the blue haze and how to prevent it?
rx7speed
Jun 15, 2008 11:01 |  #1
I've noticed when taking some nature shots of something off in the distance I usually get this blue haze that ends up comming between me and the subject how is it one gets to cut through that?
digital: 7d 70-200L 2.8 IS MKII, 17-55 2.8 IS
eddarr
There's Moderators under there....
eddarr's Avatar
Las Vegas
Jun 15, 2008 11:33 |  #2
It's just stuff in the air catching light waves. You can use a quality UV filter on the lens to help remove the haze.
Eric
primoz
POTN Sports Photographer of the year 2005
primoz's Avatar
Joined Dec 2004
Anywhere where ski World cup makes its stop
Jun 15, 2008 13:10 |  #3
Easiest way to eliminate there is to choose right timing. If you are shooting wide open spaces like Grand Canyon for example in middle of summer when it's +35c, then you will have it. If you come on cold(er) day, after some storm, when air is clean, you won't have this.
So only real option is to take such photos when it's right weather. Yes I know, it's damm hard to do this, when you are on holidays, and you have just one day to spend on location. But unfortunately that's reason why 99.9% of great landscape photos are done when people invest A LOT of time into one single photo.
PhotoSIexternal link | Latest sport photosexternal linkhttp://www.photo.siexternal link
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Jun 15, 2008 21:50 |  #4
You might notice less haze in the early morning, which can also give you some nice side light.
New Image Size Limits: Image must not exceed 1280 pixels on any side.
Double ­ Negative
*sniffles*
Double Negative's Avatar
New York, USA
Jun 16, 2008 11:53 |  #5
Other than waiting for better weather (and thus atmospheric conditions) a UV filter will help a little bit. A circular polarizer will probably help more. Other than that, you're at the weather's mercy. Getting there early in the morning will help some as the air is cooler and should have less humidity as well.
La Vida Leica!external linkLitPixel Galleriesexternal link -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
WaltA
WaltA's Avatar
Joined Feb 2006
White Rock, BC, Canada
Jun 16, 2008 12:23 |  #6
Yeah, I'd suggest the Circular Polarizer as well. Had a bright sunny morning here at the beach but as soon as the sun got above the mountains we got a blue haze over the water.
I experimated with a number of filters (UV/HAZE etc) and got mediocre results. Then I put the CP on and took shots with it turned various ways and it did a presentable job of getting rid of the haze. At least better then the other filters.
Walt
400D, 5D, 7D and a bag of stuff
rx7speed
Jun 16, 2008 12:27 |  #7
have a UV filter though it is a cheapy at best. the ol' canon uv-1 I think it is. seems to do nothing I just prefer it cause I would rather clean/scratch/damage that then the real lens. the circular polerizer didn't seem to do much on that.
the other question I have is would any color correcting filters help reduce the haze at all?
and other then that just early rise, cool, dry weather is best right?
Double ­ Negative
*sniffles*
New York, USA
Jun 16, 2008 12:53 |  #8
UV filters help in some cases, like at the beach or up in the mountains - though this is largely only true with film. Most digital cameras block UV at the sensor, making a UV relatively pointless, save for protection purposes. So you probably won't see any difference.
Color correcting filters will only change the color of the haze.  :p
Tee ­ Why
"Monkey's uncle"
Tee Why's Avatar
Joined Feb 2006
Pasadena, CA
Jun 17, 2008 00:49 |  #9
Take a few shots without the UV filter and see if that makes a difference. I think some skylight filters can cause a blue color cast.
Upload a typical example you are seeing here so we can see as well.
Gallery: http://tomyi.smugmug.c​om/external link
Double ­ Negative
*sniffles*
New York, USA
Jun 17, 2008 06:16 |  #10
^ That's weird, because skylight filters are warm-toned.
DrPablo
DrPablo's Avatar
North Carolina
Jun 17, 2008 07:21 |  #11
Double Negative wrote in post #5731653external link
Yes and no! Haze is caused mostly by scatter of visible blue light (and to a much lesser degree UV light). The scatter is caused by suspended particles or water in the air.
It's very well known that filters that block blue light will increase sharpness and decrease haze. Ansel Adams has some great examples of this in The Negative, with some extreme examples using IR film and IR pass filters.
So using an orange #23 filter or a red #25 or even a yellow #15 will dramatically sharpen the image, because the scattered blue light is blocked.
Yes, this will indeed change the color of a color picture. But you could consider taking two photos on the tripod -- one with no filter and then another with a filter like a red #25. Then take the image shot with the red #25, desaturate it (no need to do channel mixer), adjust the levels and contrast, and copy it to the clipboard. Then take the full color image, paste the B&W image on top, and set the blending mode to Luminosity. (Alternatively, perhaps better, you could convert the color image to LAB colorspace, go to Channels, select the Lightness channel, and paste the B&W image over this channel).
This takes the sharpness from a red-filtered shot and uses that image as a tone map. So the detail and sharpness will come from that shot, the color will come from the full color shot. The distant detail will still look 'blue' unless you color-correct it, but at least you'll rescue some detail.
Canon 5D Mark IV, 24-105L II, 17 TS-E f/4L, MPE 65, Sigma 50 f/1.4, Sigma 85 f/1.4, 100 f/2.8L, 135 f/2L, 70-200 f/4L, 400 L
Film gear: Agfa 8x10, Cambo 4x5, Noblex 150, Hasselblad 500 C/M
Double ­ Negative
*sniffles*
New York, USA
Jun 17, 2008 08:16 |  #12
^ That's an excellent explanation and you're totally right. I guess I oversimplified my statement a bit, heh. Blocking the blue light and layering like that would definitely bring out some otherwise lost details.
I'll have to try that next time I'm out. I was shooting with the 300mm f/2.8L IS and 1.4x/2x over the weekend and the haze was insane. I haven't prepared/purchased any filters for it yet - on distant shots the haze really showed (click for larger/info):
IMAGE: http://litpixel.com/ee/images/thumb/_1D_3414.jpg
[IMAGE'S LINK: http://litpixel.com ...=34&ee_lang=eng&u=1​682,12] (external link)
DrPablo
DrPablo's Avatar
North Carolina
Jun 17, 2008 10:32 |  #13
You might go cheap and get a gel filter kit, like from Lee. I use 4x4 inch filters for my large format lenses, and the kit isn't very expensive -- one kit (which you can order from B&H or Calumet) comes with a yellow/green #8, a yellow #11, an orange #15, and a red #23, and it comes with a plastic filter holder. The only trick is keeping the filters free of scratches. That would certainly be cheaper than finding a filter to fit a monster like the 300/2.8.
Double ­ Negative
*sniffles*
New York, USA
Jun 17, 2008 10:38 |  #14
^ Yes, but there's no way to use those 4x4 filters on the 300/2.8. ;)
The best I can do is cut some gels myself from a Rosco pack (which I'll very likely do) and pick up a Canon 52mm Drop-In Circular Polarizer PL-C.
DrPablo
DrPablo's Avatar
North Carolina
Jun 17, 2008 10:47 as a reply to Double Negative's post |  #15
Whoa, that front element is 5" -- that's even more than my Schneider 90/5.6 Super Angulon XL, which takes 105mm filters.
You're right, a Rosco gel would work. You could also check KEH for used 5" filters, because they do exist.
For these purposes I'd probably err on the side of a #11 or #15 filter rather than a very dark red one. A yellow #15 works nicely for routine haze. I don't know if it would work to shoot a neutral gray target to color balance after shooting through a color filter -- but if so, I'd probably stay away from something like a red #25 or #29, i.e. something that blocks everything shorter than ~ 650 nm wavelength. You're more likely to have recoverable color if you're just blocking blue.
6,000 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00249 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is cjp1997
895 guests, 479 members online
