#1 |
Usually when I double clicked on a JPEG in Bridge, it would automatically open up in CS3. Now when I double click on one, it opens up in MS Paint. I've been searching through all the menus and couldn't find an option to set this back to how it was before.
Any help would be appreciated. |
| sponsored links |
#2 |
Start Bridge and go to Edit > Preferences > File Type Associations.
Scroll through the window on the right until you get to the JPEG file type. In the column next to the file type, it should show the application currently assigned to open that file format. To change it, click the small arrowhead on the right of the JPEG line and from the pop-up context menu, select Adobe Photoshop CS3. You can also change it from Windows but its a little more involved that way. |
#3 |
Back to normal again now. Thanks!
| sponsored links |
#4 |
Hello, does anybody know if I can post my own threads? I am new to the site.
My question is: In the bottom of Bridge, it will say how many images I have in a specific folder and than is says that I have "hidden files". What are hidden files and how can I see them? Are they images that I have edited and might need? I haven't been able to figure it out! |
#5 |
Just click on Forum Tools to open the drop down menu and select Post New Thread. From where you are reading this, you will only find thread tools. Go back to the main forum for this topic and you will see the Forum Tools.
"If you're not living on the edge. You're taking up too much room !" My Gear Arizona's POTN Flickr Gallery Last edited by Az2Africa : 21st of June 2008 (Sat) at 01:18. |
#6 | |
It wouldn't be image files because Bridge would display all the images that are in formats that it recognizes; which is practically all images. Most likely when you see the "hidden files" message, its in folders containing edited RAW files and Bridge is indicating that there are also XMP sidecar files containing the editing instructions for the RAW files in the folder.
If you want to see the hidden files use your file manager - Windows Explorer or Finder - to navigate to the folder and examine its contents. You can also right-click on any image thumbnail and select "Reveal in Explorer" or "Reveal in Finder" from the pop-up context menu. Quote:
#7 |
Perfect! That makes perfect sense! Thanks so much.
| Thread Tools | |
| Display Modes | |
| Adobe BRIDGE - problem with fly-out menu | b.d.bop | RAW, Post Processing and Printing | 0 | 9th of March 2008 (Sun) 11:32 |
| Problem with Adobe Bridge? Help? | Ferco | RAW, Post Processing and Printing | 15 | 29th of January 2008 (Tue) 22:04 |
| How to disable Adobe Bridge and Adobe Downloader | Kagemaru | RAW, Post Processing and Printing | 3 | 3rd of October 2007 (Wed) 23:47 |
| apple Aperture Vs. Adobe DNG & Adobe Bridge | offtheroad | RAW, Post Processing and Printing | 1 | 29th of January 2007 (Mon) 17:50 |
| Adobe bridge problem | J.A.F. Doorhof | RAW, Post Processing and Printing | 7 | 21st of July 2005 (Thu) 01:11 |
