Thread started 16 Jun 2008 (Monday) 21:21
Help with exposing
thaking
Jun 16, 2008 21:21 |  #1
Long time reader, first time poster...
I have read about using multiple images so that you can combine them into one image, like hdr...in many of these discussions they talk about exposing the sky properly in one image and exposing for the rest in another...I had borrowed a friends 16-35L and went to a going away party that was outside, under a shelter...of course there were shadows all over their faces...I could not figure out how to expose for the shadows...all the images seem to be exposed for the sunlight...
How would I properly expose for the shadowed areas?
Any tips would be greatly appreciated...
kniteshade
Jun 16, 2008 22:02 |  #2
If the rest of the image looked correct (exposure-wise), but you just had shadows on the faces, then what you probably want is fill-flash.
If the entire image was too-dark, then try the different metering modes. Spot meter on a face if the camera supports it, or try partial metering. The * button on the camera (by default) is the AE-Lock button, so you point the camera at what you want exposed correctly then lock the exposure, recompose, then take the photo.
Another solution is to use exposure-bracketing to take 3 shots, and hope one of them is correct.
400D+grip / Tamron 17-50 f2.8 / 50 f1.4 / 18-55 Kit / 75-300 Kit
Souwalker
Jun 16, 2008 22:08 |  #3
kniteshade wrote in post #5734751 (external link)
Even the 40D?
Pat
kniteshade
Jun 17, 2008 03:10 as a reply to  @ Souwalker's post |  #4
Im pretty sure that what the * icon represents on the canons (AE lock)
From the 40D review on dpreview:
* AE / FE Lock
Press to trigger automatic exposure and lock the exposure for the next shot. Hold the button to lock the exposure for more than one shot.
PhotosGuy
Moderator
Joined Feb 2004
Jun 17, 2008 08:28 |  #5
Posting an image for us to see would help a lot. It's also hard to give an answer as I don't know how much you're willing to learn.
Here's why: Post #47
My solution: Try manual in those tough conditions. First set the f-stop & shutter speed you need. Then adjust the ISO. Need an exposure crutch?
Other results: Angeline outdoors
thaking
Jun 17, 2008 14:05 as a reply to  @ PhotosGuy's post |  #6
I knew I should've posted a sample :-)
I took the photos off the card last night and only got a glance at them, posted my question and went to bed. I'll definitely post a sample later as this is something I've struggled with for a while...thanks for the assistance...
lilpacheco
Jun 17, 2008 14:40 |  #7
Are you working in the auto mode? That might explain it because you don't have much control with that. I suggest shooting in AV or manual (if don't know how to use these I suggest buying a book or research on the internet) and turning on your flash for fill flash. If you are still getting shadows on faces, pump up the flash for more light to fill in the shadows. Also shoot in RAW and that can add some light to faces after the fact as well (in PP).
Robyn :)
Canon 5D, 70-200 mm f/2.8L, 24-105 mm f/4L, 580EXII
www.robynpacheco.blogs​pot.com (external link)
http://img.photobucket​.com …o/yogurthead2_r​educed.jpg (external link)
OdiN1701
Jun 17, 2008 15:34 |  #8
Heh....just imagine reading the thread title on any forum other than a photography forum :P
SAY NO TO SPEC WORK! (external link)
40D w/ Grip |
20D w/ Grip | 10D
10-22mm|17-40f/4L|24-105f/4LIS|70-200f/2.8LIS|50f/1.4|100f/2.8Macro
chauncey
Jun 17, 2008 17:09 as a reply to  @ OdiN1701's post |  #9
Andrew is a very bad boy. :lol:
thaking
Jun 17, 2008 20:55 |  #10
ok, here is a quick photo sample...no PP, just resized....shot RAW Av, used center AF, AWB, ISO 100....i focused the subject and i assumed that since i was focusing on a subject in the shaded area, the WB would be adjusted as so, but maybe i'm not correct....i know i need a flash, planning on getting one but don't have one at the moment...
@OdiN1701: i thought the same thing about my title after i searched for it today to see what responses i've received...couldn't i come up with a better title? :oops:
PhotosGuy
Moderator
Joined Feb 2004
Jun 18, 2008 09:06 |  #11
The WB looks OK. It's the metering that did you in & the links I gave you should help.
You should be able to pull better detail out of a RAW file.
thaking
Jun 18, 2008 20:12 |  #12
PhotosGuy wrote in post #5744761 (external link)
The WB looks OK. It's the metering that did you in & the links I gave you should help. You should be able to pull better detail out of a RAW file.
that's why i shoot raw, but i was hoping to do take better shots, thus reducing PP...after reading post #47 (linked above) let me see if i understand this correctly...it says "where you point the camera influences the meter reading"...when i focused the shot i focused on the female looking towards the camera laughing...then i repositioned the camera (raised it higher, thus bringing in more light)...do you think this is what caused my issue? meaning, even though i initially took my reading on her, because i recentered the camera allowing more light, the camera adjusted and thus they are darker...
if that is true, then i will go back to my original question - if i want to combine 2 images where one is exposed for the sky and one for the foreground, then what is the correct way to do this? take my sample image for example...if i could do it over (2 shots, 1 for the sky and 1 for their faces) how should i do it?
SkipD
Joined Dec 2002
Jun 18, 2008 20:17 |  #13
thaking wrote in post #5741646 (external link)
You could probably not use HDR in a situation like the shot you posted. It's quite likely that there would be too much subject motion between shots to be able to properly overlay the images.
A good flash unit (NOT a flash built into a camera) would go a long way toward making that sort of shot much better.
Skip Douglas
thaking
Jun 18, 2008 21:19 |  #14
thanks SkipD...yeah i am planning on buying a 430 ex soon, just don't have one yet...also, i was not wanting to use the posted pic as an HDR, all i was saying was to use this as an example - top portion (sky) is bright, bottom portion (foreground) is darker...how to properly expose for both...some have suggested taking 2 shots and combining them...to do that, i would need to properly expose for the sky and properly expose for the foreground...if i understood how to do that, then i would understand how to retake the photo above and expose it properly...
hopefully that makes sense....
PhotosGuy
Moderator
Joined Feb 2004
Jun 19, 2008 09:45 |  #15
Yes.
Tripod, BUT you can't expect that she won't move, so I'd make two different conversions in RAW & blend them.
Easier for you would be to use the mask in an Adjustment Layer if you have PS.
Post #9:
Airport runway shoot
Simplest, would be to expose for her & let the sky blow out, or find an angle where you don't see the sky at all.
1,678 views & 0 likes for this thread
Help with exposing
version 2.0 /
Latest registered member is Nidge
705 guests, 392 members online
