Reply
Thread Tools Display Modes
Old 4th of July 2001 (Wed)   #1
Grant Dixon
Default Solution found to red shift in G1
Just recently I was photographing a extreme red Geranium and got a very bad colour shift to the blue. Well is slept on this problem and the next day I decided to check the White Balance Setting. I photographed the same plant first in AWB then cascaded down through all the colour options. The day was cloudy and surprise of surprises the colour was tack on in the "Cloudy" setting, but still terrible on AWB.
So the conclusion I have come to is that with a very strong predominance of red the AWB is being thrown off toward the blue. I should have suspected this right off the bat as many algorithm tend to fall down under extreme conditions. The automatic balance like an averaging light meter works for the majority of times, but it is only a tool and it is up to the photographer to know when to use it and when not to use it . That being said , whenever possible, I will for not rely on the AWB. Finally the red colour shift that have bothered some with the Canon G1 is not a problem at all when you know your camera!
Grant
http://members.home.net/grant.dixon/index.htm
Creativity is so delicate a flower that praise tends to make it bloom, while
discouragement often nips it in the bud. Any of us will put out more and
better ideas if our efforts are appreciated.
Alexander F. Osborn (1888 - 1966)
Grant Dixon is offline   Reply With Quote
Old 5th of July 2001 (Thu)   #2
Eric F.
Default Re: Solution found to red shift in G1
Grant,
Thanks a lot for your post. I will give the "cloudy" white balance setting a try on some red flowers. Hopefully, this will give me some good results as well.
As always there is a lot to learn to make the shots their best. Problem is remembering what I have learned when the shot is trying to get away.
Eric F. is offline   Reply With Quote
Old 5th of July 2001 (Thu)   #3
mpkirby
Grant,
DId you take the image in Raw mode? If you get a chance, could you try again in Raw, and see if specifying the White Point in Raw works as well as specifying it in the camera? Not that I don't trust canon that raw is really raw, but....
This would explain why I have never seen the infamous "red shift" problem. I almost always shoot in raw, and manually pick the white point.
Mike
mpkirby is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A710 LCD...Fairly good solution found Graystar Small Compact Digitals by Canon 1 18th of April 2007 (Wed) 19:02
I finally found a lighting solution I'm happy with kawter2 Weddings and Other Family Events 10 3rd of April 2006 (Mon) 20:06
Anyone found a solution to mode dial problem yet Great Scott Small Compact Digitals by Canon 3 29th of March 2004 (Mon) 22:31
Adding pics in RC2 - Solution found! :-) smeyer Version 1.0-1.5 discussion 14 25th of February 2004 (Wed) 14:14
Solution to Red/Magenta Shift problem with G1 Geza Canon G-series Digital Cameras 8 5th of March 2002 (Tue) 15:43
