Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Performing Arts
Reply
Thread Tools Display Modes
Old 22nd of June 2008 (Sun)   #1
skifurthur
Default johnstoy and I DOUBLE TEAM Phil Lesh & Friends 6/19/08 Penn's Peak, PA
I had the pleasure of visiting John on his home turf of Penn's Peak in Jim Thorpe, PA Thursday night and introducing him to some old friends of mine, Phil Lesh & Friends. It was a blast comparing notes, sharing coffee and watching the show...both on and off the stage.
Lucky for both of us, Phil put on one of the best shows ever...and it was in one of the nicest venues I have had the pleasure of visiting. Top notch staff, excellent acoustics, great musicmanship and a stellar location all combined to make it a memorable night.
I only hope our photos give you a taste of what went down on stage that night....As always, critique and comments are very much welcome.
1.
2.
3.
4.
5.
6.
7.
8.
www.amsaddler.com
Capturing the passion of performance
The "simple and sweet" equipment list: 40D, 7D, 300 f/2.8 IS L, 200mm f/2.0 IS L, 70-200 f/2.8 IS L MkII, 17-55 f/2.8 IS, Canon 1.4 extender
skifurthur is offline   Reply With Quote
Old 22nd of June 2008 (Sun)   #2
jmintz
Default Re: johnstoy and I DOUBLE TEAM Phil Lesh & Friends 6/19/08 Penn's Peak, PA
Great shots - who's the female vocalist...is that someone that's touring with him? I didn't know there were any female on the road w/ him since Joan.
Josh Mintz: http://www.photosbyjosh.com
5D mk II + BG-E6 | 5D + BG-E4 | 15mm f/2.8 fishy | 16-35mm f/2.8L | 50mm f/1.4 | 100mm f/2.0 | 70-200mm f/2.8L IS | 430EX | Lots of bags, tripod, monopod, some filters, other assorted stuff that clutters up my office.
jmintz is offline   Reply With Quote
Old 22nd of June 2008 (Sun)   #3
skifurthur
That is Teresa Williams, who is Larry Campbell's wife. She and Larry are in Levon Helm's band and Levon is opening many of Phil's tour dates this summer. Previously she has been helping out when Phil has done an acoustic set...this night was her first electric band debute.
www.amsaddler.com
Old 22nd of June 2008 (Sun)   #4
johnstoy
johnstoy's Avatar
You managed to capture some great shots...
Intermittently, the lighting was just good/great enough to get those perfect looking pics... So I must say your ability to read the light is real good...
When I shot these similar moments, the red lighting must have been kicking in and it showed up often in my post processing...
That's the *thing* about Penn's Peak... Those custom lights designed by the ownership are used proficiently by the lighting engineer... and he only cuts the photographer an occasional break... If one is not paying attention, the opportunity would be missed ... That opportunity is given only a few times during the show...
I think we did good for what we had to work with.
John Stoy
www.poconophotos.com
My Gear List
"Are you only Looking or actually Seeing", from Microbiology 101.
johnstoy is offline   Reply With Quote
Old 22nd of June 2008 (Sun)   #5
skifurthur
That's the *thing* about Penn's Peak... Those custom lights designed by the ownership are used proficiently by the lighting engenier... and he only cuts the photographer an occasional break... If one is not paying attention, the opportunity would be missed ... That opportunity is given only a few times during the show...
'tis the life of a concert photographer...we always have to make do with what we get. Nobody said it would be easy.
www.amsaddler.com
Old 23rd of June 2008 (Mon)   #6
thelightofsound
thelightofsound's Avatar
nice job. you have a very well rounded set here. you did seem to hit the better colors than john. and speaking of lights, i hear that candice is now doing phil's tour; is this true? i was so upset to hear she left panic. i love her work.
thelightofsound is offline   Reply With Quote
Old 24th of June 2008 (Tue)   #7
johnstoy
johnstoy's Avatar
Mike, I agree with you on Ski's results... We were positioned in different spots... However, we both were blocked by music stands an microphones... After a while, Ski started roaming and shooting wherever he could see the stage from...
Soon after, I followed... We were the only photo pros on the scene... and with no photo pit (Penn's Peak does not put them up,) we had to make do with what we had.
John Stoy
My Gear List
Old 24th of June 2008 (Tue)   #8
DwightMcCann
so, what are we talking about?
DwightMcCann's Avatar
Well, so John's shooting again and teaching Ski all the stuff I failed to convey! Great set none-the-less.
DwightMcCann is offline   Reply With Quote
Old 25th of June 2008 (Wed)   #9
narlus
narlus's Avatar
cool to see shots from 2 different shooters from the same show. john, looks like you had stripped yr EXIF out...would have fun to compare exposures for both of you.
the lighting here looks to be rather dull; i hate the red/blue/magenta cans, and would probably just b/w the whole set (though 2 and 5 look pretty good). weird that the drummer wasn't on a riser.
narlus is offline   Reply With Quote
Old 26th of June 2008 (Thu)   #10
DwightMcCann
Yeah, but now I want to see Ski's picture of John!
Old 27th of June 2008 (Fri)   #11
johnstoy
johnstoy's Avatar
Cool Re: johnstoy and I DOUBLE TEAM Phil Lesh & Friends 6/19/08 Penn's Peak, PA
Ski does have it together... He has his routine down pat, and picking something up along the way, doesn't hurt... He's open minded...
I do want to try his pattern metering method sometime... cause my spot metering on the face, was underexposing the rest of the musician.
Narlus, I posted the EXIF printed out "longhand" in my thread from this show... You're right about the lights... The "big" spot lights weren't used... probably cause of the heat they give off and the totally full house we had... I don't think our regular lighting maestro was at the controls... and I found the lights to offer few real good opportunities to get solid shots.
I wonder if he did get a pic of me... He was using the short lens, when he would have had a better chance to get me... So it's unlikely.
John Stoy
My Gear List
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Skifurther & I "double team" Phil Lesh & Friends @ Penn’s Peak, Jim Thorpe, PA 06.1 johnstoy Performing Arts 12 27th of June 2008 (Fri) 19:05
Phil Lesh & Friends - Nokia Theater, NYC 11/10/07 skifurthur Performing Arts 7 18th of December 2007 (Tue) 08:07
Phil Lesh & Friends - Nokia Theater, NYC - 11/11/07 skifurthur Performing Arts 2 16th of December 2007 (Sun) 17:44
Phil Lesh & Friends - 10/31/07 - Nokia Theater New York, NY skifurthur Performing Arts 8 15th of November 2007 (Thu) 12:03
Phil Lesh & Friends - Tweeter Center Camden, NJ 10/12/07 skifurthur Performing Arts 8 24th of October 2007 (Wed) 07:34
