Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 25th of June 2008 (Wed)   #1
rrfa5
rrfa5's Avatar
Default critique needed...
First time posting my pictures...and these were takin with a 40d. any suggestion or comments welcomed.
http://www.flickr.com/photos/27462481@N05/
40d *50mm f1.8
rrfa5 is offline   Reply With Quote
Old 25th of June 2008 (Wed)   #2
Robert_Lay
Robert_Lay's Avatar
Default Re: critique needed...
I like Diffshades - very clever!
Bob
Quality of Light, Photo Tool ver 2.0
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
Robert_Lay is offline   Reply With Quote
Old 25th of June 2008 (Wed)   #3
rrfa5
rrfa5's Avatar
thank you. i am trying to figure out how to post those pictures here so ppl wouldnt have to click on the link. and i cant seem to find a clear answer on how to do it.
40d *50mm f1.8
Old 26th of June 2008 (Thu)   #4
Bill Boehme
Enjoy being spanked
Bill Boehme's Avatar
If you want to display an image on your Flickr gallery. you can use the image tag as follows:
[img]http://farm4.static.flickr.com/3091/2562094373_1b6a6a7465_o.jpg[/img]
The url between the tags is the web address of the image that you want to display. In this case it is your Diffshades image.
Click here to help to support POTN operating costs
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill
Bill Boehme is offline   Reply With Quote
Old 26th of June 2008 (Thu)   #5
rrfa5
rrfa5's Avatar
thanx for help .... but im not seeing a picture...on ur post.
40d *50mm f1.8
Old 26th of June 2008 (Thu)   #6
Bill Boehme
Enjoy being spanked
That is because I wanted you to see the text required to include a picture in your post. I used a trick in which I entered ASCII values for the characters instead of typing the characters directly from the keyboard. If I had just type in the characters normally, then you would not have seen the text, but just the picture and that would not have been very useful in explaining how to do it.
How does one enter ASCII into a text message, you may ask? The answer is that every character or symbol has an ASCII number assigned to it and when entering ASCII values into a text file, the number has to be "wrapped" with an identifier that tells the text display software that it is ASCII. The "wrapper" opens with the two characters &# followed by the ASCII value and then closes with a semicolon. It can be a tedious way to enter code, but sometimes is necessary as in this case where I did not want it to be interpreted by the software as an image hypertext tag.
Old 27th of June 2008 (Fri)   #7
kennykodak
kennykodak's Avatar
no. 1 horizion line isn't level which is vital when it is water.
M.Photog.MEI.Cr.
kennykodak is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
critique needed mrmacca Critique Corner 16 11th of July 2007 (Wed) 08:47
Critique needed!! whoopsjenny Critique Corner 3 17th of November 2006 (Fri) 08:59
critique needed mattgreg General Photography Talk 2 30th of July 2006 (Sun) 12:23
Critique needed ECSouljah Critique Corner 9 23rd of February 2006 (Thu) 12:11
Critique needed shniks People 19 2nd of February 2006 (Thu) 05:36
