#1 |
I know there is the battery pack, CP-E4, but can you connect it to the wall for continuous power?
Also what is the thread size of the "bracket" connection on the side near the power connection? Thanks, Rick
Rick's stuff! |
| sponsored links |
#2 |
Light Bringer
NO! It's for the battery pack only. Try that and it'll blow up. If you need that sort of power buy yourself studio strobes.
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
#3 |
Okay that is what I thought but wanted to be sure!
Thanks again!
Rick's stuff! |
| sponsored links |
#4 |
Master Flasher
... but can some of these battery packs such as quantum be plugged in and charging while they're being used?
As for the thread size of the tapped hole in the side of the 580EX II, it is apparently not a standard size. I took mine to the hardware store and tried various bolts, both SAE and metric, to no avail. Canon loves to do proprietary crap like that.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#5 | |
Moderator
...Leo |
#6 | |
The thread size seems to be 1/4-28. Witch is a US fine thread.I have some thread gauges and the 1/4-28 fit the best, although the gauge would not go all the way through and I'm not about to take the flash apart just to see. Hope this helps. Martin
Martin Birkbeck :Canon EOS 6D(Gripped) |
#7 |
It is possible to use rechargable batteries in the CP-E4, and then mod the case to accept a charger plug. On most devices, inserting the power plug from the AC adapter will usually physically disconnect the internal batteries, since if non-rechargable batteries are in the device, this would cause a problem... If an extra battery tray is dedicated to rechargable batteries only, an extra electrical contact can be added to the tray to pick up the charge circuit. The alternative would be to provide a manual switch so that if rechargables are used, the AC adapter can charge the batteries in the tray as well as provide power to the device.
#8 |
If you are going to mod the battery pack for a charger, another option would be to purchase a 6V power supply or wall dongle with a long cord and just connect the wire + to + - to - etc in the battery pack. With a dongle you could run a long length of wire from the dongle to the flash.
#9 |
Jcrompton:
Don't forget that the CP-E4, and the CP-E3, use 8 AA cells, not 4, so you would need to adjust your voltage to match when using an AC power supply instead of the batteries. |
#10 |
Master Flasher
Sorry, I tried it. No dice. The threads in the bracket hole of the 580EX II are even finer than fine.
If Canon does this stuff just to irritate me, they're succeeding.
#11 | |
Master Flasher
#12 |
Moderator
Yeah, me, too. The Turbo 2x2 pack has two sockets for powering two devices. Either one of these sockets can also be used to plug in the charger. Why they couldn't design it so that one socket can be used to power a device while the other is used to recharge the batteries or provide power to the device connected to the other port is a real mystery to me.
...Leo |
| Thread Tools | |
| Display Modes | |
| WTB: Canon 550, 580 I, 580 II EX flashes | Henry Low | Classifieds: Buy | 3 | 30th of March 2008 (Sun) 19:58 |
| Son Volt @ the Paradise | narlus | Performing Arts | 16 | 23rd of May 2007 (Wed) 11:13 |
| 512mb CF $110!! | shrink | Canon G-series Digital Cameras | 4 | 11th of April 2003 (Fri) 19:05 |
