#1 |
I'm getting ready to repaint my home studio and was looking for good choices for a color that would work well and not interfere with lighting. Also is gloss or flat paint the best way to go. The room is painted paneling. Thanks for the help.
50D, 10D, XT, S3 IS, Tamron 17-50, Tamron 28-75, Tamron 18-200, 18-55, 430EX II |
| sponsored links |
#2 |
Technically speaking, flat black would work best. Of course, you will end up with a pretty dreary room. Flat black should give you zero reflections and zero color cast.
---Bob Gross--- |
#3 |
Thanks Bob, your suggestion is not far off from my initial thought of a darker flat gray.
| sponsored links |
#4 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
Someone once suggested painting a studio 18% grey; it'd certainly make finding the exposure easier ;{)#
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#5 |
My studio walls are grey. I have never had a light or color problem!
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams 1Ds MkII 24-70 2.8L, 70-200 2.8L, 100-400 4.5L, 100 Macro 2.8, 50 1.4 |
#6 |
Thank you everyone, looks like flat gray is the way I will go.
#7 |
From about.com:
Walls and Ceilings If you have the space for a purpose built studio, the interior walls are often painted black, although it can be useful to have one white wall. The black walls prevent light bouncing from them and altering your lighting setup. A white wall can be useful when a large plain background is needed, and by using background lighting can be made anything from white to a fairly dark grey. For normal use the white wall would be behind the camera and have little effect on the scene you are shooting. You may also want to have other white walls with dark curtains that can be drawn across if necessary when the room is in use as a studio. Painting the walls a mid grey colour is almost as good so far as preventing light spill is concerned, but avoid coloured walls that will reflect coloured light to produce strange casts in your pictures. A black ceiling is often recommended also. I'd only consider this in special circumstances, perhaps if the ceiling were rather low. A black ceiling is just too depressing for both the photographer and the clients. I prefer a white ceiling because I often want to bounce a flash from it; as the best and cheapest way to get a really large light source in a studio. Avoid colours other than white that will add a colour cast to your work. If you are going to use a part of the studio for processing facilities, as a reception area, a changing area or for your computer equipment etc, you will also want to have blinds to screen these areas off from the main shooting area. From Sports Shooter.com: check out: http://www.sportsshooter.com/message....html?tid=2740 I would trust Robert Seale's opinions, he's a pretty darned good shooter.
Daniel Tunstall http://www.dmtphoto.com Sports Shooter Member http://www.sportsshooter.com/members.html?id=2474 |
#8 |
Thanks for the info Daniel, I think I am going to go with the darkest flat gray I can find since its alot easier telling the wife I'm painting gray rather than black. My ceiling is already white so I stay with that for the time being.
#9 |
Mike,
Also note that technically, some grays are not actually gray and will give a slight colour cast. I don't know if you would notice or not as it isn't something I have tried. Some of the big paint makers produce grays that are properly gray, i.e. don't produce colour casts. IIRC they are used for home cinemas for painting a wall to become the actual screen. I can't for the life of me remember the name of this range though, sorry. Cheers Ian |
| Thread Tools | |
| Display Modes | |
| Color of Paint for Small Home Portrait Studio | jhankins | General Photography Talk | 3 | 20th of August 2008 (Wed) 18:36 |
| Beginner studio choices. | Lane Jordan | Small Flash and Studio Lighting | 4 | 30th of April 2007 (Mon) 14:41 |
| What color to paint studio walls? | Kim22 | Small Flash and Studio Lighting | 10 | 2nd of August 2006 (Wed) 01:42 |
| Beginner studio choices | suse | Small Flash and Studio Lighting | 4 | 27th of November 2005 (Sun) 08:29 |
| Paint Shop Pro Studio. | walkien | RAW, Post Processing and Printing | 2 | 25th of August 2005 (Thu) 11:39 |
