Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 3rd of July 2008 (Thu)   #1
duranash
Default Gitzo Ground Level Set - Revisited
I just bought a Gitzo GT2330 tripod with the ground level set feature. I plan to remove the center column permanantly and just use the GLS setup. I'm not so sure now that I've played with the tripod a little. I'm having trouble getting the top disc nice and tight. I've tried contacting Gitzo/Bogen and never get a response. Their instructions say to tighten the disc "turn the locking collar and disc clockwise to tighten". When I do that, the entire mechanism just rotates. The only way I have found to get it tight is to rotate the locking collar counter clockwise so it essentially jams up under the disc. Anybody have a different experience or suggestions about what I might be doing wrong?
duranash is offline   Reply With Quote
Old 3rd of July 2008 (Thu)   #2
jhom
jhom's Avatar
Default Re: Gitzo Ground Level Set - Revisited
Yep, top disk platform clockwise and thumb lock collar counterclockwise. You are use the collar to press against the platform.
Jim
jhom is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Gitzo GT1540 missing Ground Level Set treefrog911 Accessories & Storage 2 31st of October 2007 (Wed) 16:45
40D owners: what level do you set your screen to? microman23 Canon EOS Digital Cameras 8 26th of October 2007 (Fri) 19:34
Gitzo 6x owners, is Ground Level Set halfway bogus? Kent Clark Accessories & Storage 75 22nd of September 2007 (Sat) 12:20
ground level shooting blam Accessories & Storage 28 15th of November 2006 (Wed) 19:52
river revisited qith a Gitzo stand garbidz Nature & Landscapes 1 11th of September 2005 (Sun) 10:49
