Thread started 05 Jul 2008 (Saturday) 08:27
5D remote release puzzle
TheGaffer
Jul 05, 2008 08:27 |  #1
I want to do photography by radio control with my 5D, so I bought a Dunecam ( http://www.dunehaven.c​om/dunecam.htm (external link) )
This has four different ways to release the shutter, so I wasn't expecting difficulty.
First choice would be CHDK I've got a suitable USB connector and the Dunecam can raise a +5v signal down it for this purpose. But CHDK is not available for the 5D: http://grandag.nm.ru/h​dk/autobuild/download.​htm (external link)
Or did I overlook something?
Second choice would be IR (I've got a suitable IR LED). But it seems that the 5D doesn't have IR release, without spending $$$ in an LC5
Or did I overlook something here?
Third choice is a switch (the Dunecam has a relay and can close a circuit), but I would have to construct a custom cable for that...
The fourth choice is to rig a servo to press the shutter button. I would rather avoid that if I can...
Any help would be appreciated.
Andrew
http://www.tug.com/ (external link)
fxk
Location: The vast wilderness of the Mid-Atlantic states
Jul 08, 2008 07:50 |  #2
The Dune Cam looks like a control for servos to control the motion of a tripod head. IR is not native to the 5d like it is on the Rebel Series.
The third choice would work - the custom cable is a bit of a problem, as Canon has a patent on the "N3" connector, and is not licensing it (as far as I know) The Canon remotes work by closing a circuit for autofocus only, and a separate circuit for shutter. Power is from camera. The "N3" is 3 conductors - 1 ground and two switching leads.
The idea of a servo to manually trip the shutter is probably not the way you want to go.
Search on e-bay for "wireless remote control canon" and you will find various units that should do the job - make sure they have the "N3" connector - that will work with any non-rebel series Canon DSLRs. I did not see the one I have, but some of them work reasonably well. Also search B&H - I think they carry a generic. Canon is absurdly expensive.
Also check this discussion - same same.
http://photography-on-the.net/forum/showthre​ad.php?t=530784
http://photography-on-the.net/forum/showthre​ad.php?t=532379
TheGaffer
Jul 10, 2008 05:08 |  #3
fxk wrote in post #5871199 (external link)
Yep. I am building a rig to suspend the camera from a kite line.
Yes, but I have found a way round it. Buy a cheap, wired remote from Hong Kong for the princely sum of £2.99 on the 'bay, then cut off the switch, leaving you with an N3 connector, ready wired, to connect into the DuneCam.
All I have to do is wait for the postman to deliver it.
Andrew
fxk
Jul 11, 2008 09:16 |  #4
WooHoo! "Up, up and away in my beautiful, my beautiful baloon!"
TheGaffer
Jul 11, 2008 13:24 |  #5
fxk wrote in post #5891743 (external link)
You are thinking of BAP. Balloon Aerial Photography.
I want to do KAP. Kite Aerial Photography.
There is also PAP, where you stick the camera on top of a pole, such as this 15 METER tripod:
http://www.kapshop.com …?cPath=36&produ​cts_id=114 (external link)
Andrew
772 views & 0 likes for this thread
Latest registered member is AndieLosAngeles
821 guests, 433 members online
