Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 6th of July 2008 (Sun)   #1
techoin
Default Filter Suggestions
I have 5D with 17-40 and 24-105. I am thinking of getting filters for these lenses...after reading through the forums I have come up on following ones from hvstar.net
a. 2 B+W 77mm MRC UV 010 Filter NEW F-PRO Multi-Coated Alloy for each lens
b. 1 B+W Kaesemann MRC CPL 77mm
c. 1 B+W 77mm Neutral Density (ND) 0.9 (8x) 103 Glass Filter for slow shutter speeds
d. Hitech 85/P Gradual ND Filter Package with ND 0.9 S.L. from http://www.2filter.com/prices/htpackages.html for sunsets etc...
(I am aware P series will vignette and will not work with 17-40 but cost is an issue here so I am not considering Z PRO)
Above filters are roughly costing around 400. I dont want to spend more than that. Any suggestions on how to go about the same within the given budget will be really helpful...Thanks.
techoin is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Filter brand suggestions... mtnbikur Canon EF and EF-S Lenses 8 22nd of April 2008 (Tue) 14:02
Filter suggestions Dumale Canon EF and EF-S Lenses 2 18th of October 2006 (Wed) 17:31
Filter for the 70-200 f/4. Suggestions? Shakespeare Accessories & Storage 1 24th of September 2004 (Fri) 14:21
skylight filter suggestions..... drautofocus Accessories & Storage 4 17th of March 2004 (Wed) 14:16
Filter suggestions and uses? gnoles Canon G-series Digital Cameras 1 14th of May 2002 (Tue) 10:16
