Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 8th of July 2008 (Tue)   #1
goldboughtrue
Default ring flash doubles as regular flash?
I'm thinking of getting a Sigma EM-140 DG ring flash for macro. Would that double as a regular flash? I don't have a flash now.
http://www.pbase.com/goldbough
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
goldboughtrue is offline   Reply With Quote
Old 8th of July 2008 (Tue)   #2
tim
Light Bringer
tim's Avatar
Default Re: ring flash doubles as regular flash?
Bounced it'd look the same as a regular flash, so yes, probably in most cases it'd be fine as a general purpose flash too.
tim is offline   Reply With Quote
Old 8th of July 2008 (Tue)   #3
PacAce
Moderator
PacAce's Avatar
The output from the EM-140 DG is just about equal to what the 40D's built-in flash outputs so I'm not sure what you gain by using that flash instead of the built-in flash unless you were looking for that distinct "shot with a ring flash" look.
...Leo
PacAce is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DIY Macro Flash ring using BUILT IN flash! mxwphoto Small Flash and Studio Lighting 70 29th of January 2012 (Sun) 06:42
Ray Flash: The Ring Flash Adapter kobe629 Small Flash and Studio Lighting 13 25th of April 2008 (Fri) 09:50
Ring Flash VS Hand Held Flash - HELP! Rodent Small Flash and Studio Lighting 2 17th of March 2007 (Sat) 12:15
DIY Macro Flash ring using BUILT IN flash! (for compacts!) Graystar Small Compact Digitals by Canon 2 10th of February 2007 (Sat) 19:55
Ring flash or Canon 580/430 flash? robwilliamsonpa Macro 5 9th of May 2006 (Tue) 19:17
