Reply
Thread Tools Display Modes
Old 10th of January 2005 (Mon)   #1
grapar
Default Power-On problems with G5
I have digital camera G5 with serious problems with power. Camera is not responding when i try to swich it on. After multiple atempts to reinsert batery and press power On switch (left or right) camera sometimes switches on, but it can take 10 or more times (removing and inserting the battery) to respond.
What do you think could be wrong with my camera? When turned on, it istarts working OK, but after several minutes it loses power and shuts down, sometimes with objective (lens) pulled out. I think that the problem has something to do with power.
I tryed with fully charged battery from another G5, but it didnt make much difference. I am intending to take the camera to service.
Is it possible that something is wrong with firmware? I have instaled version 2.0.0.0. Is it possible to restore it to previous firmware (original), if it is, please tell me how to do it and where to get this original firmware?
Gregor
grapar is offline   Reply With Quote
Old 10th of January 2005 (Mon)   #2
Ballen Photo
Moderator
Ballen Photo's Avatar
Default Re: Power-On problems with G5
Gregor
Gregor, I'm certainly no expert, but from your description, it sounds like your battery is not making good contact.
You might try cleaning the contacts with an eraser on a pencil. It will reach inside the battery compartment(Clean the contacts on the battery too). Also, make sure none of the contacts are bent or lower than the rest.
Good luck with this problem.
-Bruce
The Captain and crew finally got their stuff together, now if we can only remember where we left it.
Ballen Photo is online now   Reply With Quote
Old 11th of January 2005 (Tue)   #3
grapar
-Bruce
I tried like you sad, but it's not working!
Thanks, Gregor
Old 1st of March 2005 (Tue)   #4
jaysmith
I have this exact same problem, it just started after using the camera for 11 months with no problems. Did you solve the problem, I would love to know if you fixed it or not.
Many thanks
jaysmith is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Loose Battery Door Causes Power Problems Tirzah Canon EOS Digital Cameras 17 28th of September 2006 (Thu) 04:31
Power problems with G5 Matfink Canon G-series Digital Cameras 3 3rd of January 2006 (Tue) 14:15
Tigger and Power problems with 20D!! HELP! MadMesh Canon EOS Digital Cameras 7 7th of July 2005 (Thu) 18:08
Power problems with A75 Whistler Small Compact Digitals by Canon 0 1st of May 2005 (Sun) 05:24
G3 Power Problems? johniem Canon G-series Digital Cameras 6 9th of September 2003 (Tue) 05:47
