Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 14th of July 2008 (Mon)   #1
PhotosGuy
Moderator
PhotosGuy's Avatar
Default MOVE YOUR FEET! A <rant> of sorts.
Many times we're guilty of "Target Fixation" & all we "see" is what is right in front of us as we fly our image into the ground-air interface.
Fighter pilots are taught to scan from near to far, to see that the kill zone is clear, & then to look at threats outside the kill zone. You need to learn to do that too, & not get caught in the target fixation trap.
How does that apply to cars? How many times have you seen a shot with a light pole sticking out of the roof? Or someones white t-shirt & knobby knees reflected in the side? How about a big white parking permit hanging from the mirror? And while a group of trees might make a nice background, one or two growing out of the body are a distraction that's easily avoided.
I try to take a shot of possible locations when I see them. This doesn't look like the most inviting location for a car shot, does it? But if your objective is to make a car, or anything else, look good instead of a "Car in Landscape" or "Car in Cool Environment" shot, just how much background do you really need?
I used it for these shots: UBNXOUS Beast! part #2.
The other night the sun had set & I decided to put my (filthy) Malibu into this location I'd saved, to make the point to look before you shoot.
Move the car. Look at what the light is doing in the hood & the side. Take a shot of each view if you have to to help you remember the light on it & the reflections, both good & bad that you see there.
NOTICE the reflection from the sunset in the rear quarter of the body below. Compare that with the shots above.
You'll get the best reflections in the body if you angle it to pick up the brightest area of the sky. This is especially important in light colored cars that don't have the contrast of a dark body to show the reflections.
There was a tree (to the left of the first shot) reflecting into the hood when I first parked, so I MOVED THE CAR to the right. Seems simple, doesn't it?
This was after the move. Notice that the reflections in the side look better, too.
What do you see wrong with it now?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 14th of July 2008 (Mon)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Re: MOVE YOUR FEET! A <rant> of sorts.
I thought I'd try to hide the cars in the background so I MOVED MY FEET to the right a few feet & both the reflections in the side & the background looked a lot better. See the difference?
If I really wanted the angle in #2 I'd have MOVED THE CAR again. Pretty simple, right?
www.FrankCizek.com
Old 14th of July 2008 (Mon)   #3
PhotosGuy
Moderator
PhotosGuy's Avatar
Image #4
Just some minor PS work: I darkened the headlights & the highlights in the side a little. Warmed up the highlights in the side, hood, & windows.
How did I do that? See post #9: Airport runway shoot
Image #5
Cloning of some of the distractions in the background. A little more work near the parking light & in the bumper wouldn't hurt.
EDIT: A cleaned up & re-cropped image to put more attention on the car is in post #30.
BIG NOTES!
At no time did I use a CP (Circular Polarizer) for these shots.
At no time did I use a flash for these shots.
www.FrankCizek.com
Old 14th of July 2008 (Mon)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
Now a word about the "Creative framing" we see here. Why? Does it really make the car look better?
I have no objection to tilting the image if that's what you like, and if it really does improve the image, but with a straight image, which of these images below look better? Isn't making the subject look better the point of learning about photography?
OTOH, if your intent is to disturb the viewer, then it's an accepted technique & I would only use it if that was the emotion I needed to portray, or what the client was paying for.
FlyingPhotog: Something many beginners forget is "Lead Space" for moving vehicles...
If you're panning with a car or shooting someone running or riding a bike, it helps the brain make the connection that the subject is in motion if you leave a little more room in front of your subject than behind it.
So, everyone has their own "vision" of what the results should be. The person who's paying me gets to make the rules. I'll always include some shots that illustrate the way that I "see" the job being done. They can use them, or not, but I try to deliver more than I contracted for.
If I'm not being paid, then I shoot to satisfy myself. Consider "Rules" as guides that usually hold true. OTOH, you do have a brain. Sometimes you learn more by breaking them.
"There are no rules for good photographs, there are only good photographs."
-- Ansel Adams
Photography Composition Articles TONS of info here.
There's a link in there to a Composition Adjuster: This is a really neat Java app that will show your image with various "Rules" applied to it.
http://photoinf.com/Tools/Compositio...-Adjuster.html
Image #6
This shot was cropped this way for a reason, to show both cars, and...
Do you notice that the car looks longer in that crop? Most people are satisfied with the proportion of the frame that the camera gives them. But what's "right"? 5X7? 8X10? 8X12? 4X10?
My short answer is to crop to the important elements of the image, not to some arbitrary paper size, & then use a mat to cover the "excess" space in the frame. A mat & frame also help isolate the image from the usual white walls that they're hung on, & can make a big difference in how it looks. Take a look at POST #30 near the bottom: The gray bar at the center is the same density all the way across.
A few Car Lighting Tips
Composition Articles library
Understanding Aspect Ratios and The Art of Cropping
Image #7-9
But what about these? Only going by where the car is placed in the frame, does one of the crops look better than the others?
Did you notice that in Crop # 1: It's running into the frame of the image. What is it about that crop that some of you guys like so much? We almost never used it unless a art director needed room for text.
Crop # 2: Static. No apparent feeling of motion. OK for your grandmother's car maybe?
Crop # 3: Dynamic. Room for it to "move into" the frame.
Any questions?
www.FrankCizek.com
Old 14th of July 2008 (Mon)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
A few links, for that one person who hasn't see them yet.
A few Car Lighting Tips - Updated
This shows how the subject can affect the exposure & why manual keeps me worry free:
Post #47
Thread on manual exposure. First set the f-stop & shutter speed you need. Then adjust the ISO.
Need an exposure crutch?
COMMON MISTAKES WHEN SHOOTING A CAR
Keep reading. There's more info below.
www.FrankCizek.com
Old 14th of July 2008 (Mon)   #6
cdifoto
Don't get pissy with me
cdifoto's Avatar
is that a replacement fender or just the angle? looks to have a different finish compared to the doors. (on your malibu)
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 14th of July 2008 (Mon)   #7
cdifoto
cdifoto's Avatar
of the hot rod pics, the first one looks best. you took out the honey in green from the others.
Old 14th of July 2008 (Mon)   #8
PhotosGuy
Moderator
PhotosGuy's Avatar
Besides needing a wash, it's as it came from GM, so it's the angle of the light in the first shots. I may have darkened that fender in images #3-4 when I warmed up the side, though.
I just KNEW someone would say that!
www.FrankCizek.com
Old 14th of July 2008 (Mon)   #9
aridan
aridan's Avatar
I prefer 9 the best, but while you at it, I'd also clone out the pole that *almost* grows out of the hood.
I have this urgent need to get rid of poles and powerlines
5D Mark III
17-40L | 24-70L | 35L | 85L II | 580EXII | Complete Gear List | Flickr
Last edited by PhotosGuy : 21st of August 2008 (Thu) at 08:18. Reason: numbers corrected
aridan is offline   Reply With Quote
Old 14th of July 2008 (Mon)   #10
PhotosGuy
Moderator
PhotosGuy's Avatar
I'd also clone out the pole that grows out of the hood.
I expected that, too. I wonder where you get that compulsion from?
www.FrankCizek.com
Old 14th of July 2008 (Mon)   #11
pjfrad
I think 7 is best because it doesn't have the back of the red car on the left side.
Peter
Last edited by PhotosGuy : 21st of August 2008 (Thu) at 08:19. Reason: Numbers corrected for new added image
pjfrad is offline   Reply With Quote
Old 14th of July 2008 (Mon)   #12
cdifoto
cdifoto's Avatar
Better kill the cross too.
Old 14th of July 2008 (Mon)   #13
aridan
aridan's Avatar
I have good mentors...
5D Mark III
Old 14th of July 2008 (Mon)   #14
mlav
mlav's Avatar
You forgot to clone out the parking lines!
I am driving myself insane now with the background and parking lot defects. With spare time being reduced on a daily basis, I keep adding more time to the PP work for each photo. Cracks in the blacktop, light posts in the background, parking stripes...where does it all end?!?
mlav is offline   Reply With Quote
Old 14th of July 2008 (Mon)   #15
Jamie Holladay
Moderator
Jamie Holladay's Avatar
Hot rod shots:
the second one looks better to me. The first and third look a bit over sharpened. The light pole does not bother me as much as the cross looking like it is growing out of the hood.
Great Thread Frank!
The Site The Gallery The Gear
Jamie Holladay is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
[rant]I am ready to give up[/rant] Oneslowz28 The POTN Lounge 6 28th of June 2008 (Sat) 19:51
printing 8 feet by 4 feet --?! bluesmap RAW, Post Processing and Printing 4 3rd of May 2008 (Sat) 08:23
(RANT) Perfectionists (RANT) calicokat The POTN Lounge 111 2nd of January 2007 (Tue) 18:38
