Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 15th of October 2002 (Tue)   #1
mljg
Default Ixus 330 Waterproof Case
What buttons do you have access to when using the Digital Ixus 330's waterproof case?
http://www.mljg.co.uk
mljg is offline   Reply With Quote
Old 17th of October 2002 (Thu)   #2
chatoyant1
Default Re: Ixus 330 Waterproof Case
All buttons and the mode selection dial are useable with the WP-DC500 (waterproof case) from Canon. The mode selection dial is a little tricky to use. Move it gently to feel the detent. The case even has a metal tripod mount on it, and comes with a wrist strap, neck strap. anti-fogging liquid, and silicon gel for the case seal. Any other questions?
A satisfied Canon customer.
P.S. Now I'm wondering about setting the camera up underwater on a tripod for stability. Had only thought that the mount would be good for taking foul weather shots out of the water. Hmmm?
chatoyant1 is offline   Reply With Quote
Old 21st of October 2002 (Mon)   #3
mljg
Thank you very much for your help, it is much appreciated.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ixus 330 to 400 andylepki Small Compact Digitals by Canon 1 14th of March 2004 (Sun) 12:21
Is Waterproof case WP-DC600 suitable for digital ixus V? marvin Small Compact Digitals by Canon 5 18th of June 2003 (Wed) 08:18
IXUS 330 bunch77 Small Compact Digitals by Canon 1 28th of February 2003 (Fri) 04:49
First photos with Ixus 330 dewmuw Critique Corner 2 31st of July 2002 (Wed) 07:44
