Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 12th of January 2005 (Wed)   #1
RockOne
RockOne's Avatar
Default The Ancient Mariner
G'Day All
This is the James Craig, built in 1874 in England (and named Clan McLeod until 1905), and used on trans-tasman cargo voyages, was semi-retired several times, and finally abanoned in Tasmania, where it was found and restored.
Unfortunately in this picture, where it is leaving Newcastle harbour, the sails arn't out, because it is under diesel motor power (not an original bit of kit - 19th centuray sailors would also have been jealous of the GPS no doubt ). The washed out look around the hull is due to sea-spray (caused by a firefighting tug).
Steve
EOS300D / EOS30Dx2 / 100-400 L / EF-S 17-55IS /A75 / 75-300mmII / 18-55mm / 28-80mm / 50mm 1.8II / 50-500mm / FinePix S9500.
RockOne is offline   Reply With Quote
Old 12th of January 2005 (Wed)   #2
RJSorensen
RJSorensen's Avatar
Default Re: The Ancient Mariner
I am a big fan of ships of sail . . . even if said ships have other modes of power. A ship of sail should have some salt spray nonetheless, so the picture is perfect to me. Pay no mind that I am mostly landlocked . . . lol.
"With Some Practice . . . I Am Able to Believe Six Impossible Things Before Breakfast!"
5D, 20D, EF 50 f/1.4, EF 16-35 L, EF-S 17-85, EF 24-70 L, EF 100-400 L, 1.4 TC II, Tubes, 550 EX, 580 EX.
RJSorensen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ancient wheel Cfer4 Critique Corner 12 9th of March 2007 (Fri) 03:19
Ancient stone Cogboot Nature & Landscapes 25 5th of March 2007 (Mon) 22:51
Plentzia Mariner, Spain AdamJL Nature & Landscapes 10 7th of July 2006 (Fri) 18:03
ancient gold PEACHMAN Nature & Landscapes 15 23rd of October 2005 (Sun) 13:51
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
