Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 19th of July 2008 (Sat)   #1
Bilsen
Bilsen's Avatar
Default XSi and 430EX aren't talking
or at least it seems that way.
For example, with the 430EX on the shoe and turned on, I tried a shot in Av. The camera still took a 3 second shutter speed. If I do the same thing with the internal flash in Av, the camera will adjust the shutter.
Does anyone know what's up here? The 430 talks to my S5 IS just fine.
Thanks.
BILSEN (the artist formerly known asd John Galt NY)
Canon 600D/T3i; XSi/450D
24-105 f4L IS; 70-200 f4L IS; 50 mm 1.4; 18-55 IS;55-250 IS; Sekonic L-358; 580EX & (2) 430EX
Model Galleries: http://bilsen.zenfolio.com
Everything Else: www.pbase.com/bilsen
Bilsen is offline   Reply With Quote
Old 19th of July 2008 (Sat)   #2
DDCSD
GIVIN' GOOD KARMA
DDCSD's Avatar
Default Re: XSi and 430EX aren't talking
In AV, you set the aperture and the camera sets the SS according to the ambient light, regardless of whether or not you have a flash attached or not. It makes the flash act as "fill" and attempts to get the proper exposure for the image without taking the flash into consideration. I do not know what it does on the S series.
If you want to make your flash the main source of light, put your camera in M and set for an underexposure of 1-2 stops. If bouncing the flash, set it to around +1. This will mostly eliminate the ambient light and make the flash your main source of light.
Derek
Bucketman Karma Fund
POTN FF L2 MadTown Birds
Full Gear List & Feedback
DDCSD is offline   Reply With Quote
Old 19th of July 2008 (Sat)   #3
DDCSD
GIVIN' GOOD KARMA
DDCSD's Avatar
Here is an amazing resource on flash photography, read it more than once. Too much info there for one read.
http://planetneil.com/tangents/flash...hy-techniques/
Derek
Old 19th of July 2008 (Sat)   #4
Microcosm
Microcosm's Avatar
Sweet, thanks. Just got a 580 I'm still figuring out.
All Gear | Canon 50D | Canon Rebel XTi | EF 17-40mm f/4 L | EF 24-105mm f/4 L | EF 70-300mm f/4-5.6 IS | EF 50mm f/1.8 | EF-S 18-55mm f/3.5-5.6 | 580EX II
Nikon EM | 50f/1.8 | 100 f/2.8 | Speedlight SB-E
Microcosm is offline   Reply With Quote
Old 19th of July 2008 (Sat)   #5
350D_Noob
350D_Noob's Avatar
Might be a dumb question, but it happens...
Does your flash fire at all? Both the 430EX and internal? If not, might be that the flash is disabled and you have to change that in the menu.
http://www.myspace.com/JGabrielPhoto
"It's better to live one day as a lion than a thousand years as a lamb."
350D_Noob is offline   Reply With Quote
Old 19th of July 2008 (Sat)   #6
Bilsen
Bilsen's Avatar
Thanks DDC. On first look that's a tremendous resource.
Noob - the flash fires but there's no shutter adjustment for the flash.
Maybe I'm missing it, but I still don't know if the 430 and 350D are talking.
Old 19th of July 2008 (Sat)   #7
JeffreyG
JeffreyG's Avatar
If the flash fires, they are talking.
Perhaps you missed it in the discussion, but what your camera is doing is normal. In Av mode the camera exposes for ambient. It will give you the same shutter speed whether you have a flash on it or not.
Both Av and Tv modes do not account for flash. Both assume the flash is for fill and expose for ambient.
If you want to use the flash as primary light, then you need to use M or P modes, and of the two M is more predictable.
P will use the flash as fill in good light and as main light in low light.
My personal stuff:http://www.flickr.com/photos/jngirbach/
Commercial sports:http://girbach.zenfolio.com/
I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550
JeffreyG is offline   Reply With Quote
Old 19th of July 2008 (Sat)   #8
Bilsen
Bilsen's Avatar
You're right Jeffrey. Don't know where my head was but I missed it. Got it now.
Thanks to all for the responses and thanks again DDC for the website.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Look at me when im talking to you!!! cmgarcia Nature & Landscapes 5 7th of April 2008 (Mon) 13:32
Talking about.... mateob People 1 19th of January 2008 (Sat) 14:13
Talking henkbos Critique Corner 1 27th of April 2003 (Sun) 01:45
