Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 21st of July 2008 (Mon)   #1
s2kologist
s2kologist's Avatar
Default car show runied by circular polarize filter
EDIT2: there was a huge smug on the filter that is why the pic came out super hazy.
EDIT: i used the filter wrong, i did not rotate it.
What did I do wrong? Should i have not use a filter? It was a very bright day and thought i would try out the B+W circular polarizer filter i just picked up. All of the pictures came out hazy. I was using a 40d with 17-55 2.8 with hood.
s2kologist is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #2
mlav
mlav's Avatar
Default Re: car show runied by circular polarize filter
Did you just clean the lense/filter? Check it closely, I have smeared crap on the glass before, not a good outcome.
mlav is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #3
A2EVOMR
Did you turn and adjust the filter properly for the angle of shots you were taking?
40D ~ EF 24-70mm f/2.8L USM ~ EF 50mm f/1.4 USM ~ EF 100-400mm f4.5-5.6L IS USM
My JetPhotos
www.mwaviation.net
A2EVOMR is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #4
s2kologist
s2kologist's Avatar
no. tell me about this.
Old 21st of July 2008 (Mon)   #5
s2kologist
s2kologist's Avatar
the lens and filter are brand new. i just pulled them out of the box and shot. maybe i smugged it later in the day.
Old 21st of July 2008 (Mon)   #6
tedBalog
tedBalog's Avatar
For a Circular polarizer to work properly you must turn the one layer of the filter.
5D | 24-70mm f/2.8L | 70-200mm f/2.8L IS | 70-200mm f/4L | 85mm f/1.8
tedBalog is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #7
CincyShooter
You didn't use it correctly
CincyShooter is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #8
s2kologist
s2kologist's Avatar
how do i use it correctly?
Old 21st of July 2008 (Mon)   #9
Pete
Moderator
Prime Mover
Pete's Avatar
When you're looking at your subject through the viewfinder, rotate the front of the filter around. You'll see that the reflections on windows will appear and disappear as you rotate it.
Just take the shot when the reflection (or not as the case may be) is how you like it. Mostly, you want to try and get the windshield clear (no relfection).
Pete
Pete is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #10
Bill Ng
Polarizers only work their best when the lens is pointing at a 90 degree angle from the sun, in other words, not pointing towards it or away from it, but positioned so that the side of the camera is pointing at the sun.
Second, your polarizer should have a floating front-element that allows you to rotate the glass while the filter is installed. You need to rotate the glass while looking through the lens until the filter's effect is at its strongest. Then shoot.
Just go outside today if you have a chance and watch what happens as you rotate the filter and turn your body around to different directions - it will effect the potency of the filter.
Bill
Bill Ng is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #11
elysium
"full of stupid banter"
elysium's Avatar
Location: Harrow/London/UK/GB/That Part Of The World/Next To France
Looking at it, the white car on the right seems to be much more clearer.
Have you tested it more. How did it look when using the viewfinder on your camera?
Everyday, a programmer finds a way of creating an idiotproof program. Everyday, the universe spits out another idiot.....So far, the universe if winning
elysium is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #12
Mark1
Mark1's Avatar
You can test it here at the computer. At least with LCD screens... hold the filter up and turn it. You will see the screen change. This is what you need to do when shooting. It does slow you down, but the results are usually worth it. When you do the rotation depends on weather the front element of your lens rotates or not. If it does, you need to focus first then align the filter. If it does NOT rotate it really does not matter. However every shot will most likely take an adjustment.
Keep in mind "Its not the camera, its the photographer" works just as well for bad pictures as it does for good ones.
www.the6by6frame.wordpress.com
Mark1 is offline   Reply With Quote
Old 21st of July 2008 (Mon)   #13
s2kologist
s2kologist's Avatar
i did not know you had to turn the filter. i will do some more testing with it today. when i was looking through the view finder the pics looked dark. the sun was too bright to see how the pics looked in the monitor on the camera.
Old 21st of July 2008 (Mon)   #14
s2kologist
s2kologist's Avatar
Originally Posted by Bill Ng View Post
Polarizers only work their best when the lens is pointing at a 90 degree angle from the sun, in other words, not pointing towards it or away from it, but positioned so that the size of the camera is pointing at the sun.
Bill
so is the filter a bad idea for walking around at a car show?
Old 21st of July 2008 (Mon)   #15
Mark1
Mark1's Avatar
They will be fine. Note he said" work their best". Not "only work at". Polarizers will cut down reflections at most angles. "Cut down" not necessarily eliminate them. Just take your time and adjust the filter before each shot and you will do fine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
16-35mm F2.8 II L: Does anyone have car or car show pictures using this lens? NeoTokyo Canon EF and EF-S Lenses 17 12th of July 2008 (Sat) 03:51
Circular Polarizer - Car Show in Evening - Question NMGolfHacker Transportation Talk 2 16th of May 2008 (Fri) 21:34
Polarising Filter At A Car Show Birchwood Accessories & Storage 28 28th of April 2008 (Mon) 13:39
linear vs circular polarize microman23 Accessories & Storage 5 29th of March 2008 (Sat) 07:31
Polarize filter? TeriD Canon EF and EF-S Lenses 15 27th of February 2008 (Wed) 16:29
