Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 23rd of July 2008 (Wed)   #1
js26198
Default Some more lax
Found some more.
js26198 is offline   Reply With Quote
Old 23rd of July 2008 (Wed)   #2
js26198
Default Re: Some more lax
and more...
Old 23rd of July 2008 (Wed)   #3
johndevane
johndevane's Avatar
I'm not seeing any Exif data. If you're looking for critique, post your settings. If you're not looking for comments, then... J/K,
They look like they're very cropped, and maybe blurry to start with. The colors are very muted. Give some info on how you shot these, and the guys here will give you a ton of help!
Regards,
John.
MKIII, 40D, XTI, 70-200 f/4L, 100-400L, 17-85 IS, 85 1.8, 100 2.8 Macro, 580 EX II, 550 EX, Bee's, PW's
Last edited by johndevane : 23rd of July 2008 (Wed) at 19:18. Reason: Wasn't done.
johndevane is offline   Reply With Quote
Old 23rd of July 2008 (Wed)   #4
js26198
how do I supply the data so it can be viewed?
Old 23rd of July 2008 (Wed)   #5
johndevane
johndevane's Avatar
Just type it in... Shutter speed, aperture, ISO, focal length. Such as "1/500, f5.6, ISO 400, 70mm" for example.
It may be embedded and I just can't see it with my firefox browser, but it doesn't take any extra time to post it anyway. It helps the pros to know the data so they can help you. Also, include info about how much you cropped for these pictures, as it looks like they're suffering from cropping.
Old 23rd of July 2008 (Wed)   #6
js26198
Thanks. I know I get a little crop crazy. I also load them to the teams website. I'll be at a tournament in PA this weekend. I shoot with a XTI and just bought the 70-200 IS L. I shoot in Tv usually at 1250 to 1600 shutter speed, AI Servo, ISO 200, Center weight metering and white balance set to daylight when it's sunny out. A lot of times the sun is really harsh and super bright. I'm tempted to try Manual to get rid of some of the background. Not really sure if these are the optimum settings... I also have Photshop Elements 6 to do my cropping and resizing which I'm still muddling through. I'll post some more pics. I'm still playing around with the sizing. Thanks again for the info
Jim
Old 23rd of July 2008 (Wed)   #7
johndevane
johndevane's Avatar
Okay Jim,
Now we can help. You have great gear, and a good eye for timing on your shots. Each photo shows faces and at least some good action, which are key. You've cropped the photos so that there are no legs or arms cut off, which is also a key. Good job.
Maybe your biggest issue to deal with is a simple fix. Shooting in TV is not what most people do. AV works much better for sports. In TV, your camera decides your aperture. For sports, a larger aperture (smaller number) is best. On your 70-200L, you can set your aperture to 2.8, or 4.0, depending on the model of the lens. The smaller number will help to blur out your backgrounds. Using AV will demand your XTI to shoot in 2.8 (or 4.0)
Look at your first picture posted here... the house in the background is almost as clear as the players. If you were zoomed in all the way to 200mm, at a large aperture, you'd get the players in focus and the house blurred. In my photo I was around 300mm, f5.6. You can see my background was much closer, but much more blurred.
In AV, you control the aperture, and the exposure of the shot by adjusting your ISO. Your camera will set the shutter speed. If the SS gets too slow, raise your ISO. So try again in AV. Set your aperture to the largest for your lens, and adjust your ISO so the picture looks good. You can also do this in manual, but it's easier to start with AV.
Also, wait for the action to come to you, so that the players fill your viewfinder at 200mm. If they get too close, then zoom out. Taking shots that must be heavily cropped is difficult to keep the players separate from the background.
Keep it up, and keep posting! You'll learn a ton from the great people here who taught me.
Regards,
John.
Old 24th of July 2008 (Thu)   #8
Sauk
Sauk's Avatar
If there is something I have learned in sports is shoot tight and crop tighter!
Only word of advice I can offer
Name: Matt | Feedback |
My Website |
Twitter | Flickr
SportsShooter Page
Sauk is offline   Reply With Quote
Old 24th of July 2008 (Thu)   #9
cecilc
cecilc's Avatar
Yes, I'd agree ....
You want to be in control of your depth-of-field, not allow the camera to decide that for you by adjusting the aperture anytime "it" decides to. While a high shutter speed is good, you can keep your shutter speeds high enough by adjusting your ISO setting. Which means that if you're shooting in AV at, say, f4.0 with an ISO of 100 and your shutter speed winds up to be 1/500 then you just adjust your ISO speed upwards (to about 400) to get your shutter speeds up to where you want them.
Your shots do appear a bit soft - and I'm not sure if that's because of the cropping; or if it's a lens issue; or even some camera shake on your part. Hard to tell .....
With a 200, you will have to have the action come to you more so that you fill more of the frame with your subjects. Shooting all the way across the field will require a pretty hefty crop to isolate the action that you're shooting.
A couple of examples below. I wish I could remember how I shot these, but my best guess is that I was in AV with an aperture of anywhere between 2.8 and 4.0. ISO probably between 200 and 400. Shutter speed in the 1/1500 to 1/2000 range .....
Hope that's some help .... don't hesitate to ask specific questions ....
Cecil
SportsShooter Portfolio
cecilc is offline   Reply With Quote
Old 24th of July 2008 (Thu)   #10
js26198
Excellent advise. Thank you all. I will try Av this weekend and be more patient. Because of the reach issue with the 200mm, I tend to zoom in when I PP, I think that may have something to do with the softness, or maybe not...I went with the 4.0 since 99% of the games are during the morning and early afternoon with sufficient light. I don't shoot Basketball or other indoor sports. I will report back Monday after the tournament.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
lax js26198 Sports 2 22nd of July 2008 (Tue) 15:10
LAX js26198 Sports 2 16th of June 2008 (Mon) 16:46
LAX Spoo0oon Sports 1 8th of March 2008 (Sat) 20:43
two lax steve535 Sports 2 8th of May 2007 (Tue) 23:14
Lax steve535 Sports 6 20th of April 2007 (Fri) 12:39
