#1 |
I've taken a couple thousand pictures with my XT now and I've always felt that something was "off". Things just didn't look sharp. I'm probably a pixel peeper, and I know that my equipment is somewhat limited; however my results just looked fuzzy!
So I decided to conduct two focusing tests with the two lenses I own: The Kit 18-55 F3.5-5.6 NONIS and the 50mm 1.8. Test was used with a Tripod with the mirror lock enable. Images were shot RAW and converted to JPEG using DPP. The first test looks like this ![]() Here is this test using the 50mm 100% crop 1/80Sec F1.8 ISO 100 50.0 mm ![]() Here is the test using the 18-55mm Kit. The kit is 5.6 at 50; so I shot it at 24 to achieve F3.5 to control DOF. 1/15Sec. F3.5 ISO 100 24.0 mm ![]() Wow. That looks off to me! Next test was the battery test. The batteries and measuring tape are set at a 45 degree angle from the camera. For all pictures, I focused on the center portion of the middle battery. I'll start with the nifty fifty again: 1/60Sec. F1.8 ISO 400 50.0 mm ![]() 100% crop: ![]() And now for the 18-55 Kit. I had to bump up the ISO to get a faster shutter speed. 1/30Sec. F5.6 ISO 1600 55.0 mm ![]() And now the 100% crop ![]() It seems that it is time to replace/upgrade my walk around lens! This is the data I needed to justify the expense to myself....and my wife.
Canon 5D Mark III 24-105 F/4L; 70-200 F/4L; 85 F/1.8 |
| sponsored links |
#2 |
Your kit lens looks like its backfocusing.
Canon Supremacy |
#3 |
Definitely! Picture after picture it consistently backfocused. This helps explain, at least in part, some of the results I've had.
| sponsored links |
#4 |
Your Kit lens is back focusing. The 50 seems like it has a slight front bias, but it's certainly within spec. It could also just be your rebel, but it's fine. Send that kit lens in! My Xti was doing the same thing, but it was definitely the body. Canon fixed it under warrany.
Best Regards, -Ericson. flickr | Gear - Canon 1Ds Mark II, 50L & 28mm f/1.8 for SALE! |
#5 |
Man I Like to Fart
Yep, back focusing.
NYC Wedding Photographer | Blog | facebook | Galleries | Flickr | Gear My 5D Mark III Review |
#6 |
May be off topic but how do you accurately keep your camera at a 45 degree angle
5D Mk III Canon 580EX Canon 16-35mm f/2.8L | 24mm f/3.5L | 50mm f/1.4 | 100mm f/2.0 | 100mm f/2.8 Macro | 135mm f/2.8 SF | 70-200mm f/2.8L IS | 70-300mm f/4.5-5.6 DO Sigma 50mm f/1.4 EX |
#7 |
What exactly is "backfocusing"?
Figured out that a clunky DSLR isn't my sort of thing. Sold the XSi and continuing the journey with a S95! |
#8 |
Moderator
Backfocus occurs when the camera/lens actually focuses behind the point of focus. Front focus is just the opposite.
Mark ----- Some primes, some zooms, some Ls, some bodies and they all play nice together. Thirty-five years of shooting and still learning. My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW) G&N FORUM EARLY ACCESS & IMAGE POSTING RULES |
#9 | |
Well for the first test I used a tripod and used a protractor to measure the angle. I took a ruler (any straight object would do) to make sure the barrel of the lens was positioned to hit the chart at 45 degrees. The second test was a lot easier to accomplish. You set your camera perfectly level and then you put the batteries at a 45 degree angle on a flat surface.
#10 |
A large carpenter's triangle also does the trick!
#11 | |
#12 | |
#13 | |
#14 |
You could also fold a sheet of paper so that it makes a 45 degree angle =)
#15 |
uff at least they look worst than mine, i dont know if its a relief... as i was testing the 17 55 is and it should perform better:
http://photography-on-the.net/forum/...d.php?t=539178 |
| Thread Tools | |
| Display Modes | |
| -= Front Focusing: Camera or Lens? =- | Pentaxis | Canon EOS Digital Cameras | 9 | 9th of August 2007 (Thu) 10:13 |
| I think my camera or lens has focusing issues | newton | Canon EF and EF-S Lenses | 8 | 4th of August 2007 (Sat) 17:09 |
| 30D lens/camera focusing issues..pics | bobbyc01ta | Canon EOS Digital Cameras | 14 | 15th of April 2007 (Sun) 11:50 |
| What sorts of tests should I run on my new camera and lens? | Future Blues | Canon EF and EF-S Lenses | 5 | 4th of August 2005 (Thu) 17:43 |
| First tests to do when receiving dSLR(searchig CAMERA CHART) | 5 Type | Canon EOS Digital Cameras | 22 | 8th of March 2004 (Mon) 02:26 |
