| sponsored links |
Thread Tools | Display Modes |
#1 |
I am looking to buy a new lens but an unsure which to go for. I would welcome advise on whether to buy a Canon EF 300mm f/4.0L USM IS and a 1.4 converter or go for the Canon EF 400mm f/5.6L USM. I am thinking possibly the 300mm as this has IS. What are the plus and minus points of each lens. There are no dealers in my part of the country which stock any of these lens to try.I will be using it with a 400D and 40D
Thank you |
| sponsored links |
#2 |
subscribed.
#3 |
If you really need a 400mm lens all the time, get the 400/5.6. The lens is very sharp with very fast AF.
The exact same praise can be given to the 300/4. Native this lens is very sharp with very fast AF. My 300/4 also works really well with a 1.4X TC. The AF slows down a little I suppose, but I have not missed sporting shots in servo focus with the combination. I also have no compunction with shooting the combo wide open (f/5.6). The IQ of the combo is stellar. To me the main decider should be based on 3 things in order of importance: 1. Do you need a 300 and a 400? Or just a 400? If you need both get the 300. 2. Do you need a macro lens? The 300/4 makes for a great macro (1:0.33 with TC) for flowers and stuff. 3. If you can't decide, get the IS. Don't overestimate the value of the 300/4 IS though. This was the second Canon lens to get IS. The gen 1 IS is worth about 1 stop (maybe 2) in handholding. It is nothing like the 4 stop IS in the latest lenses.
My personal stuff:http://www.flickr.com/photos/jngirbach/ Commercial sports:http://girbach.zenfolio.com/ I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550 |
| sponsored links |
#4 |
I've got both options and they have different strengths.
What do you intend to use it for?..... Bob
1Dx (2), 1D4, 5D2 (IR)>> EF600L, EF400L, EF300L, EF300L, EF200L, EF200LII, EF180L, EF135L, EF100L, EF85LII, EF50L, EF35L, EF24LII, EF24-70L, EF24-105L, TS-E24LII, TS-E45, TS-E90, MP-E65, EF135SF, Zeiss 15/2.8, 21/2.8, 25/2, 28/2.8, 34/1.4, 35/2, 50/1.4, 50/2, 85/1.4, 100/2, T/C's, L-SC and a WIFE! |
#5 |
I want a longer lens for general wildlife work. I recently went up to see the sea birds at RSPB Bempton and they were to far away to get a good shot. I also want one that will allow me to get photographs of flighty dragonflies at a reasonable distance.
Thanks to all for their comments |
#6 |
For flying birds and dragonflies, I'd go for the 400....the IS on the 300 wouldn't be much help in this situation. My 400 is quicker to focus and gives a crisper image than the native 300 (even before the T/C is factored in).
Bob
#8 |
I have to disagree here. Flying birds, yes the 400 will focus faster but dragonflies, no, the 12 foot minimum focus distance is an anchor around your neck for dragonflies. In addition, IS is very useful for stabilizing something small like a dragonflyin your viewfinder.
#9 |
Stuck by a stickie
The difference in MFD is significant. 4.9 ft for the 300 vs. 11.5 ft for the 400 - and I have found that sometimes 4.9 ft seems a bit far when I have to start backing up to get focus.
The IS is awesome though. Works flawlessly. As an aside - some of my absolute best shots have come at 1/250 & f/4 in the evening when shooting in the garden (plants and dragonflies, interestingly enough). |
#10 |
Stuck by a stickie
#11 |
How about the 100-400mm L IS? If you really want to choose between the 300mm and the 400mm I would go with the 300mm IS which is more versatile (macro and IS). Most of the time, you will have to use a tripod with the 400mm L.
I took this macro shot a week ago with the 300mm: http://picasaweb.google.com/blubOmat...15524142273906
XT/XTi/40D, 10-22mm, 300mm f/4L IS, 100-400mm L IS, 430EX II. Gallery: http://picasaweb.google.com/blubOmatic Last edited by Zwiz : 24th of July 2008 (Thu) at 11:21. |
#12 |
do you have a 70-200 with IS? i am in the same boat and i am most likely going to get the 400mm. Its mostly going to be for wildlife. If I ever needed a Canon lens that goes to 300mm and has IS i would put a TC on my 70-200. thats how i came to my answer. (300 or 400)
#13 | |
13mm 2.55m to 15.00m 21mm 2.30m to 9.00m 31mm 2.10m to 5.80m 52mm 1.75m to 3.80m 65mm 1.55m to 3.10m Values are based on someones real world tests and posted on another forum. Bob
#14 |
I would go with the 400mm. Putting TCs on a lens is ok but not the best way to go. If your looking for reach then 400 would be great. It is a very light weight lens you can hand hold without any problems. Its lighter than the 100-400 and although I have not looked into it, I bet it will be lighter than a 300mm with a 1.4 tc. Its a tiny hair cheaper. Yes, you will be lacking IS but when you put a tc on it, you loose some image quality. Good luck with your purchase. Either lens you choose will be a great lens.
#15 |
The 300 + EF 1.4 TC is a much more versatile package than the 400 f/5.6 L alone. I use my 300 with/without TC much more often than my 400 f/5.6 L mostly because the 300 has close focus of 1.5 M.
With a EF 12 extension tube the 300 f/4 L IS provides a magnification of 0.3~0.04 and a minimum focus of 1.33 M while the 400 f/5.6 L with the EF 25 extension tube has 0.21~0.07 magnification and close focus of 2.5 M. Adding more extension to the 400 f/5.6 results in slower focus and darker VF. If all your subjects are beyond 6 M and are larger than a robin, the 400 may be the best choice. But if you want versatility, the 300 plus TCs is the best choice IMHO. The 300 f/4 L IS gives very exceptable images with both the EF 1.4 and EF 2 TCs if stopped down 1/2 -1 stop. |
| Thread Tools | |
| Display Modes | |
| Canon EF 70-200mm F4 L (IS) USM vs. Canon EF 400mm F5.6 L USM Sharpness, Detail, IQ | doublme | Canon EF and EF-S Lenses | 12 | 28th of August 2008 (Thu) 09:53 |
| 400mm f4OD IS USM vs. 300mm f2.8 IS USM with 1.4x | Snow Goose | Canon EF and EF-S Lenses | 6 | 9th of February 2008 (Sat) 14:19 |
| Used Canon 70-200 F4L USM non-IS vs Canon Refurb 70-300mm f/4-5.6 IS USM | mike93lx | Canon EF and EF-S Lenses | 4 | 25th of January 2008 (Fri) 22:52 |
| EF 70-300mm f/4-5.6 IS USM or Canon Zoom Telephoto EF 100-300mm f/4.5-5.6 USM ? | sorashell | Canon EF and EF-S Lenses | 5 | 13th of March 2006 (Mon) 14:52 |
