Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 30th of July 2008 (Wed)   #1
Canadian Techdiver
Canadian Techdiver's Avatar
Location: Its Summer I am underwater scuba diving Silly.
Default Photoshop Elements Camera issue
Anyone else have this. My camera is about 4-5 months old. I go out and I shoot about 100-175 pictures at a time. I come home plug the camera in with the stock USB cable from the kit.
Photoshop sees the camera and connects to it. It scrolls through and says it finds X number of pictures. I select get pictures.
And It opens the orginizer and starts to get 2-3 pictures and then I get an error message that says to check the camera or the batteries to see if it is on. The camera is on and blinking busy.
This started about two weeks ago and it seems to be getting worse.
ie. I would shut the camera on and off and go through this a few times and finally get it. Last night I tried multiple times and only brought in the first 4 images of 162.
Just wondering if anyone else has seen this.
Camera gear: YEP
Canadian Techdiver is offline   Reply With Quote
Old 30th of July 2008 (Wed)   #2
tim
Light Bringer
tim's Avatar
Default Re: Photoshop Elements Camera issue
Buy a USB 2.0 card reader, take the card out of the camera and put it in that. It's faster, more reliable, and doesn't use camera batteries. I don't use download programs either, I use windows explorer to copy the files manually, though I used to use the free DIM from www.alanlight.com
tim is offline   Reply With Quote
Old 30th of July 2008 (Wed)   #3
Canadian Techdiver
Thanks Tim. That is where I was leaning... I was just hoping I didn't have a bigger problem. My cheapy card reader stopped working shortly after I bought my camera...LOL go figure.
Camera gear: YEP
Old 5th of August 2008 (Tue)   #4
Point-n-shoot-n
I tried to use a USB card reader and couldn't get it to download anything at all.........just sits there! Never had any problems with the cable to camera connection though..........lightning fast and always works! Is there a specific type of card reader that I would need to get to make things work that way? Perhaps mine is not compatible with something in my computer....??
Canon 1Ds Mkii, Canon 5d, Rebel XTI 400D 18-55 kit lens, Canon EF 100mm Macro 1:2.8, Canon EF 17-40 F4L, Quantaray 70-300 1:4-5.6 LD , Canon 70-200 F4L , Canon 100-400 4.5-5.6 L, Tamron 28-75 1:2.8 , 2 alien bee 800's, 430 EX, 580 EXii, rectangular and octo softboxes, assorted umbrellas, portable backdrops, radio triggers and still adding.............
Point-n-shoot-n is offline   Reply With Quote
Old 5th of August 2008 (Tue)   #5
tim
Light Bringer
tim's Avatar
Nope, any card reader, decent brands usually work better than generic ones. Try using windows explorer to do the copy.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
photoshop elements vs photoshop CS3 Justin_NJ RAW, Post Processing and Printing 9 29th of January 2009 (Thu) 19:37
Centering issue with Adobe Elements 5.0 RDSQUIRE RAW, Post Processing and Printing 2 30th of August 2007 (Thu) 07:17
Premire Elements with Photoshop Elements planesh00ter RAW, Post Processing and Printing 3 2nd of December 2004 (Thu) 01:21
photoshop elements/photoshop album? Timo Canon G-series Digital Cameras 5 2nd of August 2003 (Sat) 17:25
