#1 |
Still livin' the cowboylife
So I was pretty happy with my kenko tubes on my 100mm but since the reversing ring for my 50mm was only $8, I figured I'd give it a try.
So the 100mm plus reversed 50 is really getting me close...almost TOO close. Sometimes the items are on the lens. How do you work with this setup? Do you just back the minimum focus back out to get away from your subject a bit? I see people using the 50 reversed a lot, but just in my quick shots, the 100/reversed 50 combo gets you too close. Thoughts?
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x Ty - My Portfolio |
| sponsored links |
#2 |
Anybody??
#3 |
There is no adjusting anything. That's why it is not more common. You have to set both at infinity. Since the 100 and 50 don't zoom there is nothing you can do to adjust it. Your are taking 2 fixed focal lenses and making 1 fixed focal lens. The only thing yo can do is buy a macro lens or try other lenses to reverse.
Keep in mind "Its not the camera, its the photographer" works just as well for bad pictures as it does for good ones. ![]() www.the6by6frame.wordpress.com |
| sponsored links |
#4 |
Or use extension rings with your 100mm macro.
Alan Myers "Walk softly and carry a big lens." GEAR: 5DII, 7D(x2), 50D(x3), some other cameras, a bunch of lenses & accessories - FLICKR - PRINTROOM |
#5 |
cowboylife,
Sorry, but thats how it works. It makes it very difficult for lighting the subject but at least it gives nice sharp results and gives you 3x life size. |
| Thread Tools | |
| Display Modes | |
| What sort of magnification/working distance with 100mm macro + reversed 50mm f/1.8 | a_dee | Macro | 4 | 9th of May 2007 (Wed) 15:22 |
| reversed 50mm coin macro...need some help | Miyagi-san | Macro | 10 | 2nd of December 2006 (Sat) 17:08 |
| 100mm macro + 50mm reversed | Leorooster | Macro | 7 | 5th of August 2005 (Fri) 18:19 |
| Another cricket macro (G3+reversed 50mm) | JoseC | Macro | 12 | 12th of June 2005 (Sun) 19:34 |
| MACRO - reversed olympus OM-series 1:1,8 50mm | erik-nl | Canon G-series Digital Cameras | 7 | 1st of May 2004 (Sat) 16:16 |
