Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 4th of August 2008 (Mon)   #1
mezorn26
User is banned from forums
Default LIGHTROOM 2, edit in CS3 not exporting in to TIFF
I have it set properly in preferences. Just as 1.xxx fucntioned, when I click edit in CS3 and then a popup comes up that asks if you want to edit a copy with lightroom adjustments and you can also select what type of file format you want to edit in, so should 2.0 according to adobe.
But when I click EDIT IN CS3 using 2.0, I do not get a popup, it just opens the RAW (Cr2) file in CS3
anyone?
mezorn26 is offline   Reply With Quote
Old 4th of August 2008 (Mon)   #2
Victoria Bampton
Victoria Bampton's Avatar
Default Re: LIGHTROOM 2, edit in CS3 not exporting in to TIFF
Correct, that's how it's meant to work now. It uses the ACR pipeline to convert, and then you get to choose the file format when you save - so those who prefer to go straight to jpeg can do. If you don't want it to work like that, set CS3 as the secondary editor and it'll create your Tiff/PSD.
Victoria Bampton is offline   Reply With Quote
Old 4th of August 2008 (Mon)   #3
mezorn26
Thanks for the reply...I'm not sure I follow that last part.
Old 4th of August 2008 (Mon)   #4
Victoria Bampton
If you set CS3 as the 'Additional External Editor' in Preferences, it'll create a Tiff/PDF like v1 used to work.
Old 4th of August 2008 (Mon)   #5
mezorn26
ahh, got ya. I guess the only reason to do that would be to NOT edit the original? no?
Old 4th of August 2008 (Mon)   #6
TheHoff
Don't Hassle....
TheHoff's Avatar
And until they fix the bug where it is creating duplicate folders in my catalog when you use the ACR tunnel...
••Vancouver Wedding Photographer ••| [gear list] | Latest blog: 5 steps to stopping image loss
TheHoff is offline   Reply With Quote
Old 4th of August 2008 (Mon)   #7
mezorn26
what exactly is ACR tunneling?
Old 4th of August 2008 (Mon)   #8
TheHoff
Don't Hassle....
TheHoff's Avatar
I'm sure VB will explain it better but when you use the first option (as you tried in your original post) Lightroom does the conversion to PSD -- when you do it the second way with PS as the external editor, PS does the conversion. I'm not sure if there is any difference in the resulting file but with the first way, there is a bug where when the file goes back in to LR from PS, it will create a dupe folder in your catalog.
Old 4th of August 2008 (Mon)   #9
Victoria Bampton
Other way round, but yeah.
Primary external editor sends the raw data through the ACR pipeline and opens directly into PS. When you then save that file, some people with upgraded catalogs are seeing a bug in the volume browser as PS is sending back the file with a slightly differently formatted path.
Secondary external editor makes LR create the Tiff/PSD as it assumes that the other program knows nothing about raw data.
Old 4th of August 2008 (Mon)   #10
aram535
aram535's Avatar
Hmmm I actually use the TIFF option in LR2, CS3 just because I don't want the original CR2 edited. I guess I'm doing this wrong?
Gear List * www.tranquilphotos.com * My Blog
aram535 is offline   Reply With Quote
Old 5th of August 2008 (Tue)   #11
Victoria Bampton
Whatever you do, you will never touch the original CR2 aram535. If you open the CR2 directly into PS, you'll have to save as something, it just means you have a choice at that stage (jpeg/tiff/psd)
Old 5th of August 2008 (Tue)   #12
mezorn26
Not here...It opens as a Cr2 and then saves as a CR2
Old 5th of August 2008 (Tue)   #13
Victoria Bampton
It shouldn't be able to save to CR2 mezorn - Mac or PC?
Old 5th of August 2008 (Tue)   #14
René Damkot
Moderator
René Damkot's Avatar
Don't think so.
If you "open" in ACR, and *not* PS proper, you might "save" an xmp sidecar, but you *cannot* save a file as a Raw file out of PS.
(you could save a tiff file with the wrong (CR2) extension probably )
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 5th of August 2008 (Tue)   #15
mezorn26
PC...
To better explain what I am looking for. I very much liked that in Lightroom v 1.xx, when I chose to to edit in CS3, it would automatically create a new TIFF file in the lightroom catalog and after editing in CS3 I could remove the cr2 from the lightroom catalog and just the final tiff remained..
I am looking for the same or similar functionality, but I don't see how that can happen...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Exporting from ligthroom to CS3 hgsfrmme2u RAW, Post Processing and Printing 7 10th of July 2008 (Thu) 10:23
Help with Lightroom exporting JayCee Images RAW, Post Processing and Printing 1 21st of June 2008 (Sat) 08:19
Exporting with Lightroom into CS3? jnick RAW, Post Processing and Printing 14 26th of May 2008 (Mon) 10:36
Exporting a JPEG as a TIFF .... minimizes loss? danpass RAW, Post Processing and Printing 3 1st of March 2008 (Sat) 17:02
exporting in lightroom mchivers RAW, Post Processing and Printing 1 30th of July 2007 (Mon) 03:22
