Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 5th of August 2008 (Tue)   #1
bluesmap
Default i still do NOT understand
in photoshop how do i change dpi without changing the size of the image? everytime i alter dpi the size increases
bluesmap is offline   Reply With Quote
Old 5th of August 2008 (Tue)   #2
Damo77
Damo77's Avatar
Default Re: i still do NOT understand
Turn off the "Resample Image" tickbox.
Damien
Trying to build a Brisbane retouching, restoration and canvas printing business in the face of a global financial crisis
Check out my Photoshop portfolio, tutorials and articles
, and my blog: The Info Palette
Damo77 is offline   Reply With Quote
Old 5th of August 2008 (Tue)   #3
Damo77
Damo77's Avatar
Wait, are you talking about file size, or physical dimensions?
Damien
Old 5th of August 2008 (Tue)   #4
Damo77
Damo77's Avatar
You're aware, aren't you, that resolution is completely irrelevant unless you're actually printing?
Damien
Old 5th of August 2008 (Tue)   #5
bluesmap
this is for printing actually.
Old 5th of August 2008 (Tue)   #6
bluesmap
ok i see how the resolution stays the same but the "document size" changes with dpi. that should be ok..
thanks
Old 6th of August 2008 (Wed)   #7
eddarr
There's Moderators under there....
eddarr's Avatar
First understand that it is pixels per inch rather than dots per inch. Dots per inch is a printing term and pixels per inch is the resolution of an image.
If you have an image that is at 300ppi and you change the dimensions it will be resampled to a new quantity of pixels because it will always divide the dimension by 300ppi.
It might help to state what it is you are trying to achieve.
Eric
eddarr is offline   Reply With Quote
Old 6th of August 2008 (Wed)   #8
bluesmap
printing an image at 8 x 10
should i leave my pixels/inch at default settings?
my printer says
books are printed at 300 DPI. The largest photos you can use - full page pictures in our 13x11 book - should be no bigger than 3900x3300 pixels. Placing images larger than this on a page in BookSmart will not improve the end product, as our printers print at 300 DPI. Larger images will simply make uploading more difficult, or even impossible, and may also result in scaling artifacts.
Please know that although 300 DPI is optimal, we can accept images down to 150 DPI. Know that at that size, your printed pictures may not look as great as you'd like.
im using an online printer and thats what they say on the FAQ section. so now im thinking i should just leave the PPI at default since its not dpi
jeez i never can understand this
Old 6th of August 2008 (Wed)   #9
Damo77
Damo77's Avatar
Honestly, don't complicate it. Just set your crop tool to 8,10,300 in the options bar and crop.
Damien
Old 6th of August 2008 (Wed)   #10
gooble
gooble's Avatar
my printer says
I have recently gone on several rants in the forum due to the fact that people interchange dpi and ppi as if their equals and they're not.
I was reading information regarding printing size and getting conflicting information over and over. Even the pro lab where I get prints was interchanging them so it wouldn't surprise me in the least if this book publisher you're talking about is doing the same thing.
I think I have things understood now. Basically don't worry about dpi in the least unless comparing printers that you want to buy and/or use to tell which one has finer detail. Many inkjet printers have dpi in the thousands so if they're saying it's 300 that's a red flag right there that they're mixing things up.
Now, ppi really only has any meaning when choosing an output size for a print. I won't go into web viewing but I basically wouldn't worry about it in the least for computer and web viewing. Certain printers require a certain ppi for best image quality it may range from 300 to 760ppi. The lab I use wants 300ppi images and they do photographic prints which means, as far as I know that there are NO dots so dpi makes no sense.
What this means is, say you have a 3888x2592 pixel image that you want to print at 12x8 inches at 300ppi. You multiply the dimensions in inches by the ppi and get 3600x2400 pixels. That is actually less than you started with so in PS if you go to image resize and set ppi to 300 and document size in inches to 12x8 then it will resample the image to 3600x2400 pixels. If you wanted 15x10 inches then it would upsample to 4500x3000 to maintain 300ppi.
Hope this helps.
gooble is offline   Reply With Quote
Old 6th of August 2008 (Wed)   #11
Underscore
I think you mean PPI, not DPI. Photoshop doesn't have anything to do with DPI. Your printer determines DPI based on the way the printhead is manufactured.
I see this error in denotation quite a bit and probably adds more to confusion vs solving problems and giving answers.
Underscore is offline   Reply With Quote
Old 6th of August 2008 (Wed)   #12
poloman
poloman's Avatar
Here is a screen shot. Note cropping parameters at the top of the page. Note image size pop up. It is this easy.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
poloman is offline   Reply With Quote
Old 6th of August 2008 (Wed)   #13
Mark1
Mark1's Avatar
I just adjust the image size in the print driver, not in the image editor.
When I hit "print" a menu comes up and asks what size I want it to be printed at. I tell it and off it goes.
Keep in mind "Its not the camera, its the photographer" works just as well for bad pictures as it does for good ones.
www.the6by6frame.wordpress.com
Mark1 is offline   Reply With Quote
Old 6th of August 2008 (Wed)   #14
poloman
poloman's Avatar
I do this so I can do an accurate sharpening as my last step.
I save my files in 2:3 ratio tiff format at full size with all edits except sizing and sharpening. This way I am ready to produce whatever size my client might want.
Old 7th of August 2008 (Thu)   #15
Lowner
"I'm the original idiot"
Lowner's Avatar
So do I! Why make life more complicated than it has to be?
Richard
http://rcb4344.zenfolio.com
Lowner is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Please help me understand... Amamba Small Flash and Studio Lighting 8 24th of May 2008 (Sat) 11:20
They don't understand no! adblink The POTN Lounge 14 27th of April 2008 (Sun) 09:46
Help me understand sjnovakovich Canon EF and EF-S Lenses 2 29th of August 2007 (Wed) 08:47
Please help me understand KTollig Birds 24 6th of March 2007 (Tue) 11:45
Help me understand, please. Jaime The POTN Lounge 13 10th of September 2006 (Sun) 20:59
