#1 |
Is there a Advanced user's guide for 580?
Canon 40D 18-55, 28-135 IS USM, 70-300 IS USM, 580ex II 100-400L, 85mm 1.8 MANFROTTO 3036+501 190CLB+ 3265 680+308rc |
| sponsored links |
#3 |
While not necessarily an easy read for everyone; The 580exII manual covers all the functions, custom functions, modes and adjustments. Is there something specific you are looking for? |
| sponsored links |
#4 |
cant find my manual, just trying to get something with the custom functions.
#5 |
There is a photocopied .pdf file loose on the net somewhere. I don't recall where I located it.
There are 13 custom functions. 0 - distance indicator display; 0=meters, 1-feet 1 - auto power off; 0=enable, 1=disabled 2 - modeling flash; 0=enabled(dof preview button), 1=enabled(test firing button), 3=disabled 3 - FEB auto cancel; 0=enabled, 1=disabled 4 - FEB sequence; 0=0,-,+ 1= -,0,+ 5 - flash metering mode; 0=E-TTl II/E-TTL, 1=TTL, 2=External metering: Auto, 3=External metering: Manual 6 - quickflash with continuous shot; 0=disabled, 1=enabled 7 - test firing with autoflash; 0=1/32 power, 1=full output 8 - AF assist beam firing; 0=enabled, 1=disabled 9 - Auto zoom for sensor size; 0=enable, 1=disabled 10 - slave auto power off timer; 0=50 minutes, 1= 10 minutes 11 - slave auto power off cancel; 0=within 8 hours, 1=within 1 hour 12 - flash recycle with external power source; 0=flash and external power, 1=external power source 13 - Flash exposure metering setting; 0=speedlite button and dial, 1=speedlite dial only To bring up the C-fn. menu press and hold the LCD panel illuminator/C-fn. button for 2 seconds. C-fn 5-2 can be used with the 1D Mk III. Others usually require C-fn. 5-3 when not using C-fn. 5-0. Hope this helps. |
#6 |
Thanks for spending the time with the reply photog!! I do appreciate it.
#7 |
Click the link below and you will find the manual.
http://akamaipix.crutchfield.com/Man...280580EXii.PDF Hope this helps. |
| Thread Tools | |
| Display Modes | |
| 580ex II Guide Numbers Off camera | xmacvicar | Small Flash and Studio Lighting | 8 | 21st of December 2007 (Fri) 14:04 |
| guide number of flash 580ex, 550ex, 540ez? | christence | Small Flash and Studio Lighting | 4 | 29th of November 2006 (Wed) 09:46 |
| User Guide 580ex / 430ex | nino | Small Flash and Studio Lighting | 5 | 10th of November 2005 (Thu) 19:23 |
| Printing users guide for Elements 2.0 | canon shooter | RAW, Post Processing and Printing | 0 | 18th of August 2005 (Thu) 10:38 |
| in need a520 users guide | bambam | Small Compact Digitals by Canon | 0 | 19th of June 2005 (Sun) 09:37 |
