#1 |
Does anybody use a homemade diffuser for your onboard EOS flash? or is something made commercially (similar to the flashclip for the canon P&S's)?
Sometimes, I really want to bring minimal equipment as possible (body+lens only), but the onboard flashes are just too harsh. Is there such a thing or is it up to me to create it myself? Thanks all!
~Mark Canon 7D |40D Canon EF-S 17-55 f/2.8 IS USM | Tamron SP 70-200 f/2.8 Di VC USD Canon Speedlites 580exII, 5800ex . . . and a bunch of other stuff Last edited by markubig : 22nd of January 2005 (Sat) at 19:36. Reason: correct the title |
| sponsored links |
#2 |
Hello:
For the last 10 years or so, I've used a very simple attachment. It's a piece of white card-stock, the size of an index card. I attach it to my flash with a piece of velcro. I position two velcro tabs on the flash. One on the top, above the flash head (shooting horizontally), and one on the side (for vertical positioning of the strobe). The bounce card works as a great diffuser. You can also add a small strip of gold or silver contact paper to the white to change the look of the bounce. The card will easily fit in my shirt-pocket when not mounted to the flash. Thanks. |
#3 |
Trigger Man - POTN Retired
For the onboard flash it's a little tough, but I once saw a nice trick where a person cut out a piece of a milk jug and then cut a hole in it sized for the diameter of then les. The lens hole was cut out of the bottom half, leaving almost 2/3 of the milk jug piece unharmed. He then "clipped" this onto the lens. So now the flash would fire and the light would travel about 4 or 5 inches and hit the piece of milk jug which diffused the light.
It looked odd, but was quite effective.
You can take my 100-400 L away when you pry it from my cold, dead fingers. Scottes' Rum Pages - Rum Reviews And Info Finally, I have a Gallery! Follower of Fidget - Joined the cult of HAMSTTR© |
| sponsored links |
#4 |
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
#5 |
Thank guys!!!
Well, we've got a blizzard here in the northeast, so I'll try to play around with your suggestions . . . maybe look for some other materials . . . Cheers!
~Mark Canon 7D |40D Canon EF-S 17-55 f/2.8 IS USM | Tamron SP 70-200 f/2.8 Di VC USD Canon Speedlites 580exII, 5800ex . . . and a bunch of other stuff |
#6 |
Hi markubig,
I have something called a “Lumiquest” Promax Softbox. Basically it folds up when not in use and otherwise attaches to my flashes with Velcro. It’s a miniature light box. I’ve used it for years and it seems to work well. Mine came from ‘Wolf Camera’ in Memphis. Hope that helps. The attached site is just one of the places you can buy it. I have not bought from them, so I can’t comment. http://www.link4pc.com/cameras/camer...ies/51288.html |
#7 |
I can recommend the Lumiquest Pocket Bouncer - it's really well constructed and diffuses the flash very nicely by making the light area larger. It works best on close subjects and when you shoot on location where nothing is available to bounce the flash of (outdoor for example).
Best wishes, Oleg. www.Olegis.com My equipment list 'I take orders from no one except the photographers' – Harry S Truman |
#8 |
Location: sydney, au (now in singapore for a few years)
uh...i think he is saying that he doesn't want to take his flash (for which he already has an omnibounce...) - he's asking for some sort of diffuser for the onboard flash.
fwiw, i've seen someone with a white piece of plastic from a bowl cut into a big arc in front of the flash. and believe it or not, i've also seen someone use a white plastic grocery bag, all wadded up and bunched over the flash - truly ghetto and looked horrible, but i get the feeling it worked.
-- oblio 1dmkiii - 5dmkii -Leica M8/M6 - Mamiya 645AFDiii/zd ModelMayhem | my flickr gallery |
#9 |
Oh, I'm sorry - I missed the word "onboard" ... Try this link , it may be useful for you.
#10 | |
#11 |
I use two diferent options:
first is a Photoflex 12x16 softbox. I use in combo with a dome diffusor clipped on the front of the flash head. You have to buy a ring and bracket for it (total cost with shipping is about 100) and you really have to use a L shaped flash bracket which means that you have to also have a sync cord (I just spent another 100-125 of your money). go to their web site for more info. It really yeild VERY VERY escellent results, but is a bit unwieldy and can make some subjcts uncomfortable. Westcot sells a foldable 5X8 inch softbox that is very easy to use. When also used with the dome it gives decent results and is less obvious. It is about 25 and you can get away without a flash bracket, but they are cheap and worth it for the results |
#12 | |
---Bob Gross--- |
#13 |
I've got a couple of softbox type diffusers which work remarkably well. They're just tupperware typw containersith a hole cut in the back that fits the flash nice and tight.
One is about 12 inches by 6 inches, the other about 4X6 inches. In theory, or rather, so I was told, you should put reflective material inside to direct the light forward, but I find that if I don;t, the whole softbox kid of illuminates the room, giving a better effect. Try it out. It's really cheap, and works excellently. |
#14 |
It does not - I missed the onboard part
#15 |
Hi
use some tracing paper and a spring clip ( paper type0 the kind you squeeze mark |
| Thread Tools | |
| Display Modes | |
| Homemade shutter release for Canon EOS 350D | cheewooi | Canon EOS Digital Cameras | 42 | 29th of March 2007 (Thu) 12:57 |
| diffusers | monkey_wrench | Canon G-series Digital Cameras | 1 | 20th of December 2006 (Wed) 16:31 |
| Diffusers? Do I need one? | islandphoto | Small Flash and Studio Lighting | 27 | 24th of April 2006 (Mon) 01:00 |
| diffusers | coeng | Small Flash and Studio Lighting | 1 | 20th of March 2006 (Mon) 16:04 |
| Can older EOS flashes be upgraded? | Rusty Shackleford | Canon EOS Digital Cameras | 1 | 10th of November 2003 (Mon) 18:50 |
