Thread started 23 Jan 2005 (Sunday) 15:51
How to crop pictures with correct print aspect e.g. 4x6..
Tdragone
Joined Sep 2004
Jan 23, 2005 15:51 |  #1
Hi All;
I have a Canon printer which I loved; but used knockoff ink cartridges and one leaked; took printer in for service; canon paid an auth repair shop to clean the printer (yay)
While in the shop; my folks heard 'printer is not working' and bought me an HP printer...
I LOVE the quality of the HP unit; BUT...
With the canon; there was an app called Easy Photo Print that would allow you to put the 'crop' rectangle on the picture to show what area of the full size picture you wanted to print. If you enlarged it vertically; the horizontal would also grow-thus retaining the L by W ratio.
Problem is; it only works when printing to the Canon printer.
Is there a free or cheap (< $20) application for windows that will let me do the same thing?
As seen here:
Thanks in advance..
-ToM D.
-Tom Dragonetti
Spyder Holster + 1Dmk IV, 50D, G11
10-22, 16-35 2.8Lii, , 24-70 2.8Lii, 50mm 1.4,
70-200 2.8Lii IS, 100-400L IS
1.4x TC, 580EX ii, ST-E2
tim
Light Bringer
Jan 23, 2005 17:43 |  #2
In Photoshop CS use the select tool, and in the options bar choose 'fixed aspect ratio'. Enter 6 wide and 4 high, and the correct ration will always be selected. Choose Image | Crop to crop it.
I don't know if PS elements does it or not., but it's worth a go. Photoshop's invaluable to me, well worth it's price, especially if you can get an upgrade price.
Tdragone
Joined Sep 2004
Jan 23, 2005 22:41 as a reply to  @ tim's post |  #3
Will this let me 'drag' or re-size the cropped selection until I get what I like?
The outer frame in the pic shown above can be resized until I find a framing I like + I can slide it around until I get it exactly how I want it.
Sorry If I'm not explaining this better..
-Tom D.
-Tom Dragonetti
Dante ­ King
"Cream of Corn" BurgerMeister
Joined Jan 2005
Jan 23, 2005 22:57 |  #4
yes it will. quite nicly too.
Dante
I am not an Lcoholic. Lcoholics go to meetings!
mrsmac
Joined Oct 2003
Jan 23, 2005 23:01 as a reply to  @ tim's post |  #5
PS Elements does it!
FlashGordon
Joined Jan 2005
Location: London, UK where the sun is an occasional event
Jan 24, 2005 05:04 as a reply to  @ mrsmac's post |  #6
As mrsmac says PSE will do this too. After selecting the crop tool, type in the width and height dimensions you want and the aspect ratio will be maintained when you click and drag. Once you let go of the mouse you can subsequently click on the cropped area and move the selection while keeping the left click of the mouse depressed.....very easy and I use it a lot.
Just a note, however, PSE will 'remember' your selection for the next time you use the crop tool so you will either need to reset it for more random dimensions or re-type your new crop width and height dimensions for an alternative print size.
Gordon
Tdragone
Joined Sep 2004
Jan 24, 2005 21:54 as a reply to  @ FlashGordon's post |  #7
Thanks all!
I can't believe I didn't notice the size bar on the top of the screen (The default in my PS 7.0 was pixels; when I changed measurements to inches it became too obvious). :rolleyes:
Again; thanks
-Tom D
-Tom Dragonetti
Kostyanych
Joined Jan 2005
Mar 09, 2005 06:30 as a reply to  @ Dante King's post |  #8
I am not sure. :)
I founded that I can use Select tool to select (and then Crop) the picture just with requred aspect ration.
But I can't use Crop tool to crop the picture with preselected aspect ratio without resampling.
You can easy move and resize "crop tool selection".
But I can just move (no resize) my "select tool selection".
Or may be I am just missing something....
Canon 7D | EF-S 10-22 F/3.5-4.5 | EF 24-105 mm F/4L IS USM | EF 70-200 F/2.8L IS USM | EF 50 mm F/1.4 USM | EF 85 mm F/1.8 USM | 580EX II| TC-80N3 | Gitzo G2220 tripod | Manfrotto 329RC4 head | Dynatran AT-CF992 tripod | Newton Bracket Di100FR2 | 2 x POTN Op-Tech Strap | 4 x Hensel Integra 500 Pro | 2 x PW Plus II | Sekonic L-758D | Dynatran AS-014-2
PacAce
Joined Feb 2003
Mar 09, 2005 06:52 as a reply to  @ Kostyanych's post |  #9
Kostyanych wrote:
I am not sure. :)
If you don't want to resample when cropping, make sure that the "resolution" field is blank. If it's not, the cropping tool will resample the image to comply with the resolution specified.
...Leo
mdmedicgod
Joined Sep 2004
Mar 09, 2005 07:03 as a reply to  @ PacAce's post |  #10
If you wanted the whole image. Not just a cropped section. Couldn't u just change the image size to desired print size?
Canon 1D Mark II
Canon 20D
Canon 300D
Canon 70-200 F2.8L IS
Canon 24-70 F2.8 L
Canon 50mm F 1.8
Sigma 70-200mm F2.8 EX DG
2 kit lenses MKI and MKII
http://www.fithp.com (external link)
PacAce
Joined Feb 2003
Mar 09, 2005 07:09 as a reply to  @ mdmedicgod's post |  #11
Yes you can but that's not what was asked.
...Leo
Kostyanych
Joined Jan 2005
Mar 09, 2005 07:47 as a reply to  @ PacAce's post |  #12
Or, I have just founded the solution. :)
I have tried to clean resolution box before. But!!!
If you put just number into width and height for the crop tool (in the toolbar on the top) PS will put px in these windows.
And in this case you will get resample anyway.
But if you put 8 in into the width and 10 in into the height, and clear resolution window you will get the crop wihtout resampling. Also you will get funny resolution (like 5.6 px/inch) :)
But it is very easy to fix.
Before I have tried just first way. :) And I was getting resample every time.
Well, now everything is clear for me. :)
PacAce
Joined Feb 2003
Mar 09, 2005 09:41 as a reply to  @ Kostyanych's post |  #13
Yes, you're right about the Pixels unit. I always use the Inches unit so it never occurred to me that your resampling problem may have been related to the unit (Pixels in your case) you were using. :)
...Leo
3,543 views & 0 likes for this thread
Latest registered member is livingHi
716 guests, 264 members online
